  • 1312查看
[Advisor] 请高人帮助
  • 签到天数: 10 天
    发表于 21-3-2021 10:18:01 | 显示全部楼层 |阅读模式
    菜鸟 :advisor点击run后出现下列情况,
    advisor
    # ADVISOR 2002 April 30, 2002
    Data loaded: TC_DUMMY - lossless belt drive
    Data loaded: MC_AC75 - Westinghouse 75-kW (continuous) AC induction motor/inverter
    Data loaded: EX_SI - Standard catalyst for ~stoichiometric SI engine
    Data loaded: VEH_SMCAR - Hypothetical small car
    Data loaded: FC_SI41_emis.M - Geo 1.0L (41kW) SI Engine - transient data
    Data loaded: ESS_PB25 - Hawker Genesis 12V26Ah10EP VRLA battery, tested by VA Tech
    Data loaded: TX_5SPD - manual 5-speed transmission
    Data loaded: WH_SMCAR - Wheel/axle assembly for small car
    Data loaded: PTC_PAR - multi-spd parallel electric-assist hybrid w/ electric launch
    Data loaded: ACC_HYBRID - 700-W constant electric load
    Data loaded: TX_1SPD - 1-speed transmission
    Data loaded: PTC_EV - Powertrain control for electric vehicle
    Data loaded: VEH_EV1 - EV1 vehicle chassis
    Data loaded: MC_EV1_draft - GM EV1 traction motor based on Westinghouse 75-kW (continuous) AC induction motor/inverter
    Data loaded: INIT_CONDS - Standard initial conditions
    Data loaded: CYC_UDDS - EPA Urban Dynamometer Driving Schedule
    [SimSetupFig:road_grade_checkbox_Callback] Error!
    错误使用 legend>process_inputs (line 554)
    参数无效。有关详细信息,请键入 'help legend'。
    未定义变量 "Utils" 或类 "Utils.helpProcess"。
    Data loaded: CYC_ECE_EUDC - ECE+EUDC Drive Cycle
    [SimSetupFig:cycles_Callback] Error!
    [SimSetupFig:run_pushbutton_Callback] Error!
    错误使用 gui_run_simulation (line 82)
    Error due to multiple causes.
    > In SimSetupFig>run_pushbutton_Callback (line 1352)
      In SimSetupFig (line 374)
    GMT+8, 23-1-2025 12:57 , Processed in 0.500317 second(s), 34 queries .
