TA的每日心情 | 郁闷 11-3-2018 10:50 |
签到天数: 5 天 [LV.2]偶尔看看I
各位大神:
我在建立涡轮机模型的时候使用了用户自定义模型。但是在预运行的时候,提示了这样的错误信息,能帮忙看看这是什么原因吗?
*WARN:Turbine Ref. Object not found: ign
Code will assume it is a file name and will try to open it
INFO File not found in USER-SPECIFIED dir., will search for the file in local
directory and in any External Paths specified in Advanced Run Setup
for file ign
*FAIL:FILE NOT FOUND IN ANY SPECIFIED SEARCH PATH:ign
If the file does exist in the specified location, note that
this may be caused by differences in cases of file names
("intake.val" in the GTM vs. "INTAKE.val" on the hard drive)
Note: UNIX/Linux file systems are case sensitive, while
Windows systems are not. A model that runs on a Windows system
may fail on UNIX/Linux systems due to this case-sensitivity.
