  • 3739查看
  • 7回复
[Advisor] advisor仿真时出错,点run后仿真页面显示不出来
    21-8-2017 10:00
  • 签到天数: 6 天
    发表于 11-8-2017 07:04:21 | 显示全部楼层 |阅读模式
    点continue后能自动跳出UDDS工况,改个其他工况也能显示,但再改个循环次数什么的就不行了,显示不出仿真页面,还如下报错。
    大神们有遇到这种错误吗?还请指教!
    警告: The MaskInitialization string of block 'BD_CONV/drive cycle <cyc>/repeated cycle speed vs. time' contains usage of mask variables by
    reference (' @1 @1 @2') instead of by variable name. Support for this usage will be removed in a future release
      In gui_run_simulation at 82
      In accel_test_advanced at 252
      In gui_run at 93
      In SimSetupFig>run_pushbutton_Callback at 1345
      In SimSetupFig at 374
    警告: The MaskInitialization string of block 'BD_CONV/drive cycle <cyc>/repeated cycle vehicle cargo mass vs. distance' contains usage of
    mask variables by reference (' @1') instead of by variable name. Support for this usage will be removed in a future release
      In gui_run at 93
    警告: The MaskInitialization string of block 'BD_CONV/drive cycle <cyc>/super-smooth, no-lag trace' contains usage of mask variables by
      In gui_run at 93
    [SimSetupFig:run_pushbutton_Callback] Error!
    错误使用 save
    无法写入文件 C:\Program Files\MATLAB\ADVISOR2002\interactive\recorded_interactive.mat: 权限被拒绝。
    > In SimSetupFig>run_pushbutton_Callback at 1352
    难过
    15-1-2019 20:45
  • 签到天数: 11 天
    发表于 26-8-2017 16:50:10 | 显示全部楼层
    同样的问题  楼主 解答了吗?
    难过
    21-9-2017 00:13
  • 签到天数: 8 天
    发表于 7-9-2017 22:38:15 | 显示全部楼层
    朋友,我最近在学习ADVISOR,一直下载不到软件,是否方便将您的软件给我共享下,不胜感激!
    擦汗
    2-11-2017 13:44
    发表于 2-11-2017 13:53:24 | 显示全部楼层
    同问,这样的问题怎么解决
    难过
    2-11-2017 14:32
    发表于 2-11-2017 16:30:15 | 显示全部楼层
    同问,请问点击run后出现错误使用 gui_run_simulation   Error due to multiple causes如何解决,新手,求指导
    错误使用 gui_run_simulation (line 82)
    Error due to multiple causes.
    > In SimSetupFig>run_pushbutton_Callback at 1351
  • 签到天数: 143 天
    [LV.7]常住居民III
    发表于 6-3-2018 17:51:41 | 显示全部楼层
    楼主把结果告诉一下。
    发表于 16-1-2019 19:46:34 | 显示全部楼层
    hpandwl_JDSpP 发表于 2-11-2017 16:30
    同问,请问点击run后出现错误使用 gui_run_simulation   Error due to multiple causes如何解决,新手,求 ...
    你好,我也碰到一模一样的问题,请问你找到解决办法了吗?
    发表于 17-2-2019 21:08:24 | 显示全部楼层
    出现上述问题大多数原因在于MATLAB版本与advisor2002不兼容造成的,为了避免修改m文件时间的浪费,建议使用6.1版本的MATLAB,二者匹配兼容非常好,从来没有出现过类似的错误
    GMT+8, 3-1-2025 19:29 , Processed in 0.377494 second(s), 30 queries .
