  • 722查看
[底盘] Tyre testing轮胎试验
发表于 28-1-2016 22:02:19 | 显示全部楼层 |阅读模式
Tyre testing轮胎试验
Hypertext has been divided to three levels:
•        Contents of the first level are titles on the left side of your computer screen.
•        Contents of the second level shows up to this area while clicking titles.
•        Contents of the third level shows up to a new window while clicking link names or small figures in the second level text. Third level contents can be texts, large figures or tables.
Investigation of tyre comfort
Tyre spring rate measurement
________________________________________
Devices for measuring tyre spring rate are classified depending on the following criteria:
•        Time-variation of tyre applied forces:
o        static measurement;
o        dynamic measurement;
o        both type measurement.
•        Direction of applied force:
o        vertical (radial);
o        longitudinal;
o        lateral.
•        Part of device that is moving:
o        tyre hub;
o        contact surface.
The test rig for measuring static vertical spring rate of passenger tyre and the vertical force transducer are shown, respectively, in figure 1 and figure 2 [1]. The test rig consists of several subassemblies: wheel attachment, loading system, measuring systems for vertical displacement and force.
Tyre testing轮胎试验.doc
594.5 KB, 下载次数: 0, 下载积分: 贡献值 -3
GMT+8, 15-4-2026 19:16 , Processed in 0.465585 second(s), 37 queries .
