  • 1872查看
博士的氧传感器
牛头目 该用户已被删除
发表于 11-12-2015 11:05:21 | 显示全部楼层 |阅读模式
请问谁有博士的氧传感器说明书,六线制的,非常感谢
发表于 16-12-2015 14:42:58 | 显示全部楼层
遇到这种需求资料的,建议先找度娘,到度娘文库找找
牛头目 该用户已被删除
 楼主| 发表于 17-12-2015 21:17:53 | 显示全部楼层
找过好多地方,一般都是在介绍工作原理,不是我想要的,现在想找一份原版的说明书,之前有过用浪么哒(过量空气系数)分析仪,也不需要那些针脚的定义,直接就可以读数,现在想撤去分析仪,直接取氧传感器的信号,所以您懂得
    难过
    22-5-2019 08:34
  • 签到天数: 6 天
    发表于 29-12-2015 19:02:07 | 显示全部楼层
    度娘会告诉你答案的,小伙子
    10-3-2016 09:18
  • 签到天数: 8 天
    发表于 2-1-2016 09:15:55 | 显示全部楼层
    PRODUCT
    DATASHEET
    #57006 rev 2.0
    MoTeC Pty. Ltd, 121 Merrindale Drive, Croydon South, Victoria 3136, Australia
    www.motec.com, Ph 61 3 9761 5050, Fax 61 3 9761 5051, support@motec.com.au
    Configuration in ‘hundred
    series’ ECU
    Procedure described for Version 3 software.
    Configuration in Version 2 software is similar.
    1.  On the Adjust menu, click Sensor Setup
    and then Input Setup.
      Double-click the Lambda 1 (La1)
    channel and in the Input Source box,
    select Lambda 1.
      Click Predefined, select #38
    Lambda Internal LSU or NTK and
    click OK twice.
    2.  On the Adjust menu, click Sensor Setup
    and then Wideband Lambda Setup.
      Click Sensor Type and enter 7 (LSU
    4.9 Normal) or optional 8 (LSU 4.9
    Fast Heat).
      Click ESC, then click Calibration
    Number and enter the number as
    explained on screen.
      Click ESC, then click Quick Lambda
    MODE and enter the number as
    3.  On the Adjust menu, click Auxiliary
    Output Functions
      Click Auxiliary Out #X - choose the
    number of the output that has the
    sensor heater connected.
      Enter 9 (Lambda Sensor Heater) and
    click ESC.
      Click Parameters and enter 1 for
    Lambda 1.
    Repeat the configuration for a second Lambda
    sensor if required (not available in M400).
    Lambda versus Air Fuel Ratio
    Examples of typical values.
    Air Fuel Ratio
    Lambda
    0.70  10.3  4.5  6.8  10.2  10.9
    0.75  11.0  4.8  7.3  10.9  11.6
    0.80  11.8  5.1  7.8  11.6  12.4
    0.85  12.5  5.4  8.3  12.3  13.2
    0.90  13.2  5.8  8.8  13.1  14.0
    0.95  14.0  6.1  9.3  13.8  14.7
    1.00  14.7  6.4  9.8  14.5  15.5
    1.05  15.4  6.7  10.3  15.2  16.3
    1.10  16.2  7.0  10.8  16.0  17.1
    1.15  16.9  7.4  11.2  16.7  17.8
    1.20  17.6  7.7  11.7  17.4  18.6
    1.25  18.4  8.0  12.2  18.1  19.4
    1.30  19.1  8.3  12.7  18.9  20.2
    1.35  19.8  8.6  13.2  19.6  20.9
    1.40  20.6  9.0  13.7  20.3  21.7
    1.45  21.3  9.3  14.2  21.0  22.5
    1.50  22.1  9.6  14.7  21.8  23.3
    1.55  22.8  9.9  15.1  22.5  24.0
    1.60  23.5  10.2  15.6  23.2  24.8
    Me
    thanol
    LPG
    Diesel
    E85
    blen
    d
    Gasoline PRODUCT
    DATASHEET
    #57006 rev 2.0
    Connector and Pinout
    Connecting to a ‘hundred series’ ECU
    6 pin connector
    Mating connector #64010
    Pin no  Name  Colour
    1  Ip  Red
    2  Sensor 0 V  Yellow
    3  Heater –  White
    4  Heater +  Grey
    5  Ipr
    6  Vs  Black
    Lambda
    sensor  ‘Hundred series’ ECU
    Pin   Name M400/M600/
    M800 Pin
    M880
    Pin Name
    1  Ip  B_26  60  LA1–P
    2  Sensor 0 V  B_16  27  0V–ENG
    3  Heater –
    A_1, A_18,
    A_23, A_24,
    A_31, A_32,
    A_33, A_34
    8, 9, 43,
    51, 58, 59,
    65, 64
    Any Aux
    4  Heater +  A_26  23, 32, 41  VBAT
    5  Ipr  NC  NC  NC
    6  Vs  B_25  54  LA1–S
    When connecting a second Lambda sensor (not
    available on M400)
    1  Ip  B_13  61  LA2–P
    6  Vs  B_12  55  LA2–S
    Lambda sensor   PLM
    Pin   Name  Pin   Name
    1  Ip  M_9  Ipr
    2  Sensor 0 V  M_5  Common
    3  Heater –  M_7  Heater -
    4  Heater +  M_2  Heater +
    5  Ipr  M_4  Ip
    6  Vs  M_8  Vs
    Connecting to a PLM MoTeC Pty. Ltd, 121 Merrindale Drive, Croydon South, Victoria 3136, Australia
    Product specifications are subject to change PRODUCT
    DATASHEET
    #57006 rev 2.0
    Lambda Sensor Installation
    Note: The Lambda sensors are factory
    calibrated with a trimming resistor embedded
    in the sensor connector. If this connector is
    cut off and replaced the sensor will require a
    free air calibration.
    The Lambda sensor should be fitted to the
    exhaust system with the sensor tip protruding
    into the exhaust gas flow.
    Considerations when fitting a sensor:
     Place the sensor on an angle between 10
    and 90 degrees to the vertical with the tip of
    the sensor pointing down to prevent
    condensation build up between the sensor
    case and the sensor ceramic.
     Do not place the sensor in a vertical
    position; excess heat soak will prevent
    proper operation.
     Place the sensor at least 1 meter from the
    exhaust ports to avoid excessive heat
    (recommended).
    open end of the exhaust system to avoid
    incorrect readings due to outside oxygen
    (recommended).
     Place the sensor away from the flame front
    coming out of the cylinder head and away
    from areas where one cylinder may have
    more effect than another.
     If possible, do not place the sensor near
    exhaust slip joints; some designs allow air
    to enter resulting in incorrect readings.
    If the sensor has to be placed near a slip
    joint, reverse the slip joints to reduce the
    influence of introduced air.
    Sensor Warm-up
    The internal heater in the sensor is powerful
    enough to allow accurate measurement when
    gas temperature is at room temperature. The
    sensor will take approximately 20 seconds to
    heat up.
    The maximum continuous operating
    temperature of the sensor is 930 °C. Sensors
    should not be used at higher temperatures for
    a prolonged period. The sensor can be heated
    to 1030 °C for a maximum of 10 minutes, but
    this may reduce the accuracy.
    Sensor Lifetime
    Sensor lifetimes are highly dependent on
    application for example the type of fuel used
    and the volume of gas flow over the sensor.
    Some factors that reduce sensor lifetime are:
     Contaminants such as silicon, lead, oil, etc.
    (use sensor-friendly sealants)
     Thermal cycling and exposure to exhaust
    fumes without any heating control active
     Incorrect placement in the exhaust that can
    overheat the sensor
     Leaded fuel – substantially reduces lifetime
     Water jacketed exhaust manifolds as in
    PWCs – substantially reduces lifetime
    At the end of its life the sensor becomes slow
    to respond and does not read rich properly.
    Regular free air calibrations will maintain the
    accuracy of the sensor over its lifetime.
    Correct  Incorrect
    Introduced air  No air introduced
    exhaust flow
    Incorrect   Correct
    GMT+8, 18-5-2026 08:57 , Processed in 0.545963 second(s), 42 queries .
