  • 2333查看
[Advisor] advisor在64位win7run出错,求教在线等
发表于 19-5-2015 23:35:29 | 显示全部楼层 |阅读模式
### Build procedure for model: 'BD_FUELCELL' aborted due to an error.
[SimSetupFig:run_pushbutton_Callback] Error!
Error using gui_run_simulation (line 82)
Unable to build a standalone executable to simulate the model 'BD_FUELCELL' in rapid accelerator mode. This could be because the model has blocks that either do not support code generation or generate code only for specific hardware targets. Models with such blocks cannot be simulated in rapid accelerator mode.
The rtwbuild error (message and identifier shown below) may identify these blocks.
   message: Invalid parameters for S-function 'BD_FUELCELL/<vc> fuel cell/gearbox control for series  HV and EV/downshift  command/load fraction/S-Function'. For code generation, S-function parameters must be one or two dimensional nonsparse numeric or character arrays unless the S-function uses a TLC file and has an mdlRTW function.
   identifier: 'Simulink:SFunctions:SFcnBlkInvalidParam'
> In SimSetupFig>run_pushbutton_Callback at 1351
  In SimSetupFig at 374
发表于 20-5-2015 23:21:29 | 显示全部楼层
advisor我在matlab7上也无法使用
最好安装一个xp的模拟器、然后安装matlab6.5、方能正常运行
GMT+8, 23-12-2024 14:32 , Processed in 0.521329 second(s), 28 queries .
