  • 1503查看
[Advisor] 求助,advisor安装问题
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    发表于 21-4-2015 11:25:44 | 显示全部楼层 |阅读模式
    安装后,点击continue后,grade options点不动,[SimSetupFig:grade_pushbutton_Callback] Error!
    Cannot find an exact (case-sensitive) match for 'GradeFig'
    The closest match is: gradefig
    in e:\advisor\gui\gradefig.m
    > In SimSetupFig>grade_pushbutton_Callback at 1025
      In SimSetupFig at 374
    点击run后又出现Warning: The MaskInitialization string of block 'BD_PAR/drive cycle <cyc>/repeated cycle grade vs.
    distance' contains usage of mask variables by reference (' @1') instead of by variable name. Support
    for this usage will be removed in a future release
      In gui_run_simulation at 82
      In gui_run at 404
      In SimSetupFig>run_pushbutton_Callback at 1344
    Warning: The MaskInitialization string of block 'BD_PAR/drive cycle <cyc>/repeated cycle speed vs.
    time' contains usage of mask variables by reference (' @1 @1 @2') instead of by variable name. Support
      In gui_run at 404
    Warning: The MaskInitialization string of block 'BD_PAR/drive cycle <cyc>/repeated cycle vehicle cargo
    mass vs. distance' contains usage of mask variables by reference (' @1') instead of by variable name.
    Support for this usage will be removed in a future release
      In gui_run at 404
    Warning: The MaskInitialization string of block 'BD_PAR/drive cycle <cyc>/super-smooth, no-lag trace'
    contains usage of mask variables by reference (' @1') instead of by variable name. Support for this
      In gui_run at 404
    Warning: The MaskInitialization string of block 'BD_PAR/par <vc> config/<vc> par/engine on (parallel
    hybrid)/key_on' contains usage of mask variables by reference (' @1 @1 @2') instead of by variable
    name. Support for this usage will be removed in a future release
      In gui_run at 404
    Warning: The specified delay time for 'BD_PAR/par <vc> config/<vc> par/parallel clutch
    control/Transport Delay' is smaller than the step size of the fixed-step solver. This may cause
    simulation results to be inaccurate. Consider decreasing the step size of the solver to improve
    accuracy
      In gui_run at 404
    Warning: Outport 'BD_PAR/energy storage <ess>/ess config/energy storage <ess>/ess
    tmp/Tair,ave/Tair_ave' and 'BD_PAR/energy storage <ess>/ess config/energy storage <ess>/ess tmp/Tair'
    which are driven by the same signal must have the same setting for the "Output when disabled" parameter
      In gui_run at 404
    [SimSetupFig:run_pushbutton_Callback] Error!
    Error using gui_run_simulation (line 82)
    Error due to multiple causes.
    > In SimSetupFig>run_pushbutton_Callback at 1351
    求大神指点啊
    GMT+8, 21-2-2025 19:41 , Processed in 0.550639 second(s), 31 queries .
