  • 1639查看
SAEJ1939
发表于 3-1-2015 14:46:14 | 显示全部楼层 |阅读模式
CAN通信协议的标准SAEJ1939
SAE J1939_616608KHLIY8.pdf
873.41 KB, 下载次数: 6, 下载积分: 积分 -1
发表于 3-6-2015 16:49:57 | 显示全部楼层
下来瞧瞧  希望有用
    发表于 25-10-2019 17:16:23 | 显示全部楼层
    Issued 2000-04
    Revised 2003-08
    SAE J1939 Revised AUG2003
    1. Scope........................................................................................................................... 3
    1.1 Degree of Openness.....................................................................................................3
    1.2 Proof of Compliance.....................................................................................................3
    2. References.....................................................................................................................3
    2.1 Publications...................................................................................................................3
    2.2 Definitions and Abbreviations.....................................................................................4
    2.2.1 Definitions .....................................................................................................................4
    2.2.2 Abbreviations................................................................................................................7
    2.3 References to the OSI Model:......................................................................................7
    2.4 Documentation Structure and Guide..........................................................................9
    3. Technical Requirements
    10
    3.1 J1939 Tutorial
    10
    3.1.1 Introduction
    10
    3.1.2 Message Format and Usage (J1939/21 for 29 Bit Identifier) ...................................10
    3.1.3 Addresses and NAME (J1939/81 and Appendix B)..................................................12
    3.1.4 Communication Methods ..........................................................................................13
    3.1.5 Transmitting Messages (Using J1939/21 and J1939/7X) ........................................14
    3.1.6 Receiving Messages (Using J1939/21 and J1939/7X)..............................................14
    3.1.7 ECU Design (Using J1939/11, J1939/21, and J1939/7X) 14
    3.1.8 Network Topology ----- J1939/01 Using Physical Layer J1939/11
    and Network Layer J1939/31 .....................................................................................15
    3.2 Preassigned Values ....................................................................................................15
    3.2.1 Parameter Group Numbers .......................................................................................15
    3.2.2 Data Field Grouping ...................................................................................................16
    3.2.3 NAME Systems and Functions..................................................................................16
    3.2.4 Industry Group............................................................................................................17
    3.2.5 Manufacturer Code.....................................................................................................17
    3.2.6 Preferred Address 18
    3.2.7 Suspect Parameter Number (SPN)............................................................................18
    3.3 Application Examples.................................................................................................18
    Appendix A Parameter Group Assignments
    B Address and Identity Assignments
    C Fault Reporting Parameters
    D Assignment Request Forms
    GMT+8, 1-2-2025 12:56 , Processed in 0.793959 second(s), 36 queries .
