TA的每日心情 | 开心 14-3-2018 20:59 |
签到天数: 1 天 [LV.1]初来乍到
我在advisor中修改了insight整车模型后,另存为一个新模型,重新定义了一个新名称并建立好了后台关系。然后调用该模型仿真运行后,遇到报错。哪位前辈帮我看下这个是什么原因造成的以及如何修改。感激。。。
>> advisor
# ADVISOR 2002 April 30, 2002
Data loaded: TC_INSIGHT - Honda Insight Torque Coupling (Hypothetical)
Data loaded: MC_INSIGHT_draft - Preliminary Model of Honda 10 KW (continuous), permanent magnet motor/controller
Data loaded: EX_SI_CC - CLOSE-COUPLED catalyst for ~stoichiometric SI engine
Data loaded: VEH_INSIGHT - Honda Insight 2000
Data loaded: FC_INSIGHT - Honda Insight 1.0L VTEC-E SI Engine from ANL Test Data
Data loaded: ESS_NIMH6 - Spiral Wound NiMH Used in Insight & Japanese Prius
Data Loaded: TX_5SPD_SI_INSIGHT - 5-speed transmission for the Honda Insight
Data loaded: WH_INSIGHT - Wheel/axle assembly for small car (Honda Insight)
Data loaded: PTC_INSIGHT - Model of Honda Insight Control Strategy, 5-spd parallel integrated motor assist hybrid
Data loaded: ACC_INSIGHT - 200-W constant electric load - based on data from the HONDA INSIGHT tests
Data loaded: INIT_CONDS - Standard initial conditions
Data loaded: CYC_UDDS - EPA Urban Dynamometer Driving Schedule
Warning: Matching "Goto" block for "From" block 'BD_insight2/Altia_off/Live Inputs/From<main>1' not found.
Warning: Matching "Goto" block for "From" block 'BD_insight2/Altia_off/Live Inputs/additional/From<fc>3' not found.
Warning: Matching "Goto" block for "From" block 'BD_insight2/Altia_off/Live Inputs/additional/N*m1' not found.
Warning: Matching "Goto" block for "From" block 'BD_insight2/Altia_off/Live Inputs/additional/SubSystem1/ns' not found.
Warning: Matching "Goto" block for "From" block 'BD_insight2/Altia_off/Live Inputs/additional/rad//s1' not found.
Warning: Matching "Goto" block for "From" block 'BD_insight2/Altia_off/Live Inputs/veh/From<veh>6' not found.
Warning: Matching "Goto" block for "From" block 'BD_insight2/drive cycle <cyc>/From' not found.
Warning: Matching "Goto" block for "From" block 'BD_insight2/drive cycle <cyc>/From1' not found.
Warning: Matching "From" block for "Goto" block 'BD_insight2/<cs>' not found.
Warning: Matching "From" block for "Goto" block 'BD_insight2/Altia_off/Live Inputs/misc/Goto' not found.
Warning: Matching "From" block for "Goto" block 'BD_insight2/energy storage <ess>/ess config/energy storage <ess>/Goto <cs>' not found.
Warning: Matching "From" block for "Goto" block 'BD_insight2/energy storage <ess>/ess config/energy storage <ess>/Goto <cs>1' not found.
Warning: Matching "From" block for "Goto" block 'BD_insight2/energy storage <ess>/ess config/energy storage <ess>/Goto <cs>2' not found.
Warning: Matching "From" block for "Goto" block 'BD_insight2/fuel converter <fc>/Goto' not found.
Warning: Matching "From" block for "Goto" block 'BD_insight2/wheel and axle <wh>/Goto' not found.
Warning: Unconnected input line found on block 'BD_insight2/fuel converter <fc>/fc_clt' (input port: 1). |
