  • 714查看
求高手帮我修改一下81行的内容,感激不尽,小弟的毕业设计
发表于 6-5-2013 10:31:39 | 显示全部楼层 |阅读模式
clear all
%z增加视频的录入并转化为可用的bmp图片文件
figure(1)
%读懂程序改为能够统计自己采集视频中车辆的数目
top_x=[8,97,174,246,280];
top_y=[134,141,144,147,150];
rect.lx=0;
rect.ly=59;
rect.width = 280;
rect.height=103;
host_num=0;
host_regions=zeros(1,13);
global v_order;
v_order=1;
esm_num=0;
esm_regions=zeros(1,6);
%c_match=zeros(1,4);
%c_center=zeros(1,12);
dt=0.12;
BWG=imread('1.bmp');
figure(2);
imshow(BWG);
j=0;
for i=1:1:120
     open_filename='';
     o=num2str(i);
     open_filename=strcat(open_filename,o,'.bmp');
     CBW=imread(open_filename);
    figure(3);
        subplot(221);
      imshow(CBW);hold on;
      % size(CBW) 120   160     3
      SBW=abs(double(CBW)-double(BWG));
      SBW=uint8(SBW);
      BW2=im2bw(SBW,0.15);
      MBW=medfilt2(BW2);
        subplot(222);
     imshow(MBW);hold on;
     %%%%jsx增加一个小区域
     %%%%根据自己车道的位置来调整
     %修改点1
     lefttopx=96;
     lefttopy=160;
       rightbottomx=120;
    rightbottomy=96;
     smallarea=MBW(lefttopx:rightbottomx,lefttopy:rightbottomy);
        subplot(223);
     imshow(smallarea); hold on;
     %j=(i-997)/3;
     j=i;
     smallareavalue(j,:,:)=smallarea; %上述数据可以用来判别是否有车辆通过
      subplot(222)
      %正好与画像素图的x和y相反
    A=[lefttopy,lefttopy,rightbottomy,rightbottomy,lefttopy;lefttopx,rightbottomx,rightbottomx,lefttopx,lefttopx];
    plot(A(1,:),A(2,:),'m');
    %axis ([0 14 0 14])
        %%%%jsx  end
      BWG=(0.01*double(CBW)+0.99*double(BWG)).*double(MBW)+(0.1*double(CBW)+0.9*double(BWG)).*double(~MBW);
      BWG=uint8(BWG);
        subplot(224)
        imshow(BWG);
   delete=zeros(host_num,1);
             count=0;
             for k=1:host_num
                 if host_regions(k,7)<20
                     delete(k)=1;
                     count=count+1;
                 end
             end
             temp_host=zeros(1,13);
             index=1;
            for k=1:host_num
                 if  delete(k)==0
                     temp_host(index,:)=host_regions(k,:);
                     index=index+1;
                 end
            end
          host_regions=temp_host;
          host_num=host_num-count;
        %  c_match=zeros(1,4);
         % c_num=0;
          if  host_num==0
              init_num=0;
              init_center=zeros(1,2);
            %  c_num=0;c_match=zeros(1,4);
              [c_num,c_match]=Zcluster(init_num,init_center,MBW,rect);
          else
              for k=1:host_num
                  init_center(k,1)=host_regions(k,7);
                  init_center(k,2)=host_regions(k,8);
              end
              init_num=host_num;
          end
       for j=1:c_num
           hold on
           figure(3);
           plot(c_match(j,3),c_match(j,4),'g.')
       end
          point=j;
            measured=zeros(c_num,1);
            if c_num~=0
              if c_num>host_num
                for  k=1:c_num
                    if c_match(k,1)==0&&c_match(k,2)==0
%                        if  c_match(k,3)<20
  %                           measured(k)=1;
  %                      else
                            if abs(c_match(k,3)-270)<30
                       %          if esm_num==0
                                 esm_regions(1,1)=c_match(k,3);
                                 esm_regions(1,2)=c_match(k,4);
                                 esm_regions(1,3)=0;
                                 esm_regions(1,4)=0;
                                 esm_regions(1,5)=0;
                                 esm_regions(1,6)=0;
                              %   esm_num=esm_num+1;
                                 measured(k)=1;
                                 else if esm_num==1
                                        esm_regions(1,3)=(c_match(k,3)-esm_regions(1,1))/dt;
                                        esm_regions(1,4)=(c_match(k,4)-esm_regions(1,2))/dt;
                                        esm_regions(1,5)=0;
                                        esm_regions(1,6)=0;
                                        esm_num=esm_num+1;
                                        measured(k)=1;
                                     else
                                         temp_vx=esm_regions(1,3);
                                         temp_vy=  esm_regions(1,4);
                                         esm_regions(1,5)=(esm_regions(1,3)-temp_vx)/dt;
                                         esm_regions(1,6)=(esm_regions(1,4)-temp_vy)/dt;
                                         measured(k)=1;
                                     end
                                 end
                             end
                                         rem_host=kkghr(esm_regions,v_order);
                                         host_num=host_num+1;
                                         host_regions(host_num,:)=rem_host;
                                         v_order=v_order+1;
                                     %      hold on
                                       %    plot(host_regions(host_num,1),host_regions(host_num,2),'g.')
                     end
                                         esm_num=0;
                end
              end
            end
            for j=1:c_num
                    hold on
                    plot(host_regions(j,1),host_regions(j,2),'g.')
            end
       for j=1:c_num
           hold on
      end
        host_regions=kkghr2(c_match,measured,host_regions);
  %       hold on
   %   plot(host_regions(1,1),host_regions(1,2),'g.')
   for j=1:c_num
           hold on
     end
        for j=1:c_num
                      hold on;
                    plot(host_regions(j,1),host_regions(j,2),'g.') ;
        end
        for j=1:c_num
            plot(host_regions(j,7),host_regions(j,8),'r.');
        end
       pause(0.01);
end
%%%%jsx add 实现车辆计数
for l=1:size(smallareavalue,1)
    pxelnum=0;
      for m=1:size(smallareavalue,2)
          for n=1:size(smallareavalue,3)
      if smallareavalue(l,m,n)==1
   pxelnum=pxelnum+1;
      end
          end
      end
      flag(l)=pxelnum;
end
figure(4);
plot( flag,'-o');
title('这个值可以用来确定车辆数目;车型等;标定后可以求车速...');
carnum=0;
for i=1:size(flag,2)-1
    if flag(1,i)==0 && flag(1,i+1)>0
        carnum=carnum+1;
    end
end
carnum
%%%%end
 楼主| 发表于 6-5-2013 10:34:12 | 显示全部楼层
发现这边没有行数,第81行就是BWG=(0.01*double(CBW)+0.99*double(BWG)).*double(MBW)+(0.1*double(CBW)+0.9*double(BWG)).*double(~MBW);
感激不尽,求帮忙
GMT+8, 30-10-2025 23:49 , Processed in 0.449766 second(s), 34 queries .
