求adams齿轮冲击仿真案例。我折腾了一周了,定义了驱动,负载,冲击接触,然后运行动力学仿真,但仿真时总是提示:WARNING: The data set is kinematically determinate. However, a dynamic analysishas been requested. A kinematic analysis with the SIMULATE/KINEMATICS command would be more efficient and possibly more accurate for some of the computed quantitiesAs requested, the simulation will continue with a dynamic analysis.最后查看结果速度没有波动,是恒定的。求大神解惑呀
