  • 2151查看
  • 7回复
[求助] 汽车空气滤清器(无纺布滤芯)设计标准
发表于 9-3-2013 15:24:42 | 显示全部楼层 |阅读模式
我现在在设计一款空滤器滤芯,是采用无纺布的,我就是想知道关于这个过滤面积怎么计算?谁有无纺布滤芯的一些设计技术标准,谢谢!
发表于 14-3-2013 23:54:58 | 显示全部楼层
JB/T  9756
发表于 15-3-2013 00:27:47 | 显示全部楼层
以下的资料足够你设计出好的滤清器了
Air Filter Flow Calculations
Chuck Leeper with permission from K&N Introduction
Below is a series of formulas to determine air filter size for a given air flow capacity. Chuck was trouble shooting a problem when he found that air flow he needed was more than his 9" filter could provide. K&N shared this information with him to help trouble shoot his problem.
Formulas
Square inches of filter required for a motor = CID x Maximum RPM / 20839
CFM required for a 4 stroke motor = CID x Maximum RPM / 3456
CFM required for a 2 stroke motor = CID x Maximum RPM / 1728
CFM required for a turbocharged or supercharged motor = Pounds of Boost / 14.7
Add 1.0 to this answer. This relates to #2 and #3
Example: (CID x maximum RPM x #4 ) / 3456 or 1728
To find circumference of a circle multiply diameter by 3.1416
To find diameter of a circle multiply circumference by .31831
CFM Formulas for Filters
Round: Diameter x Height x 6 x 3.14
Flat Panel: Length x Width x 6
Universal Round Taper: (Base + Top) / 2 = A
Take A x Length x 6 x 3.14
Universal Round Straight: Diameter x Length x 6 x 3.14
发表于 28-3-2013 12:55:48 | 显示全部楼层
技术就是力量 发表于 15-3-2013 00:27
以下的资料足够你设计出好的滤清器了
Chuck Leeper with permission from  ...
哥们咱有没有中文的啊 看不懂
 楼主| 发表于 1-4-2013 09:19:57 | 显示全部楼层
有没有中文的啊 谢谢,翻译又翻译不到位!
发表于 2-4-2013 21:15:31 | 显示全部楼层
为什么复制不了呢
发表于 13-4-2013 11:34:17 | 显示全部楼层
先收藏,以后可能用的到
  • 签到天数: 4 天
    发表于 30-9-2016 16:13:47 | 显示全部楼层
    先收藏一下,英文后续再翻译吧
    GMT+8, 29-6-2026 20:22 , Processed in 0.508273 second(s), 40 queries .
