  • 1020查看
2007丰田雅力士YARIS电路图册
发表于 22-1-2013 18:39:19 | 显示全部楼层 |阅读模式
2007丰田雅力士YARIS电路图册
This manual consists of the following 13 sections:
No. Section Description
A
INDEX Index of the contents of this manual.
INTRODUCTION Brief explanation of each section.
B HOW TO USE THIS
MANUAL Instructions on how to use this manual.
C TROUBLE–
SHOOTING Describes the basic inspection procedures for electrical circuits.
D ABBREVIATIONS Defines the abbreviations used in this manual.
E
GLOSSARY OF
TERMS AND
SYMBOLS
Defines the symbols and functions of major parts.
F RELAY LOCATIONS Shows position of the Electronic Control Unit, Relays, Relay Block, etc.
This section is closely related to the system circuit.
G ELECTRICAL
WIRING ROUTING
Describes position of Parts Connectors, Splice points, Ground points, etc.
H
INDEX Index of the system circuits.
SYSTEM CIRCUITS
Electrical circuits of each system are shown from the power supply through ground
points. Wiring connections and their positions are shown and classified by code
according to the connection method. (Refer to the section, ”How to use this manual”).
The ”System Outline” and ”Service Hints” useful for troubleshooting are also contained
in this section.
I GROUND POINT Shows ground positions of all parts described in this manual.
J POWER SOURCE
(Current Flow Chart) Describes power distribution from the power supply to various electrical loads.
K CONNECTOR LIST Describes the form of the connectors for the parts appeared in this book.
L PART NUMBER OF
CONNECTORS Indicates the part number of the connectors used in this manual.
M
OVERALL
ELECTRICAL
WIRING DIAGRAM
Provides circuit diagrams showing the circuit connections.
YARIS (EM01V0U)
3
HOW TO USE THIS MANUAL B
This manual provides information on the electrical circuits installed on vehicles by
dividing them into a circuit for each system.
The actual wiring of each system circuit is shown from the point where the power
source is received from the battery as far as each ground point. (All circuit
diagrams are shown with the switches in the OFF position.)
When troubleshooting any problem, first understand the operation of the circuit
where the problem was detected (see System Circuit section), the power source
supplying power to that circuit (see Power Source section), and the ground points
(see Ground Point section). See the System Outline to understand the circuit
operation.
When the circuit operation is understood, begin troubleshooting of the problem
circuit to isolate the cause. Use Relay Location and Electrical Wiring Routing
sections to find each part, junction block and wiring harness connectors, wiring
harness and wiring harness connectors and ground points of each system circuit.
Internal wiring for each junction block is also provided for better understanding of
connection within a junction block.
Wiring related to each system is indicated in each system circuit by arrows
(from__, to__). When overall connections are required, see the Overall Electrical
Wiring Diagram at the end of this manual.
2007丰田雅力士YARIS电路图册.part1.rar
976.56 KB, 下载次数: 0, 下载积分: 积分 -1
2007丰田雅力士YARIS电路图册.part2.rar
2007丰田雅力士YARIS电路图册.part3.rar
2007丰田雅力士YARIS电路图册.part4.rar
2007丰田雅力士YARIS电路图册.part5.rar
183.38 KB, 下载次数: 0, 下载积分: 积分 -1
GMT+8, 23-2-2025 09:53 , Processed in 0.500735 second(s), 39 queries .
