  • 2472查看
【求助】catia用vb用点生成球的代码
  • 签到天数: 8 天
    发表于 2-9-2012 11:22:23 | 显示全部楼层 |阅读模式
    catia里车身焊点比较多,画完点有时候要生成球。
    以前用过这样的代码,现在没有了。
    希望有人能将该代码发一下,万分感谢!
    发表于 12-10-2012 15:58:16 | 显示全部楼层
    期待高手!!!
    20-7-2015 20:39
    发表于 10-6-2013 17:28:57 | 显示全部楼层
    Sub CATMain()
    dim aaa as document
    set aaa = catia activedocument
    Dim partDocument1 As PartDocument
    Set partDocument1 = CATIA.ActiveDocument
    Dim part1 As Part
    Set part1 = partDocument1.Part
    Dim hybridShapeFactory1 As HybridShapeFactory
    Set hybridShapeFactory1 = part1 HybridShapeFactory
    Dim hybridBodies1 As HybridBodies
    Set hybridBodies1 = part1 Hybridbodies
    Dim hybridShapes1 As HybridShapes
    Set hybridShapes1 = HybridBody1 HybridShapes
    Dim selection As selection
    Set oSel = partDocument1 Selection
    Dim InputObjectType(0)
    InputObjectType(0) = "Point"
         Status = oSel.SelectElement3(InputObjectType,"框选焊点",True,1,True)
         If (Status = "Cancel")Then
             oSel Clear Exit Sub
         End If
    for i=1 to oSel count
    Dim hybridShapePointExplicit1 As Parameter
    Set hybridShapePointExplicit1 = oSel Item(i)
    Dim reference1 As Reference
    Set reference1 =oSel Item(i) value
    Dim hybridShapeSphere1 As HybridShapeSphere
    Set hybridShapeSphere1 = hybridShapeFactory1 AddNewSphere(referencel,Nothing,6.000000,-45.000000,45.000000,0.000000,180.000000)
    hybridShapeSphere1 limitation = 1
    hybridBody1 AppendHybridShape hybridShapeSphere1
    part1 InWorkObject = hybridShapeSphere1
    next
    part1 Update
    End Sub
    难过
    31-7-2016 06:17
  • 签到天数: 8 天
    发表于 23-8-2013 01:15:34 | 显示全部楼层
    类似二次开发了啊
  • 签到天数: 8 天
     楼主| 发表于 23-4-2014 21:31:20 | 显示全部楼层
    3楼的代码比较繁琐,而且运行不了。第二行就出现错误。
    今天编辑多次,运行多次,终于成功了
    代码如下:
    Sub CATMain()
    Dim odoc, opart, ohbodies, ohbody, ohybridshapefactory, oshere, oselection, status, pointreference
    Dim i, inputtype(0)
    CATIA.Visible = True
    Set odoc = CATIA.ActiveDocument
    Set opart = odoc.Part
    Set ohbodies = opart.HybridBodies
    Set ohbody = ohbodies.Add()
    ohbody.Name = ohbody.Name & "(sphere)"
    Set oselection = odoc.Selection
    Set ohybridshapefactory = opart.HybridShapeFactory
    For i = 1 To oselection.Count
        Set pointreference = opart.CreateReferenceFromObject(oselection.Item(i).Value)
        Set osphere = ohybridshapefactory.AddNewSphere(pointreference,Nothing,3,-45,45,-180,180)
        osphere.Limitation = 1
        ohbody.AppendHybridShape osphere
    Next
    opart.Update
    End Sub
    首先要选取点
    发表于 23-5-2015 18:19:23 | 显示全部楼层
    今天编辑多次,运行多次,终于成功了
    立马去试试
    GMT+8, 23-2-2025 12:02 , Processed in 0.459350 second(s), 40 queries .
