  • 2368查看
  • 7回复
世界500强德企招聘Design Engineer
发表于 9-8-2012 10:22:05 | 显示全部楼层 |阅读模式
ACCOUNTABILITY OBJECTIVE:
Accountable for providing cost-effective robust product designs that meet the customer specification.
PRINCIPAL ACCOUNTABILITIES:
1.        This position has minor direct supervision requirements; it is intended to be the primary source for all Product Design and Development.
2.        Ensure that the product design meets the intended function defined by the customer specification.
3.        Ensure that the base-level mechanical, electrical, magnetic, and hydraulic physics are understood, modeled, and validated for the product design.
4.        Ensure that a thorough and accurate DFMEA is prepared early in the development process.
5.        Ensure that accurate tolerance stack-ups are prepared both for dimensional and geometric tolerances.
6.        Ensure that the product design meets the cost target set forth by the customer.
7.        Ensure that the materials used in the product design are appropriate for the application and do not violate any customer requirements.
8.        Direct the activities of the Development Technician and ensure that they are properly trained to do an effective job.
9.        Ensure that the Account Manager, Mfg. Engineer, and Quality Engineer are involved early in the development process.
10.        Ensure that DFM and DFA techniques are employed early in the development process.
11.        Plan and Execute Design of Experiments (DOE) as necessary to support root-cause analysis.
12.        Analyze test data to determine if design meets functional and performance specifications.
13.        Work closely with Electronics Test, Hydraulics Test, and Software Test Engineers to ensure that all aspects of Test Development are in agreement with Customer Specification.
14.        Perform other duties as assigned from manager.
PRINCIPAL WORKING RELATIONSHIPS:
Key Internal Relationships:                Engineering Manager
                                        CAD Designers
Test Engineer: Hardware
                                        Test Engineer: Software
                                        Development Technicians
                                        Validation Technicians
Project Engineer
                                        Quality Engineers
                                        Manufacturing Engineers
Key External Relationships:                Customer Design Release Engineers
                                        Analysis Software Applications Engineers
 楼主| 发表于 9-8-2012 14:27:53 | 显示全部楼层
没有人感兴趣吗?这是一个德资企业,生产汽车用电磁阀的。
  • 签到天数: 8 天
    发表于 9-8-2012 14:55:01 | 显示全部楼层
    要求太高了
     楼主| 发表于 9-8-2012 15:44:32 | 显示全部楼层
    这里不是有很多高手吗?要求高,待遇也好啊。
    发表于 9-8-2012 22:33:02 | 显示全部楼层
    公司地点在常熟吧!
     楼主| 发表于 10-8-2012 09:22:25 | 显示全部楼层
    fdj 发表于 9-8-2012 22:33
    公司地点在常熟吧!
    是的,在常熟。。
    发表于 17-8-2012 14:13:44 | 显示全部楼层
    哎  为什么老是用英文呢  这是在中国
    发表于 17-8-2012 19:34:14 | 显示全部楼层
    great。。。。。。。。。。。。。
    GMT+8, 11-7-2026 08:57 , Processed in 0.572459 second(s), 43 queries .
