  • 3764查看
  • 23回复
[求助] 由设计人员转向产品工程师如何??
发表于 10-4-2012 00:54:43 | 显示全部楼层 |阅读模式
本人原本在一家设计院负责内饰设计的,混了两年后感觉除了会建模外(建模速度也一般)其余都不会,现在跳槽去主机厂做内饰件产品工程,主要负责新车型导入、试制和供应商管理这一块,个人的打算是学习几年后再转回设计的,就是不知道以后再转回设计的话有没有可能,会不会简单点?
发表于 11-4-2012 11:18:09 | 显示全部楼层
再转回设计是有可能的
为什么要转呢,我觉得产品工程师更好
发表于 23-7-2012 17:43:02 | 显示全部楼层
产品工程师是一个很有前途的职业。基本上他是一个工程师在一定沉淀以后的一个可选择的发展方向。如果你真的不喜欢做研发类的工程师,产品工程师是一个可以考虑的选择。
发表于 17-10-2012 19:35:02 | 显示全部楼层
其实你做了两年设计,现在转成产品工程师那是最好的,不知道你为什么还要做回设计呢?你现在有了一定的设计经验,应该比那些刚毕业的大学生直接做产品的要有优势,懂得如何从设计的角度去避免产品问题,也更能去分析一些由于设计而产生的产品问题。你应该一方面把你的设计不要拉下,另一方面扩从产品方面的知识,比如装配、公差、模具工艺、材料等等,这样你做起产品来就比较得心应手了。
发表于 30-10-2012 13:00:23 | 显示全部楼层
产品工程师更有挑战,除了跟电脑打交道,还要面对工厂、供应商、路试、试验等各方面,如果你不属于能潜心做研发的学院派,有进取心、抗压能力强,设计转产品是很正确的选择。
发表于 31-10-2012 11:44:25 | 显示全部楼层
Normally speaking the path is:
Designer in Supplier;
Product engineer in Supplier or Quality Engineer in supplier;
Then you can decide where to go, to OEM for PE or stay in Supplier for PM;
If you want to OEM then can be PE;
Then you can decide to be Viehcle system Engineer or group leader in OEM or in Supplier site for PM;
Then you can be PM in OEM or supplier for PM;
发表于 31-10-2012 11:45:32 | 显示全部楼层
Normally speaking to be PM is the promising path for Engineer, but need change a lot for personality or you were born with PM personality.
发表于 31-10-2012 11:52:44 | 显示全部楼层
PM means: following aspects should be strong:
1, Cooperation;
2, Communication, which is very important and will take 70% duty of PM. This is very important and very difficult. By survey 70% of failed projects because of faulty communication;
3,Problem solving skill, which is based on your engineering experience and you systematic thinking and skill. Really need your Zusammenfassen(只能用德文了,忘了英文怎么说了)in daily work and life. Also need your very carefully observe the thing going.
4, Foreign language skill, at least grasp 1 foreign language, 2 are better.
5, Fast learning skill, which means you should very soon adapt to new environment or field, and you should be very quick to find the right source or resource to know the knowledge or the ways to do.
发表于 31-10-2012 11:57:55 | 显示全部楼层
6, You'd better to make a dairy book to write down all work down then at night can review and learn somewhere you can be better;
7, As PM, you should be healthy, because the job is tough;
8, You should be very proactive, means you should actively know where is the risk, from interpersonal speaking and the project, and try to make contengency plan for it.
9, Also PM should also can encourage team members. The persons will not follow a guy, who complain much and can not cheer others up, although maybe the project situation is not good in deed.
发表于 31-10-2012 13:10:17 | 显示全部楼层
but even you want to be Interior design director, to be honest, also need not know much about all the component design etc. More is how to manage your time and people, and how to make the things done.
参与人数 1贡献值 +2 积分 +12 收起 理由
清雅轩 + 2 + 12 回帖有奖【论坛口号→知无不言,言无不尽】
发表于 31-10-2012 13:12:33 | 显示全部楼层
I suggest you can have a look of the book named"brain map", which will tell you a way to analyze how to get to your goal and analyze yourself.
发表于 31-10-2012 13:15:00 | 显示全部楼层
知人者智,自知者明
发表于 31-10-2012 13:15:50 | 显示全部楼层
also for a human being, work and life is balance. It is hard but need to do.
发表于 29-12-2012 11:18:51 | 显示全部楼层
it is wonderful what you say
  • 签到天数: 10 天
    发表于 10-10-2013 17:07:51 | 显示全部楼层
    做研发工程师很考验你的自我管理能力,学习能力、职业规划。因为这个岗位可以很闲,整天上网,没事干,活都被别人干了;也可以很忙,搞各种报表。没有明确的目标和毅力,待在这个岗位就是浪费时间。
    GMT+8, 24-2-2025 10:09 , Processed in 1.564160 second(s), 52 queries .
