  • 2021查看
  • 9回复
[Advisor] 求助 advisor电机模型 m文件出错了
发表于 2-4-2012 15:02:50 | 显示全部楼层 |阅读模式
mc_description='Solectria ACgtx20/AC300 AC induction motor/controller';
mc_version=2002;
mc_proprietary=0;  % 0=> public data, 1=> restricted access, see comments above
mc_validation=0; % 0=> no validation, 1=> data agrees with source data,
% 2=> data matches source data and data collection methods have been verified
disp(['Data loaded: MC_AC25 - ',mc_description]);
% TORQUE AND SPEED ranges
% N-m, torque vector corresponding to columns of efficiency & loss maps
mc_map_trq=[-84 -70 -56 -42 -28 -14 0 14 28 42 56 70 84];
% rad/s, speed vector corresponding to rows of efficiency & loss maps
mc_map_spd=[0 500 1000 1500 2000 2500 3000 3500 3800]*(2*pi)/60;
% LOSSES AND EFFICIENCIES
mc_eff_map =[ 0.593 0.65 0.683 0.729 0.764 0.1 0.807 0.785 0.754 0.73 0.708
             0.769 0.82 0.843 0.887 0.912 0.1 0.937 0.914 0.88 0.853 0.828
             0.875 0.874 0.903 0.918 0.927 0.1 0.941 0.935 0.933 0.92 0.908
             0.903 0.914 0.921 0.927 0.911 0.1 0.939 0.948 0.945 0.939 0.931
             0.915 0.924 0.931 0.931 0.925 0.1 0.933 0.95 0.954 0.948 0.943
             0.914 0.921 0.932 0.93 0.916 0.1 0.932 0.961 0.958 0.951 0.943
             0.91 0.91 0.894 0.93 0.901 0.1 0.928 0.955 0.954 0.937 0.937
             0.908 0.908 0.909 0.921 0.883 0.1 0.911 0.939 0.94 0.939 0.939
             0.897 0.897 0.897 0.903 0.868 0.1 0.89 0.922 0.922 0.922 0.922];
% CONVERT EFFICIENCY MAP TO INPUT POWER MAP
%% find indices of well-defined efficiencies (where speed and torque > 0)
pos_trqs=find(mc_map_trq>0);
pos_spds=find(mc_map_spd>0);
%% compute losses in well-defined efficiency area
[T1,w1]=meshgrid(mc_map_trq(pos_trqs),mc_map_spd(pos_spds));
mc_outpwr1_map=T1.*w1;
mc_losspwr_map=(1./mc_eff_map(pos_spds,pos_trqs)-1).*mc_outpwr1_map;
显示最后一行有错误 谁能告诉我 怎么错了
??? Index exceeds matrix dimensions.
Error in ==> D:\Matlab6p5FULL\advisor2002\data\motor\MC_AC25_HK.m
On line 60  ==> mc_losspwr_map=(1./mc_eff_map(pos_spds,pos_trqs)-1).*mc_outpwr1_map;
发表于 3-4-2012 12:24:29 | 显示全部楼层
在计算电机损失的时候可能矩阵出错,提示说超过了最大矩阵维度!
发表于 3-4-2012 12:27:33 | 显示全部楼层
再者,从我对你的转速转矩和效率的数据上看,你的矩阵维度不对,转矩是1X13的,转速是1X9的,然后效率呢,你自己看看,内部模块查表需要匹配的,你需要有13X9的效率数据!
发表于 3-4-2012 12:28:31 | 显示全部楼层
修改看看!
 楼主| 发表于 3-4-2012 13:15:26 | 显示全部楼层
scofision 发表于 3-4-2012 12:28
修改看看!
只需要把效率数据改成 13X9的格式么?
 楼主| 发表于 3-4-2012 13:22:54 | 显示全部楼层
修改看看!
还有 想问下您 内部效率表是怎么得来的呢?是计算的?还是查表?
发表于 3-4-2012 16:03:23 | 显示全部楼层
你觉得呢,试验的来的
发表于 19-4-2012 13:46:34 | 显示全部楼层
请问,如果我有电机的DATASHEET,表上面能看见么?
发表于 10-5-2012 12:51:42 | 显示全部楼层
来看看,看不懂
发表于 27-6-2012 12:24:39 | 显示全部楼层
大家知道怎样在M文件里面看电机的额定功率和最大功率呢
GMT+8, 23-12-2024 08:52 , Processed in 0.230690 second(s), 27 queries .
