  • 2723查看
[Star-CD] calculation stops and BICGStab did not converge
发表于 6-3-2012 09:49:26 | 显示全部楼层 |阅读模式
When I try to run the calculation, it failed and the output is as below, who has met this problem and solved it?
BiCGStab did not converge !
* CFL 5.00000e+00 -> 5.00000e-01...
A floating point exception has occurred: floating point exception [Invalid operation]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide.
Command: RunSimulation
CompletedCommand: RunSimulation
In: [Machine::main, SimulationIterator::startSimulation, SteadySolver::step]
error: Server Error
GMT+8, 24-2-2025 00:16 , Processed in 0.567346 second(s), 34 queries .
