TA的每日心情 | 无聊 10-1-2016 13:38 |
签到天数: 2 天 [LV.1]初来乍到
US703 scanner and make it work with major European, USA and French car makes! Addtional file CD and instructions provided to add other car makes to this US703 scanner!
That means you will have a code reader for following car makes:
BMW, Chrysler, Citroen, Ford, GM, Honda, Mazda, Mercedes, Mitsubishi, Nissan, Opel, Peugeot, Renault, Toyota, Volvo, VW.
Features
•Troubleshoot and clearEngine,Transmission, Airbag, and ABSfailures
for major USA vehicles (Chrysler, Ford & GM)
•Global OBD II/EOBD coverage(US, Asian & European)
•Turn off engine, transmission, ABS, airbag warning lights
•Support all nine test modes of the latest J1979 OBD II test specs, including Read Codes, Erase Codes, Live Data, Freeze Frame, I/M Readiness, O2 Mon.Test, On-Board Mon.Test, Component Test and Vehicle Information
•OBD II repair information
•Display DTC definitions on unit screen
•Retrieve ECU information (VIN, CIN and CVN)
•Data graphing
•Read, store & playback live data
•CAN enabled with no adapters to buy
•Memory/battery backup for off-vehicle data review and analysis
•Extremely easy to use and highly reliable
•Software upgradeable via internet
•Print data via PC-link
•Screen display support multi language including English, Spainish, Deutsch, French and Dutch
The standard package of this code reader only provide OBD2 16 PIN connector, so please check whether your vehicle has OBD2 16 pin diagnostic plug. If it has a different shape of diagnostic plug, please contact us before you make the purchase.
Package Includes
•US703 Code Reader
•OBD II connector
•Extension cable
•USB cable (connect to computer for software upgrade)
•CD software (PC-LINK)
•User's Manual
•Nylon carry case
•Additional file CD to add other car makes to this scanner |
