  • 18952查看
Abaqus 如何将两个部件固连到一起啊?
发表于 19-11-2011 09:36:36 | 显示全部楼层 |阅读模式
我用tie连接,好像提示自由度没有限制住。 .msg文件如下。  哪位大侠帮忙指点一下啊!多些了!
1
   Abaqus 6.9-3                                  Date 21-Mar-2010   Time 09:14:22
   For use by TEAM TBE under license from Dassault Systemes or its subsidiary.
STEP    1     INCREMENT     1     STEP TIME    0.00
                        S T E P       1     S T A T I C   A N A L Y S I S
     AUTOMATIC TIME CONTROL WITH -
          A SUGGESTED INITIAL TIME INCREMENT OF                 1.00
          AND A TOTAL TIME PERIOD OF                            1.00
          THE MINIMUM TIME INCREMENT ALLOWED IS                1.000E-05
          THE MAXIMUM TIME INCREMENT ALLOWED IS                 1.00
     LINEAR EQUATION SOLVER TYPE         DIRECT SPARSE
CONVERGENCE TOLERANCE PARAMETERS FOR FORCE
     CRITERION FOR RESIDUAL FORCE     FOR A NONLINEAR PROBLEM          5.000E-03
     CRITERION FOR DISP.    CORRECTION IN A NONLINEAR PROBLEM          1.000E-02
     INITIAL VALUE OF TIME AVERAGE FORCE                               1.000E-02
     AVERAGE FORCE     IS TIME AVERAGE FORCE
     ALTERNATE CRIT. FOR RESIDUAL FORCE     FOR A NONLINEAR PROBLEM    2.000E-02
     CRITERION FOR ZERO FORCE     RELATIVE TO TIME AVRG. FORCE         1.000E-05
     CRITERION FOR RESIDUAL FORCE     WHEN THERE IS ZERO FLUX          1.000E-05
     CRITERION FOR DISP.    CORRECTION WHEN THERE IS ZERO FLUX         1.000E-03
     CRITERION FOR RESIDUAL FORCE     FOR A LINEAR INCREMENT           1.000E-08
     FIELD CONVERSION RATIO                                             1.00
     CRITERION FOR ZERO FORCE     REL. TO TIME AVRG. MAX. FORCE        1.000E-05
     CRITERION FOR ZERO DISP.    RELATIVE TO CHARACTERISTIC LENGTH     1.000E-08
CONVERGENCE TOLERANCE PARAMETERS FOR MOMENT
     CRITERION FOR RESIDUAL MOMENT    FOR A NONLINEAR PROBLEM          5.000E-03
     CRITERION FOR ROTATION CORRECTION IN A NONLINEAR PROBLEM          1.000E-02
     INITIAL VALUE OF TIME AVERAGE MOMENT                              1.000E-02
     AVERAGE MOMENT    IS TIME AVERAGE MOMENT
     ALTERNATE CRIT. FOR RESIDUAL MOMENT    FOR A NONLINEAR PROBLEM    2.000E-02
     CRITERION FOR ZERO MOMENT    RELATIVE TO TIME AVRG. MOMENT        1.000E-05
     CRITERION FOR RESIDUAL MOMENT    WHEN THERE IS ZERO FLUX          1.000E-05
     CRITERION FOR ROTATION CORRECTION WHEN THERE IS ZERO FLUX         1.000E-03
     CRITERION FOR RESIDUAL MOMENT    FOR A LINEAR INCREMENT           1.000E-08
     CRITERION FOR ZERO MOMENT    REL. TO TIME AVRG. MAX. MOMENT       1.000E-05
     VOLUMETRIC STRAIN COMPATIBILITY TOLERANCE FOR HYBRID SOLIDS       1.000E-05
     AXIAL STRAIN COMPATIBILITY TOLERANCE FOR HYBRID BEAMS             1.000E-05
     TRANS. SHEAR STRAIN COMPATIBILITY TOLERANCE FOR HYBRID BEAMS      1.000E-05
     SOFT CONTACT CONSTRAINT COMPATIBILITY TOLERANCE FOR P>P0          5.000E-03
     SOFT CONTACT CONSTRAINT COMPATIBILITY TOLERANCE FOR P=0.0         0.100
     CONTACT FORCE ERROR TOLERANCE FOR CONVERT SDI=YES                 1.00
     DISPLACEMENT COMPATIBILITY TOLERANCE FOR DCOUP ELEMENTS           1.000E-05
     ROTATION COMPATIBILITY TOLERANCE FOR DCOUP ELEMENTS               1.000E-05
EQUILIBRIUM WILL BE CHECKED FOR SEVERE DISCONTINUITY ITERATIONS
TIME INCREMENTATION CONTROL PARAMETERS:
     FIRST EQUILIBRIUM ITERATION FOR CONSECUTIVE DIVERGENCE CHECK              4
     EQUILIBRIUM ITERATION AT WHICH LOG. CONVERGENCE RATE CHECK BEGINS         8
     EQUILIBRIUM ITERATION AFTER WHICH ALTERNATE RESIDUAL IS USED              9
     MAXIMUM EQUILIBRIUM ITERATIONS ALLOWED                                   16
     EQUILIBRIUM ITERATION COUNT FOR CUT-BACK IN NEXT INCREMENT               10
     MAXIMUM EQUILIB. ITERS IN TWO INCREMENTS FOR TIME INCREMENT INCREASE      4
     MAXIMUM ITERATIONS FOR SEVERE DISCONTINUITIES                            50
     MAXIMUM CUT-BACKS ALLOWED IN AN INCREMENT                                 5
     MAXIMUM DISCON. ITERS IN TWO INCREMENTS FOR TIME INCREMENT INCREASE      50
     MAXIMUM CONTACT AUGMENTATIONS FOR *SURFACE BEHAVIOR,AUGMENTED LAGRANGE    6
     CUT-BACK FACTOR AFTER DIVERGENCE                                 0.2500
     CUT-BACK FACTOR FOR TOO SLOW CONVERGENCE                         0.5000
     CUT-BACK FACTOR AFTER TOO MANY EQUILIBRIUM ITERATIONS            0.7500
     CUT-BACK FACTOR AFTER TOO MANY SEVERE DISCONTINUITY ITERATIONS   0.2500
     CUT-BACK FACTOR AFTER PROBLEMS IN ELEMENT ASSEMBLY               0.2500
     INCREASE FACTOR AFTER TWO INCREMENTS THAT CONVERGE QUICKLY        1.500
     MAX. TIME INCREMENT INCREASE FACTOR ALLOWED                       1.500
     MAX. TIME INCREMENT INCREASE FACTOR ALLOWED (DYNAMICS)            1.250
     MAX. TIME INCREMENT INCREASE FACTOR ALLOWED (DIFFUSION)           2.000
     MINIMUM TIME INCREMENT RATIO FOR EXTRAPOLATION TO OCCUR          0.1000
     MAX. RATIO OF TIME INCREMENT TO STABILITY LIMIT                   1.000
     FRACTION OF STABILITY LIMIT FOR NEW TIME INCREMENT               0.9500
     TIME INCREMENT INCREASE FACTOR BEFORE A TIME POINT                1.000
     AUTOMATIC TOLERANCES FOR OVERCLOSURE AND SEPARATION
     PRESSURE ARE SUPPRESSED
     GLOBAL STABILIZATION CONTROL IS NOT USED
     FRICTION IS INCLUDED IN INCREMENT THAT THE CONTACT POINT CLOSES
          PRINT OF INCREMENT NUMBER, TIME, ETC., EVERY    1  INCREMENTS
     THE MAXIMUM NUMBER OF INCREMENTS IN THIS STEP IS                   10000
     LINEAR EXTRAPOLATION WILL BE USED
     CHARACTERISTIC ELEMENT LENGTH      4.23
     DETAILED OUTPUT OF DIAGNOSTICS TO DATABASE REQUESTED
     PRINT OF INCREMENT NUMBER, TIME, ETC., TO THE MESSAGE FILE EVERY     1  INCREMENTS
     EQUATIONS ARE BEING REORDERED TO MINIMIZE WAVEFRONT
     COLLECTING MODEL CONSTRAINT INFORMATION FOR OVERCONSTRAINT CHECKS
     COLLECTING STEP CONSTRAINT INFORMATION FOR OVERCONSTRAINT CHECKS
  INCREMENT     1 STARTS. ATTEMPT NUMBER  1, TIME INCREMENT   1.00
***WARNING: THERE ARE 2 UNCONNECTED REGIONS IN THE MODEL.
***WARNING: THE SYSTEM MATRIX HAS 1 NEGATIVE EIGENVALUES.
     IN AN EIGENVALUE EXTRACTION STEP THE NUMBER OF NEGATIVE EIGENVALUES IS
     EQUAL TO THE NUMBER OF EIGENVALUES BELOW THE CURRENT SHIFT POINT.
     THIS MAY BE USED TO CHECK THAT EIGENVALUES HAVE NOT BEEN MISSED.
     NOTE: THE LANCZOS EIGENSOLVER APPLIES AN INTERNAL SHIFT WHICH WILL
     RESULT IN NEGATIVE EIGENVALUES.
     IN A DIRECT-SOLUTION STEADY-STATE DYNAMIC ANALYSIS, NEGATIVE
     EIGENVALUES ARE EXPECTED. A STATIC ANALYSIS CAN BE USED TO VERIFY THAT THE SYSTEM IS STABLE.
     IN OTHER CASES, NEGATIVE EIGENVALUES MEAN THAT THE SYSTEM MATRIX IS NOT
     POSITIVE DEFINITE:
     FOR EXAMPLE, A BIFURCATION (BUCKLING) LOAD MAY HAVE BEEN EXCEEDED.
     NEGATIVE EIGENVALUES MAY ALSO OCCUR IF QUADRATIC ELEMENTS ARE
     USED TO DEFINE CONTACT SURFACES.
***WARNING: SOLVER PROBLEM. NUMERICAL SINGULARITY WHEN PROCESSING NODE
             N800-1-1-1.187 D.O.F. 2 RATIO = 3.03274E+12.
             N800-1-1-1.186 D.O.F. 1 RATIO = 43.1192E+12 .
             N800-1-1-1.186 D.O.F. 2 RATIO = 20.8326E+12 .
             N800-1-1-1.186 D.O.F. 3 RATIO = 22.3203E+12 .
               CONVERGENCE CHECKS FOR EQUILIBRIUM ITERATION     1
AVERAGE FORCE                      3.568E-03   TIME AVG. FORCE       3.568E-03
LARGEST RESIDUAL FORCE              2.80       AT NODE        243   DOF  3
   INSTANCE: N800-1-1-1
LARGEST INCREMENT OF DISP.         2.822E+08   AT NODE         36   DOF  2
LARGEST CORRECTION TO DISP.        2.822E+08   AT NODE         36   DOF  2
          FORCE     EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE.
AVERAGE MOMENT                      0.00       TIME AVG. MOMENT      4.229E-02
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -10.8       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -1.365E+07   AT NODE          1   DOF  6
   INSTANCE: {assembly node}
LARGEST CORRECTION TO ROTATION    -1.365E+07   AT NODE          1   DOF  6
          THE MOMENT    IS ZERO EVERYWHERE BUT THE MOMENT    RESIDUAL OR
          THE ROTATION CORRECTION IS NON-ZERO
             EXPLANATIONS ARE SUGGESTED AFTER THE FIRST OCCURRENCE OF THIS MESSAGE.
               CONVERGENCE CHECKS FOR EQUILIBRIUM ITERATION     2
AVERAGE FORCE                      3.629E-03   TIME AVG. FORCE       3.629E-03
LARGEST RESIDUAL FORCE              2.37       AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         5.643E+08   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -19.9       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -2.730E+07   AT NODE          1   DOF  6
               CONVERGENCE CHECKS FOR EQUILIBRIUM ITERATION     3
AVERAGE FORCE                      3.709E-03   TIME AVG. FORCE       3.709E-03
LARGEST RESIDUAL FORCE             -2.81       AT NODE        244   DOF  3
LARGEST INCREMENT OF DISP.         8.465E+08   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -18.0       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -4.094E+07   AT NODE          1   DOF  6
               CONVERGENCE CHECKS FOR EQUILIBRIUM ITERATION     4
AVERAGE FORCE                      3.831E-03   TIME AVG. FORCE       3.831E-03
LARGEST RESIDUAL FORCE              2.92       AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         1.129E+09   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -33.9       AT NODE          1   DOF  5
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -5.459E+07   AT NODE          1   DOF  6
***NOTE: THE SOLUTION APPEARS TO BE DIVERGING. CONVERGENCE IS JUDGED UNLIKELY.
  INCREMENT     1 STARTS. ATTEMPT NUMBER  2, TIME INCREMENT  0.250
AVERAGE FORCE                      8.921E-04   TIME AVG. FORCE       8.921E-04
LARGEST RESIDUAL FORCE             0.700       AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         7.054E+07   AT NODE         36   DOF  2
LARGEST CORRECTION TO DISP.        7.054E+07   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -2.70       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -3.412E+06   AT NODE          1   DOF  6
LARGEST CORRECTION TO ROTATION    -3.412E+06   AT NODE          1   DOF  6
AVERAGE FORCE                      9.074E-04   TIME AVG. FORCE       9.074E-04
LARGEST RESIDUAL FORCE             0.592       AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         1.411E+08   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -4.97       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -6.824E+06   AT NODE          1   DOF  6
AVERAGE FORCE                      9.272E-04   TIME AVG. FORCE       9.272E-04
LARGEST RESIDUAL FORCE            -0.702       AT NODE        244   DOF  3
LARGEST INCREMENT OF DISP.         2.116E+08   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -4.50       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -1.024E+07   AT NODE          1   DOF  6
AVERAGE FORCE                      9.577E-04   TIME AVG. FORCE       9.577E-04
LARGEST RESIDUAL FORCE             0.731       AT NODE        243   DOF  3
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -8.47       AT NODE          1   DOF  5
   INSTANCE:
  INCREMENT     1 STARTS. ATTEMPT NUMBER  3, TIME INCREMENT  6.250E-02
AVERAGE FORCE                      2.230E-04   TIME AVG. FORCE       2.230E-04
LARGEST RESIDUAL FORCE             0.175       AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         1.764E+07   AT NODE         36   DOF  2
LARGEST CORRECTION TO DISP.        1.764E+07   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -0.676       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -8.530E+05   AT NODE          1   DOF  6
LARGEST CORRECTION TO ROTATION    -8.530E+05   AT NODE          1   DOF  6
AVERAGE FORCE                      2.268E-04   TIME AVG. FORCE       2.268E-04
LARGEST RESIDUAL FORCE             0.148       AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         3.527E+07   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -1.24       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -1.706E+06   AT NODE          1   DOF  6
AVERAGE FORCE                      2.318E-04   TIME AVG. FORCE       2.318E-04
LARGEST RESIDUAL FORCE            -0.175       AT NODE        244   DOF  3
LARGEST INCREMENT OF DISP.         5.291E+07   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -1.13       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -2.559E+06   AT NODE          1   DOF  6
AVERAGE FORCE                      2.394E-04   TIME AVG. FORCE       2.394E-04
LARGEST RESIDUAL FORCE             0.183       AT NODE        243   DOF  3
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT            -2.12       AT NODE          1   DOF  5
   INSTANCE:
  INCREMENT     1 STARTS. ATTEMPT NUMBER  4, TIME INCREMENT  1.563E-02
AVERAGE FORCE                      5.576E-05   TIME AVG. FORCE       5.576E-05
LARGEST RESIDUAL FORCE             4.375E-02   AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         4.409E+06   AT NODE         36   DOF  2
LARGEST CORRECTION TO DISP.        4.409E+06   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -0.169       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -2.132E+05   AT NODE          1   DOF  6
LARGEST CORRECTION TO ROTATION    -2.132E+05   AT NODE          1   DOF  6
AVERAGE FORCE                      5.671E-05   TIME AVG. FORCE       5.671E-05
LARGEST RESIDUAL FORCE             3.702E-02   AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         8.818E+06   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -0.310       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -4.265E+05   AT NODE          1   DOF  6
AVERAGE FORCE                      5.795E-05   TIME AVG. FORCE       5.795E-05
LARGEST RESIDUAL FORCE            -4.386E-02   AT NODE        244   DOF  3
LARGEST INCREMENT OF DISP.         1.323E+07   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -0.281       AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -6.397E+05   AT NODE          1   DOF  6
AVERAGE FORCE                      5.986E-05   TIME AVG. FORCE       5.986E-05
LARGEST RESIDUAL FORCE             4.569E-02   AT NODE        243   DOF  3
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -0.529       AT NODE          1   DOF  5
   INSTANCE:
 楼主| 发表于 19-11-2011 09:37:17 | 显示全部楼层
  INCREMENT     1 STARTS. ATTEMPT NUMBER  5, TIME INCREMENT  3.906E-03
AVERAGE FORCE                      1.394E-05   TIME AVG. FORCE       1.394E-05
LARGEST RESIDUAL FORCE             1.094E-02   AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         1.102E+06   AT NODE         36   DOF  2
LARGEST CORRECTION TO DISP.        1.102E+06   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -4.222E-02   AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -5.331E+04   AT NODE          1   DOF  6
LARGEST CORRECTION TO ROTATION    -5.331E+04   AT NODE          1   DOF  6
AVERAGE FORCE                      1.418E-05   TIME AVG. FORCE       1.418E-05
LARGEST RESIDUAL FORCE             9.254E-03   AT NODE        243   DOF  3
LARGEST INCREMENT OF DISP.         2.204E+06   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -7.759E-02   AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -1.066E+05   AT NODE          1   DOF  6
AVERAGE FORCE                      1.449E-05   TIME AVG. FORCE       1.449E-05
LARGEST RESIDUAL FORCE            -1.097E-02   AT NODE        244   DOF  3
LARGEST INCREMENT OF DISP.         3.307E+06   AT NODE         36   DOF  2
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -7.036E-02   AT NODE          1   DOF  4
   INSTANCE:
LARGEST INCREMENT OF ROTATION     -1.599E+05   AT NODE          1   DOF  6
AVERAGE FORCE                      1.496E-05   TIME AVG. FORCE       1.496E-05
LARGEST RESIDUAL FORCE             1.142E-02   AT NODE        243   DOF  3
                                                (FROM FORCE     FIELD)
LARGEST RESIDUAL MOMENT           -0.132       AT NODE          1   DOF  5
   INSTANCE:
***ERROR: TOO MANY ATTEMPTS MADE FOR THIS INCREMENT
     ANALYSIS SUMMARY:
     TOTAL OF          1  INCREMENTS
                       5  CUTBACKS IN AUTOMATIC INCREMENTATION
                      20  ITERATIONS INCLUDING CONTACT ITERATIONS IF PRESENT
                      20  PASSES THROUGH THE EQUATION SOLVER OF WHICH
                      20  INVOLVE MATRIX DECOMPOSITION, INCLUDING
                       0  DECOMPOSITION(S) OF THE MASS MATRIX
                       1  REORDERING OF EQUATIONS TO MINIMIZE WAVEFRONT
                       0  ADDITIONAL RESIDUAL EVALUATIONS FOR LINE SEARCHES
                       0  ADDITIONAL OPERATOR EVALUATIONS FOR LINE SEARCHES
                      46  WARNING MESSAGES DURING USER INPUT PROCESSING
                     101  WARNING MESSAGES DURING ANALYSIS
                      80  ANALYSIS WARNINGS ARE NUMERICAL PROBLEM MESSAGES
                      20  ANALYSIS WARNINGS ARE NEGATIVE EIGENVALUE MESSAGES
                       1  ERROR MESSAGES
     JOB TIME SUMMARY
       USER TIME (SEC)      =   124.60
       SYSTEM TIME (SEC)    =  0.80000
       TOTAL CPU TIME (SEC) =   125.40
       WALLCLOCK TIME (SEC) =        127
发表于 4-1-2012 13:07:18 | 显示全部楼层
刚体发生位移了 检查一下是不是该约束的地方没有约束?
GMT+8, 23-2-2025 04:21 , Processed in 0.893206 second(s), 36 queries .
