  • 3271查看
二次开发遇到的问题:Error using ==> sim
发表于 16-11-2011 22:48:40 | 显示全部楼层 |阅读模式
在对ADVISOR进行二次开发时,RUN之后出现如下问题:
Error using ==> sim
--> Data type mismatch. Input port 1 of block 'BD_SUV/electric acc loads <acc>/Electrical Accessory Loads v2 <acc>/backward model/electrical accessories (W)/Electrical Accessories: Time Variable/Aux Loads 14V Pwr/RearDefrost/Subsystem/Subsystem/Hit  Crossing3' expects a signal of data type 'double'. However, it is driven by a signal of data type 'boolean'.
--> Data type mismatch. Output port 1 of block 'BD_SUV/electric acc loads <acc>/Electrical Accessory Loads v2 <acc>/backward model/electrical accessories (W)/Electrical Accessories: Time Variable/Aux Loads 14V Pwr/RearDefrost/Subsystem/Subsystem/Relational Operator3' is a signal of data type 'boolean'. However, it is driving a signal of data type 'double'.
> In D:\MATLAB\advisor\advisor2002\gui\SimSetupFig.m (run_pushbutton_Callback) at line 1351
  In D:\MATLAB\advisor\advisor2002\gui\SimSetupFig.m at line 374
continue 可以运行,一到RUN就出问题,不知道是哪里错了呢?
我用的是2002,matlab6.5,应该跟版本没问题吧,文件修改,模型什么的也没有问题
发表于 18-11-2011 10:20:17 | 显示全部楼层
用matlab6.1
 楼主| 发表于 18-11-2011 12:31:06 | 显示全部楼层
纠结了好几天,我试试看
发表于 21-11-2011 14:27:28 | 显示全部楼层
advisor在高级的matlab中运行必须要有一个补丁文件,先进入matlab,在matlab中打开这个补丁文件,然后按下F5运行补丁文件,运行完成后进入advisor中就没有问题了。
呵呵,这个问题刚开始我也纠结了好长的时间才弄好的,住你好运。
ADVISOR2002patchforR13.m
2.99 KB, 下载次数: 37, 下载积分: 积分 -1
发表于 12-6-2012 00:39:18 | 显示全部楼层
ADVISOR2002patchforR13.m这个不错...
GMT+8, 23-12-2024 08:25 , Processed in 0.490438 second(s), 35 queries .
