  • 1541查看
在matlab编程中总出现下面的问题
    发表于 15-10-2011 09:51:59 | 显示全部楼层 |阅读模式
    程序;function y = QuadraticBarElementStiffness(E, A, L)
    %QuadraticBarElementStiffness   This dunction returns the element
    %stiffness matrix for a quadratic bar with modulus of elasticity E,
    %cross-sectional area A, and length L.This size of  the element stiffness
    %matrix is 3*3.
    y=E*A/(3*L)[7 1 -8; 1 7 -8; -8 -8 16];
    提示出项的问题:Warning: Could not find an exact (case-sensitive) match for
    'QuadraticBarElementstiffness'.
    E:\matlab,\toolbox\75function\QuadraticBarElement\QuadraticBarElementStiffness.m
    is a case-insensitive match and will be used instead.
    You can improve the performance of your code by using exact
    name matches and we therefore recommend that you update your
    usage accordingly. Alternatively, you can disable this warning using
    warning('off','MATLAB:dispatcher:InexactCaseMatch').
    This warning will become an error in future releases.
    ??? Error: File: QuadraticBarElementStiffness.m Line: 6 Column: 12
    Unbalanced or unexpected parenthesis or bracket.,该怎么修改??求高手指点
    发表于 15-10-2011 14:52:23 | 显示全部楼层
    貌似表达式不是很清楚,E A L是否是矩阵,(3L)和[]是什么关系,是不是乘,如果是乘要加'*',如果前面的是矩阵,是元素相乘要有'.'
    GMT+8, 16-6-2026 01:50 , Processed in 0.542373 second(s), 38 queries .
