  • 1865查看
关于板簧刚度测试的问题
发表于 6-10-2011 17:41:42 | 显示全部楼层 |阅读模式
我的板簧模型测试时出现:
ERROR:      **** ADAMS MEMORY OVERFLOW ****
   A larger MD array is required.
   The error occurred in subroutine "SYMFAC" while allocating " DOUB" space
   from "SOLV" for the "Jacobian array".
   Space Available:  49866    Space Requested:  69518
   Adams/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   20,000,000
        HUGE       60,000,000
   where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
   the main memory array in Adams in words (one word is 4 bytes).
   To use an alternative setting, you have to start the Adams 'Settings'
   program.  It can be found using the Start menu:
     Start -> Programs -> MSC.Software -> Adams -> Adams-Settings
ERROR:   Abnormal termination encountered in Adams/Solver.
什么意思啊,看不懂......
有兴趣的朋友一起交流一下板簧建立呀。
发表于 16-4-2013 19:47:47 | 显示全部楼层
…… 得好好看看
GMT+8, 23-4-2026 14:40 , Processed in 0.431610 second(s), 37 queries .
