  • 1415查看
平顺性仿真时,出现如下错误,盼指点
发表于 17-9-2011 13:28:37 | 显示全部楼层 |阅读模式
我的车是四轴半挂车,在做平顺性仿真时出现如下错误,说明一下,我的牵引车单独仿真时是可行的,加上挂车后就报错,.提示bgs_fifth_wheel_to_trailer.field .错误,有没有人知道可能会是什么引起的这种错误,求指点!万分感谢!
---- WARNING ----
   The corrector has not converged after 6 attempts. No. of iterations = 20.
   The system has 539 kinematic degrees of freedom.
---- ERROR ----
   The simulation stopped at time = 0.0 .  Adams cannot solve
   the equations of motion.
   The greatest error in an equation is 3.08756E-04 in the
   equation for FIELD G_linear_uniform65.msc_truck_rigid_trailer.bgs_fifth_wheel_to_trailer.field .
   The greatest change in a variable is 8.83880E-15 in the
   variable for PART G_linear_uniform65.msc_truck_steer_suspension.ges_tie_rod .
   Try the following in this order:
       1.  Use the MAXIT argument on the EQUILIBRIUM, IC, KINEMATICS,
           or INTEGRATOR command to increase the maximum number of
           iterations.
       2.  Temporarily change the value of the PATTERN argument on the
           EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command to
           PATTERN = T.
       3.  Temporarily increase the value of the ERROR argument on the
           EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command at
           time = 0.0 .
       4.  If one or more forces change rapidly or sharply near
           time = 0.0, modify the force or forces.
---- ERROR ----
   SIMULATE command failed for minimaneuver: UNIFORM
   Aborting Execution.
   Terminating Adams/Car usersubs...
      Adams/Solver execution terminated by subprogram ERRMES
   CPU time used = 4.8594 seconds
Simulation is complete.
GMT+8, 22-12-2024 22:33 , Processed in 0.211251 second(s), 27 queries .
