  • 1567查看
汽车后排有效腿部空间问题
    发表于 29-8-2011 11:32:00 | 显示全部楼层
    还有这个L34
    L34
    Effective Leg Room – Accelerator
    The distance along a line from the ankle pivot center to the SgRP –
    front, plus 254 mm, measured with the right foot on the
    undepressed accelerator pedal.
     楼主| 发表于 29-8-2011 11:30:47 | 显示全部楼层 |阅读模式
    SAE 2005版本中,后排有效腿部空间规定的比较多,兄弟们是咋理解的?要不要将脚左右偏127mm后量取脚踝点至H点啊?
    SAE J1100 Revised SEP2005
    L51:Effective Leg Room (Passengers) The dimension measured along a line from the ankle pivot center
    to the SgRP plus 254 mm with the heel of the shoe at the FRP
    and the bottom of the shoe at the FPA.
    Note 1: For long-coupled seating, leg room is measured with the
    shoe at its most forward location within a lateral space 127 mm
    either side of the occupant centerline regardless of the ankle angle.
    The shoe is not located at the FRP or FPA.
    Note 2: For short-coupled seating, leg room is measured with the
    shoe located at the FRP. When the front of the shoe interferes
    with the preceding seat, the amount of seat track travel needed to
    clear the interference is subtracted. If the preceding seat does not
    adjust, the horizontal interference is subtracted.
    GMT+8, 25-11-2024 16:40 , Processed in 0.294220 second(s), 27 queries .
