  • 2820查看
有关四轴半挂车的建模问题--请大侠进来瞧瞧
发表于 11-6-2011 10:51:13 | 显示全部楼层 |阅读模式
我想建一个四轴挂车的模型,在truck模块里自带有一个五轴半挂车模型msc_tractor_semitailer.asy,我想将这个模型改为四轴的,于是将牵引车的后桥改为单桥msc_truck_drive_axle.sub,但是仿真是会出现如下错误.请高手指点指点,感激不尽!
另外我还想将这个四轴半挂车模型再改成自己想要的车型,很多地方不知道从哪修改!
---- ERROR ----
   Attempt = 1. No convergence after 25 iterations. Best iteration = 11.
   Trying next attempt with a different set of statics parameters...
   For the last attempted iteration the equation with the largest error
   was PART line_5_linear_uniform.msc_truck_rigid_cab.ges_cab  Error = 5.32182E+07
   The variable receiving the largest increment
   was JOINT line_5_linear_uniform.msc_truck_steer_suspension.jolrev_upright_to_axle  Delta = 4.18849E+08
---- WARNING ----
   The part 147, line_5_linear_uniform.msc_truck_trailer_wheels_2.whr_outside_wheel, may be a free body.
---- ERROR ----
   Static equilibrium analysis has not been successful.
   Restoring the input initial conditions...
   acar_2010.1.0/vdm::apre_fvbcsb
   **** Error:
         Sim/stat cannot be achieved.
---- ERROR ----
   Aborting Execution.
   Terminating Adams/Car usersubs...
      Adams/Solver execution terminated by subprogram ERRMES
   CPU time used = 1.9688 seconds
Simulation is complete.
    发表于 2-5-2013 22:27:09 | 显示全部楼层
    这个你需要仔细研究模板,不是所有的都是可以删除的
    GMT+8, 7-5-2026 02:58 , Processed in 0.318719 second(s), 33 queries .
