  • 7300查看
[欧洲标准] ECE法规目录列表(中英对照)
发表于 5-5-2011 15:45:25 | 显示全部楼层 |阅读模式
ECE法规目录列表(中英对照)
Regulation No.法规编号        Title        中文名称
1        Uniform provisions concerning the approval of motor vehicle headlamps emitting an asymmetrical passing beam and/or a driving beam and equipped with filament lamps of categories R2 and/or HS1        关于批准发射非对称近光和/或远光并装有R2/或HS1类白炽灯的机动车前照灯的统一规定
2        Uniform provisions concerning the approval of incandescent electric lamps for headlamps emitting an asymmetrical passing beam or a driving beam or both        关于批准发射对称近光或远光或两者兼有的前照灯用白炽灯泡的统一规定
3        Uniform provisions concerning the approval of retro-reflecting devices for power-driven vehicles and their trailers        关于批准机动车辆及其挂车后反射装置的统一规定
4        Uniform provisions for the approval of devices for the illumination of rear registration plates of motor vehicles (except motor cycles) and their trailers        关于批准机动车辆(摩托车除外)及其挂车后牌照板照明装置的统一规定
5        Uniform provisions for the approval of motor vehicle "sealed beam" headlamps (SB) emitting a European asymmetrical passing beam or a driving beam or both        关于批准发射欧洲型非对称近光或远光或两者兼有的机动车封闭式前照灯(SB)的统一规定
6        Uniform provisions concerning the approval of direction indicators for motor vehicles and their trailers        关于批准机动车及其挂车转向指示信号灯的统一规定
7        Uniform provisions concerning the approval of front and rear position (side) lamps, stop-lamps and end-outline marker lamps for motor vehicles (except motor cycles) and their trailers        关于批准机动车(不含摩托车)及其挂车前后位置(侧边)灯、制动灯和示廓灯的统一规定
8        Uniform provisions concerning the approval of motor vehicle headlamps emitting an asymmetrical passing beam or a driving beam or both and equipped with halogen filament lamps (H1, H2, H3, HB3, HB4, H7, H8, H9, HIR1, HIR2 and/or H11)        关于批准发射非对称近光或远光或两者兼有装有卤素灯(H1,H2,H3,HB3,HB4和/或H7)的机动车前照灯的统一规定
9        Uniform provisions concerning the approval of category L2, L4 and L5 vehicles with regard to noise        关于就噪声方面批准三轮车辆的统一规定
10        Uniform provisions concerning the approval of vehicles with regard to electromagnetic compatibility        关于就无线电干扰抑制方面批准车辆的统一规定
11        Uniform provisions concerning the approval of vehicles with regard to door latches and door retention components        关于就门锁和车门保持件方面批准车辆的统一规定
12        Uniform provisions concerning the approval of vehicles with regard to the protection of the driver against the steering mechanism in the event of impact        关于就碰撞中防止转向机构伤害驾驶员方面批准车辆的统一规定
13        Uniform provisions concerning the approval of vehicles of categories M, N and O with regard to braking        关于就制动方面批准M、N和O类车辆的统一规定
13-H        Uniform provisions concerning the approval of passenger cars with regard to braking        关于就制动方面批准客车的统一规定。
14        Uniform provisions concerning the approval of vehicles with regard to safety-belt anchorages        关于就安全带固定方面批准车辆的统一规定
15        Uniform provisions concerning the approval of vehicles equipped with a positive-ignition engine or with a compression-ignition engine with regard to the emission of gaseous pollutants by the engine - method of measuring the power of positive-ignition engines - method of measuring the fuel consumption of vehicles        关于就发动机气体污染物排放方面批准装有点火式发动机或压燃式发动机的车辆统一规定-点火式发动机的功率测量方法-车辆的油耗测量方法
16        Uniform provisions concerning the approval of :I.        Safety-belts and restraint systems for occupants of power-driven vehiclesII.  Vehicles equipped with safety-belts        关于批准Ⅰ 机动车成年乘客用安全带和约束系统Ⅱ 装有安全带的车辆的统一规定
17        Uniform provisions concerning the approval of vehicles with regard to the seats, their anchorages and any head restraints        关于就座椅、座椅固定点和头枕方面批准车辆的统一规定
18        Uniform provisions concerning the approval of motor vehicles with regard to their protection against unauthorized use        关于就防盗方面批准机动车的统一规定
19        Uniform provisions concerning the approval of motor vehicle fog lamps        关于批准机动车前雾灯的统一规定
20        Uniform provisions concerning the approval of motor vehicle headlamps emitting an asymmetrical passing beam or a driving beam or both and equipped with halogen filament lamps (H4 lamps)        关于批准发射非对称近光或远光或两者兼有并装有卤素灯(H4)的机动车前照灯的统一规定
21        Uniform provisions concerning the approval of vehicles with regard to their interior fittings        关于就内饰件方面批准车辆的统一规定
22        Uniform provisions concerning the approval of protective helmets and their visors for drivers and passengers of motor cycles and mopeds        关于批准摩托车、轻便摩托车驾驶员及乘客用头盔和面罩的统一规定
23        Uniform provisions concerning the approval of reversing lights for power-driven vehicles and their trailers        关于批准机动车及其挂车的倒车灯的统一规定
24        Uniform provisions concerning:I.        The approval of compression ignition (C.I.) engines with regard to the emission of visible pollutantsII.        The approval of motor vehicles with regard to the installation of C.I. engines of an approved typeIII.        The approval of motor vehicles equipped with C.I. engines with regard to the emission of visible pollutants by the engineIV.        The measurement of power of C.I. engine        关于Ⅰ 就可见污染物排放方面批准压燃式(C.I)发动机   Ⅱ 就安装已批准型式的C.1.发动机方面批准机动车  Ⅲ C.I.发动机的功率测量的统一规定
25        Uniform provisions concerning the approval of head restraints (headrests), whether or not incorporated in vehicle seats        关于批准与车辆座椅一体或非一体的头枕的统一规定
26        Uniform provisions concerning the approval of vehicles with regard to their external projections        关于就外部突出物方面批准车辆的统一规定
27        Uniform provisions for the approval of advance-warning triangles        关于批准提前警告三角板的统一规定
28        Uniform provisions concerning the approval of audible warning devices and of motor vehicles with regard to their audible signals        关于就声响信号方面批准声报警装置和机动车辆的统一规定
29        Uniform provisions concerning the approval of vehicles with regard to the protection of the occupants of the cab of a commercial vehicle        关于就商用车辆驾驶室乘员防护方面批准车辆的统一规定
30        Uniform provisions concerning the approval of pneumatic tyres for motor vehicles and their trailers        关于批准机动车及其挂车气压轮胎的统一规定
31        Uniform provisions concerning the approval of halogen sealed-beam unit (HSB unit) motor vehicle headlamps emitting an asymmetrical passing beam or a driving beam or both        关于批准发射非对称近光或远光或两者兼有的卤素封闭式(HSB)机动车前照灯的统一规定
32        Uniform provisions concerning the approval of vehicles with regard to the behaviour of the structure of the impacted vehicle in a rear-end collision        关于就追尾碰撞中被撞车辆的结构特性方面批准车辆的统一规定
33        Uniform provisions concerning the approval of vehicles with regard to the behaviour of the structure of the impacted vehicle in a head-on collision        关于就正面冲撞中被撞的结构特性方面批准车辆的统一规定
34        Uniform provisions concerning the approval of vehicles with regard to the prevention of fire risks        关于就火灾预防方面批准车辆的统一规定
35        Uniform provisions concerning the approval of vehicles with regard to the arrangement of foot controls        关于就脚控制件的布置方面批准车辆的统一规定
36        Uniform provisions concerning the approval of large passenger vehicles with regard to their general construction        关于就一般结构方面批准大型客车的统一规定
37        Uniform provisions concerning the approval of filament lamps for use in approved lamp units of power-driven vehicles and of their trailers        关于批准用于已经批准的机动车或挂车灯具中的白炽灯的统一规定
38        Uniform provisions concerning the approval of rear fog lamps for power-driven vehicles and their trailers        关于批准机动车和挂车后雾灯的统一规定
39        Uniform provisions concerning the approval of vehicles with regard to the speedometer equipment including its installation        关于就车速表及其安装方面批准车辆的统一规定
40        Uniform provisions concerning the approval of motor cycles equipped with a positive-ignition engine with regard to the emission of gaseous pollutants by the engine        关于就摩托车废气污染物的排放方面批准装有点火式发动机的摩托车的统一规定
41        Uniform provisions concerning the approval of motor cycles with regard to noise        关于就噪声方面批准摩托车的统一规定
42        Uniform provisions concerning the approval of vehicles with regard to their front and rear protective devices (bumpers, etc.)        关于就车辆前、后保护装置(保险杠等)批准车辆的统一规定
43        Uniform provisions concerning the approval of safety glazing materials        关于批准安全玻璃和玻璃材料的统一规定
44        Uniform provisions concerning the approval of restraining devices for child occupants of power-driven vehicles ("child restraint system")        关于批准机动车儿童乘客约束装置(儿童约束系统)的统一规定
45        Uniform provisions concerning the approval of headlamp cleaners, and of power-driven vehicles with regard to headlamp cleaners        关于就前照灯清洗器方面批准机动车辆和批准前照灯清洗器的统一规定
46        Uniform provisions concerning the approval of rear-view mirrors, and of motor vehicles with regard to the installation of rear-view mirrors        关于批准后视镜和就后视镜的安装方面批准机动车辆的统一规定
47        Uniform provisions concerning the approval of mopeds equipped with a positive-ignition engine with regard to the emission of gaseous pollutants by the engine        关于就发动机的气体污染物排放方面批准装有点火发动机的轻便摩托车的统一规定
48        Uniform provisions concerning the approval of vehicles with regard to the installation of lighting and light-signalling devices        关于就灯光和信号装置的安装方面批准车辆的统一规定
49        Uniform provisions concerning the approval of compression ignition (C.I.) and natural gas (N.G.) engines as well as positive-ignition (P.I.) engines fuelled with liquefied petroleum gas (LPG) and vehicles equipped with C.I. and N.G. engines and P.I. engines fuelled with LPG, with regard to the emissions of pollutants by the engine        关于就发动机污染物排放方面批准压燃式发动机和天然气发动机、燃用LPG的点火式发动机和装有压燃式发动机和天然气发动机、燃用LPG的点火式发动机的车辆的统一规定
50        Uniform provisions concerning the approval of front position lamps, rear position lamps, stop lamps, direction indicators and rear-registration-plate illuminating devices for mopeds, motor cycles and vehicles treated as such        关于批准轻便摩托车、摩托车及其类似车辆前后位置灯、制动灯、转向信号灯和后牌照灯照明装置的统一规定
51        Uniform provisions concerning the approval of motor vehicles having at least four wheels with regard to their noise emissions        关于就噪声排放方面批准四轮及四轮以上机动车的统一规定
52        Uniform provisions concerning the approval of M2 and M3 small capacity vehicles with regard to their general construction        关于小型公共运输车辆(M2、M3)的结构的统一规定
53        Uniform provisions concerning the approval of category L3 vehicles with regard to the installation of lighting and light-signalling devices        关于就灯光及信号装置的安装方面批准L3类车辆的统一规定
54        Uniform provisions concerning the approval of pneumatic tyres for commercial vehicles and their trailers        关于批准商用车辆及其挂车的气压轮胎的统一规定
55        Uniform provisions concerning the approval of mechanical coupling components of combinations of vehicles        关于批准汽车机械联结件的统一规定
56        Uniform provisions concerning the approval of headlamps for mopeds and vehicles treated as such        关于批准轻便摩托车以及类似车辆前照灯的统一规定
57        Uniform provisions concerning the approval of headlamps for motor cycles and vehicles treated as such        关于批准摩托车以及类似车辆前照灯的统一规定
58        Uniform provisions concerning the approval of: I.        Rear underrun protective devices (RUPDs)II.        Vehicles with regard to the installation of a RUPD of an approved typeIII.        Vehicles with regard to their rear underrun protection (RUP)        关于Ⅰ 批准后下部防护装置 Ⅱ 就已批准的后下部防护装置的安装方面批准车辆  Ⅲ 就后下部防护装置方面批准车辆 的统一规定
59        Uniform provisions concerning the approval of replacement silencing systems        关于批准备用消声系统的统一规定
        Uniform provisions concerning the approval of two-wheeled motor cycles and mopeds with regard to driver-operated controls including the identification of controls, tell-tales and indicators        关于就驾驶员操纵的控制件,包括控制件的识别,信号装置和指示器方面批准两轮摩托车和轻便摩托车的统一规定
61        Uniform provisions concerning the approval of commercial vehicles with regard to their external projections forward of the cab's rear panel        关于就驾驶室后挡板的前向外部突出物方面批准商用车的统一规定
62        Uniform provisions concerning the approval of power-driven vehicles with handlebars with regard to their protection against unauthorized use        关于就防盗方面批准带有操纵把的机动车的统一规定
63        Uniform provisions concerning the approval of two-wheeled mopeds with regard to noise        关于就噪声方面批准轻便摩托车的统一规定
64        Uniform provisions concerning the approval of vehicles equipped with temporary-use spare wheels/tyres        关于批准装有应急用备用车轮/轮胎的车辆的统一规定
65        Uniform provisions concerning the approval of special warning lamps for motor vehicles        关于批准摩托车特别警告灯的统一规定
66        Uniform provisions concerning the approval of large passenger vehicles with regard to the strength of their superstructure        关于就上部结构强度方面批准大型乘客车的统一规定
67        Uniform provisions concerning:I. Approval of specific equipment of motor vehicles using liquefied petroleum gases in their propulsion systemII. Approval of a vehicle fitted with specific equipment for the use of liquefied petroleum gases in its propulsion system with regard to the installation of such equipment        关于批准在其驱动系统中使用液化石油气的机动车辆特殊装置的统一规定
68        Uniform provisions concerning the approval of power-driven vehicles including pure electric vehicles with regard to the measurement of the maximum speed        关于就最大车速的测量方面批准机动车,包括电动车的统一规定
69        Uniform provisions concerning the approval of rear marking plates for slow-moving vehicles (by construction) and their trailers        关于批准低速车辆及其挂车后标志牌的统一规定
70        Uniform provisions concerning the approval of rear marking plates for heavy and long vehicles        关于批准重、长型车辆后标志牌的统一规定
71        Uniform provisions concerning the approval of agricultural tractors with regard to the driver's field of vision        关于就驾驶员视野方面批准农用拖拉机的统一规定
72        Uniform provisions concerning the approval of motor cycle headlamps emitting an asymmetrical passing beam and a driving beam and equipped with halogen lamps (HS1 lamps)        关于批准发射非对称近光和远光并装有卤素灯(HIS灯)的摩托车前大灯统一规定
73        Uniform provisions concerning the approval of goods vehicles, trailers and semi-trailers with regard to their lateral protection        关于就侧面防护方面批准货车、挂车和半挂车的统一规定
74        Uniform provisions concerning the approval of category L1 vehicles with regard to the installation of lighting and light-signalling devices        关于就灯光和光信号装置方面批准轻便摩托车的统一规定
75        Uniform provisions concerning the approval of pneumatic tyres for motor cycles and mopeds        关于批准摩托车和轻便摩托车气压轮胎的统一规定
76        Uniform provisions concerning the approval of headlamps for mopeds emitting a driving beam and a passing beam        关于批准发射远光和近光的轻便摩托车前照灯的统一规定
77        Uniform provisions concerning the approval of parking lamps for power-driven vehicles        关于批准机动车驻车灯的统一规定
78        Uniform provisions concerning the approval of vehicles of category L with regard to braking        关于就制动方面批准L类车辆的统一规定
79        Uniform provisions concerning the approval of vehicles with regard to steering equipment        关于就转向装置方面批准车辆的统一规定
80        Uniform provisions concerning the approval of seats of large passenger vehicles and of these vehicles with regard to the strength of the seats and their anchorages        关于就座椅及其固定点方面批准大型客车座椅和车辆的统一规定
81        Uniform provisions concerning the approval of rear-view mirrors of two-wheeled power-driven vehicles with or without side car, with regard to the mounting of rear-view mirrors on handlebars        关于就车把上后视镜的安装方面批准后视镜及带与不带边斗的二轮机动车的后视镜的统一规定
82        Uniform provisions concerning the approval of moped headlamps equipped with filament halogen lamps (HS2)        关于装有白炽卤素灯(HS2)的轻便摩托车前照灯的统一规定
83        Uniform provisions concerning the approval of vehicles with regard to the emission of pollutants according to engine fuel requirements        关于根据发动机燃油要求就污染物排放方面批准车辆的统一规定
84        Uniform provisions concerning the approval of power-driven vehicles equipped with internal combustion engines with regard to the measurement of fuel consumption        关于就油耗测量方面批准装有内燃机的机动车的统一规定
85        Uniform provisions concerning the approval of internal combustion engines or electric drive trains intended for the propulsion of motor vehicles of categories M and N with regard to the measurement of the net power and the maximum 30 minutes power of electric drive trains        关于就净功率测量、电驱动机组30分钟功率方面批准用于驱动M类机动车辆的内燃机及电驱动机组的统一规定
86        Uniform provisions concerning the approval of agricultural or forestry tractors with regard to the installation of lighting and light-signalling devices        关于就灯光和信号装置的安装方面批准农林拖拉机的统一规定
87        Uniform provisions concerning the approval of daytime running lamps for power-driven vehicles        关于批准机动车白天行车灯的统一规定
88        Uniform provisions concerning the approval of retroreflective tyres for two-wheeled vehicles        关于批准二轮机动车反光轮胎的统一规定
89        Uniform prescriptions for approval of: I. Vehicles with regard to limitation of their maximum speed or their adjustable speed limitation functioII.        Vehicles with regard to the installation of a speed limiting device (SLD) or adjustable speed limitation device (ASLD) of an approved typeⅢ. Speed limitation devices (SLD) ) and adjustable speed limitation device (ASLD)        关于:Ⅰ 就最高车速限制或可调速度限制功能方面批准车辆  Ⅱ 就已批准型式的最高车速限制装置或可调速度限制   装置的安装方面批准车辆  Ⅲ 批准车速限制装置或可调速度限制装置  的统一规定
90        Uniform provisions concerning the approval of replacement brake lining assemblies and drum-brake linings for power-driven vehicles and their trailers        关于13机动车辆及其挂车用可更替制动衬片总成和鼓式制动器衬片的统一规定
91        Uniform provisions concerning the approval of side-marker lamps for motor vehicles and their trailers        关于批准机动车及其挂车侧标志灯的统一规定
92        Uniform provisions concerning the approval of non-original replacement exhaust silencing systems (RESS) for motorcycles, mopeds and three-wheeled vehicles        关于批准摩托车、轻便摩托车和三轮车的非原装替换排气消声系统的统一规定
93        Uniform provisions concerning the approval of:I.        Front underrun protective devices (FUPDs)II.        Vehicles with regard to the installation of an FUPD of an approved typeIII.Vehicles with regard to their front underrun protection (FUP)        关于Ⅰ 批准前下部防护装置 Ⅱ 就已批准型式的前下部防护装置的安装方面批准车辆  Ⅲ 就前下部防护方面批准车辆  的统一规定
94        Uniform provisions concerning the approval of vehicles with regard to the protection of the occupants in the event of a frontal collision        关于就前碰撞中乘员防护方面批准车辆的统一规定
95        Uniform provisions concerning the approval of vehicles with regard to the protection of the occupants in the event of a lateral collision        关于就侧碰撞中乘员防护方面批准车辆的统一规定
96        Uniform provisions concerning the approval of compression ignition (C.I.) engines to be installed in agricultural and forestry tractors and in non-road mobile machinery with regard to the emissions of pollutants by the engine        关于就发动机污染物排放方面批准农林拖拉机、非道路移动机械装用的压燃式发动机的统一规定
97        Uniform provisions concerning the approval of vehicle alarm systems (VAS) and of motor vehicles with regard to their alarm systems (AS)        关于就其报警系统方面批准车辆报警系统和机动车辆的统一规定
98        Uniform provisions concerning the approval of motor vehicle headlamps equipped with gas-discharge light sources        关于批准装用气体放电光源的机动车前照灯的统一规定
99        Uniform provisions concerning the approval of gas-discharge light sources for use in approved gas-discharge lamp units of power-driven vehicles        关于批准用于已通过认证的机动车的气体放电灯具的气体放电光源的统一规定
100        Uniform provisions concerning the approval of battery electric vehicles with regard to specific requirements for the construction, functional safety and hydrogen emission        关于就结构、功能安全性及氢辐射的特殊要求方面批准蓄电池电动车辆的统一规定
101        Uniform provisions concerning the approval of passenger cars equipped with an internal combustion engine with regard to the measurement of the emission of carbon dioxide and fuel consumption and of categories M1 and N1 vehicles equipped with an electric power train with regard to the measurement of electric energy consumption and range        关于就CO排放物和油耗的测量方面批准装用内燃机的客车及就电能消耗和范围的测量方面批准装用电驱动机组的M1和N1类车辆的统一规定
102        Uniform provisions concerning the approval of:I.        A close-coupling device (CCD)II. Vehicles with regard to the fitting of an approved type of CCD        关于批准Ⅰ 紧耦合装置 Ⅱ 就一个已通过认证的紧耦合装置的安装方面批准车辆的统一规定
103        Uniform provisions concerning the approval of replacement catalytic converters for power-driven vehicles        关于批准机动车辆的可更换催化转化器的统一规定
104        Uniform provisions concerning the approval of retro-reflective markings for heavy and long vehicles and their trailers        关于批准重型及加长型机动车及其挂车的回复反射器标记的统一规定
105        Uniform provisions concerning the approval of vehicles intended for the carriage of dangerous goods with regard to their specific construction features        关于就其特殊构造特点方面批准载用危险货物的机动车的统一规定
106        Uniform provisions concerning the approval of pneumatic tyres for agricultural vehicles and their trailers        关于批准农用车及其挂车的气动轮胎的统一规定
107        Uniform provisions concerning the approval of double-deck large passenger vehicles with regard to their general construction        关于批准就其总结构方面批准大型双层客车的统一规定
108        Uniform provisions concerning the approval for the production of retreaded pneumatic tyres for motor vehicles and their trailers        关于批准机动车及其挂车的翻新的气动轮胎的生产的统一规定
109        Uniform provisions concerning the approval for the production of retreaded pneumatic tyres for commercial vehicles and their trailers        关于商用车及其挂车的的翻新的气动轮胎的生产的统一规定
110        Uniform provisions concerning the approval of:Ⅰ Specific components of motor vehicles using compressed natural gas (CNG) in their propulsion system;II. Vehicles with regard to the installation of specific components of an approved type for the use of compressed natural gas (CNG) in their propulsion system        关于批准Ⅰ 燃用压缩天然气的机动车的推进系统中的专用部件Ⅱ 就已通过认证的燃用压缩天然气的机动车的推进系统中的专用部件的安装方面的统一规定
111        Uniform provisions concerning the approval of tank vehicles of categories N and O with regard to rollover stability        关于就转动稳定性批准N 、O类罐车的统一规定
112        Uniform provisions concerning the approval of motor vehicle headlamps emitting an asymmetrical passing beam or a driving beam or both and equipped with filament lamps        关于批准装有发射非对称近光或远光或两者兼有的白炽灯的机动车前照灯的统一规定
113        Uniform provisions concerning the approval of motor vehicle headlamps emitting a symmetrical passing beam or a driving beam or both and equipped with filament lamps        关于批准装有发射对称近光或远光或两者兼有的白炽灯的机动车前照灯的统一规定
114        Uniform provisions concerning the approval of:I.        An airbag module for a replacement airbag system;II.         A replacement steering wheel equipped with an airbag module of an approved type;III.        A replacement airbag system othe than that installed in a steering wheel        关于批准Ⅰ 代替气囊系统的气囊组件Ⅱ 装有已通过认证的气囊组件的可替换方向盘Ⅲ 非安装在方向盘上的可替换气囊系统的统一规定
115        Uniform provisions concerning the approval of Uniform provisions concerning the approval of:I. Specific LPG (liquefied petroleum gases) retrofit systems to be     installed in motor vehicles for the use of LPG in their propulsion systemII. Specific CNG (compressed natural gas) retrofit systems to be installed in motor vehicles for the use of CNG in their propulsion system        关于批准:Ⅰ 在其驱动系统中使用液化石油气的机动车辆上安装的特殊液化石油气加注系统;Ⅱ 在其驱动系统中使用压缩天然气的机动车辆上安装特殊压缩天然气加注系统的统一规定
116        Uniform technical prescriptions concerning the protection of motor vehicles against unauthorized use        关于机动车辆防盗保护的统一技术规定
117        Uniform provisions concerning  the approval of tyres with regard to rolling sound emissions        在滚动噪声方面批准轮胎的统一规定
118        Uniform technical prescriptions concerning the burning behaviour of materials used in the interior construction of certain categories of motor vehicles        用于某些类型机动车辆内部结构的材料的燃烧特性的统一技术规定
119        Uniform provisions concerning  the approval of  cornering lamps for power-driven vehicles        关于批准机动车辆转弯灯(弯道照明灯)的统一规定
120        Uniform provisions concerning  the approval of internal combustion engines to be installed in agricultural and forestry tractors and in non-road mobile machinery , with regard to the measurement of the net power ,net torque and specific fuel consumption        关于就净功率的测量批准农林拖拉机和非道路机动机械装用的内燃机的统一规定
121        Uniform provisions concerning  the approval of  vehicles with regard to the location and identification of hand controls, tell-tales and indicators        关于车辆的手控装置、信号装置和指示器位置和识别的批准的统一规定
122        Uniform technical prescriptions concerning  the approval of vehicles of categories M,N and O with regard to their heating systems        关于M,N和O类车辆的加热系统批准的统一规定
123        Uniform provisions concerning the approval of adaptive front-lighting systems (AFS) for motor vehicles        关于机动车自适应前照灯系统批准的统一规定
124        Uniform provisions concerning the approval of wheels for passenger cars and their trailers        关于乘用车及拖车车轮批准的统一规定
125        Forward field of vision        前向视野
126        Partitioning systems        隔离系统
ECE法规目录列表(中英对照).doc
202.5 KB, 下载次数: 57, 下载积分: 积分 -1
发表于 17-5-2011 14:10:20 | 显示全部楼层
顶一下,好东西
发表于 15-4-2013 10:27:37 | 显示全部楼层
不错,正好用得着
发表于 25-2-2014 00:07:19 | 显示全部楼层
现在Regulation已经更新到R131啦。哈
    3-8-2015 21:30
  • 签到天数: 9 天
    发表于 29-6-2015 23:28:56 | 显示全部楼层
    值得学习学习
    GMT+8, 26-11-2024 06:52 , Processed in 0.385765 second(s), 30 queries .
