  • 1233查看
发表于 26-4-2011 12:40:31 | 显示全部楼层 |阅读模式
Warning: Using a default value of 0.2 for maximum step size.  The simulation step size will be equal to or less than
this value.  You can disable this diagnostic by setting 'Automatic solver parameter selection' diagnostic to 'none'
in the Diagnostics page of the configuration parameters dialog.
> In simlink_inputzidong_cheshu_podu at 81
ans =
 楼主| 发表于 26-4-2011 12:41:22 | 显示全部楼层
出现上述结果是什么原因?
 楼主| 发表于 26-4-2011 12:45:56 | 显示全部楼层
期待高手!
GMT+8, 23-12-2024 08:23 , Processed in 0.306948 second(s), 27 queries .
