  • 1155查看
autolisp二次开发
    发表于 10-3-2011 15:51:46 | 显示全部楼层 |阅读模式
    请问大家我成功加载这个autolisp文件后,为什么在command里面输入命令后,无任何反应呢?我对着书把这两个程序检查了不下十遍,可以说一个字母一个字母的检查,就是发现不了错误。求高手赐教!谢谢
    Autolisp程序如下:
    (defun C:jiancao()
      (setq key 0)
      (dialog)
      (if (= key 1) ((drawing)))
    (defun dialog()
       (setq dcl_id (load_dialog "jiancao.dcl"))
       (if (not (new_dialog "jiancao" dcl_id)) (exit))
       (setq colorlist (list "Black" "Red" " Yellow" "Green" "Cyan" "Blue" "Magenta" "White"))
       (start_list "color" 1)
       (mapcar 'add_list colorlist)
       (end_list)
       (action_title "accept" "(takeout) (done_dialog)")
       (start_dialog)
       (unload_dialog dcl_id)
    (defun drawing()
      (if (= pick 1.0) (setq p0 (getpoint"请用鼠标选插入点(轴心位置) ")))
      (setq ang (atan (* 0.5 a) (sqrt (- (* r r) (* 0.5 0.5 a a)))))
      (setq p1 (polar p0 (- alf ang) r))
      (setq p4 (polar p0 (+ alf ang) r))
      (setq p5 (polar p0 alf (- r b)))
      (setq x5 (car p5))
      (setq y5 (cadr p5))
      (setq x2 (+ x5 (* 0.5 a (sin alf))))
      (setq y2 (- y5 (* 0.5 a (cos alf))))
      (setq p2 (list x2 y2))
      (setq x3 (- x5 (* 0.5 a (sin alf))))
      (setq y3 (+ y5 (* 0.5 a (cos alf))))
      (setq p3 (list x3 y3))
      (command "layer""m""1""")
      (command "pline" p1 p2 p3 p4 "a""ce" p0 p1 "")
      (command "layer""m""hatch-1""c" yanse "hanch-1""")
      (command "hatch""ansi31""5.0""0""1""")
    (defun takeout()
      (setq pick (atof (get_tile "pick_pt")))
      (setq r (atof (get_tile "r")))
      (setq a (atof (get_tile "a")))
      (setq b (atof (get_tile "b")))
      (setq alf (atof (get_tile "alf")))
      (setq yanse (get_tile "color"))
      (setq x0 (atof (get_tile "x0")))
      (setq y0 (atof (get_tile "y0")))
      (setq p0 (list x0 y0))
      (setq key 1)
    DCL对话框设计程序如下:
    dcl_settings:default_dcl_settings {audit_level=0;}
    jiancao:dialog{
      label="绘制带键槽的轴截面图:";
      :row {
             :boxed_column {
               label="截面参数";
               :edit_box {
                  label="轴半径:";
                  key="r";
                  value="10";}
               :edit_box {
                  label="键槽宽:";
                  key="a";
                  value="5";}
               :edit_box {
                  label="键槽深:";
                  key="b";
                  value="4";}
               :edit_box {
                  label="旋转角:";
                  key="alf";
                  value="0";}
             spacer;
             :boxed_column {
               label="填充颜色:";
                 :list_box {
                         key="color";}
           spacer;
        :row {
           label="插入点";
                 :edit_box {
                  label="X轴";
                  key="x0";
                  value="0";}
                 :edit_box {
                  label="Y轴";
                  key="y0";
                  value="0";}
                 :toggle {
                    label="点选插入点&P";
                    key="pick_pt";
                    fixed_width=ture;
                    alignment=centered;}
    spacer;
      ok_cancel;
    发表于 24-3-2011 20:27:31 | 显示全部楼层
    请修改以下几处:
    1、(action_title "accept" "(takeout) (done_dialog)")中的action_title为action_tile;
    2、(command "layer""m""hatch-1""c" yanse "hanch-1""")中的hanch-1为hatch-1;
    3、(command "hatch""ansi31""5.0""0""1""")中的"1"为"l";(L的小写)
    4、(setq ang (atan (* 0.5 a) (sqrt (- (* r r) (* 0.5 0.5 a a)))))应为(setq ang (atan (/ (* 0.5 a) (sqrt (- (* r r) (* 0.5 0.5 a a))))))
    注意:
    程序在运行前要关闭捕捉模式。
    需改进:
    对话框中角度的单位为弧度,使用时不方便。
    GMT+8, 9-1-2025 22:44 , Processed in 0.336522 second(s), 28 queries .
