  • 1289查看
论文摘要——曲柄连杆机构设计
发表于 31-10-2010 11:38:31 | 显示全部楼层 |阅读模式
奥迪A4 2.0T FSI曲柄连杆机构设计
摘要
主要对奥迪A4 2.0T FSI 发动机曲柄连杆机构进行设计,曲柄连杆机构由活塞、活塞环、活塞销、连杆、曲轴和飞轮等零件组成。设计中分别对活塞、活塞销、连杆、曲轴、飞轮和飞轮齿圈进行结构设计,并对曲轴、连杆、活塞销等零件的关键的关键部位进行校核。绘图时还需要利用Auto CAD绘制工程图。
关键词:发动机、曲柄连杆机构、活塞、曲轴。
Abstract
Mainly engine crank link motion gear carries on the design to Audi A4 2.0T the FSI, the crank link motion gear by components and so on piston, piston curl, piston pin, connecting rod, crank and flywheel is composed.In the design separately to the piston, the piston pin, the connecting rod, the crank, the flywheel and the flywheel ring gear carries on the structural design, and to components and so on crank, connecting rod, piston pin key essential spots carries on the examination.When cartography also needs to use Auto the CAD plan engineering plat.
Keyword:Motor、Crank link motion grar、Piston、
Connecting rod
发表于 26-5-2012 15:07:46 | 显示全部楼层
怎么什么都没有啊?
GMT+8, 24-12-2024 00:28 , Processed in 0.287000 second(s), 27 queries .
