  • 1887查看
ANSYS关于接触分析的一个命令流
发表于 28-8-2010 08:37:11 | 显示全部楼层 |阅读模式
关于接触分析的一个命令流,感兴趣的可以自己拿去练习一下,模型建立也许本身不难,只是单元实常数定义之类的比较恼火。
命令流如下:
pressure=33.1
/PREP7
ET,1,PLANE42
!*                                             !定义材料属性
MPTEMP,1,0
MPDATA,EX,1,,127000
MPDATA,PRXY,1,,0.3
MPDATA,MU,1,,0
BLC5,0,-0.49,19,0.98
CYL4,0,50.8,50.8,180,0,360
K, ,-4.75,0,,
K, ,4.75,0,,
K, ,4.75,9.5,,
K, ,-4.75,9.5,,
LSTR,       8,      11
LSTR,      10,      11
LSTR,       9,      10
lsel,s,loc,y,0.1,9.5
asbl,2,all
asel,s,loc,y,10,50.8
adele,all,,,1
allsel,all
numcmp,area
numcmp,line
LESIZE,2,0.1, , , , , , ,1
LESIZE,1,0.2, , , , , , ,1
mshkey,1                                   !设定为用映射网格划分
amesh,1
lsel,s,loc,y,0.5,9.4
LESIZE,all,0.2, , , , , , ,1
allsel,all
lsel,s,loc,y,9.5,9.5
allsel,all
numcmp,kp
amap,2,5,6,7,8                               !一下是log文件里的命令创造接触对
/COM, CONTACT PAIR CREATION - START
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
/GSAV,cwz,gsav,,temp
MP,MU,1,0.5
MAT,1
MP,EMIS,1,7.88860905221e-031
R,3
REAL,3
ET,2,169
ET,3,172
R,3,,,1.0,0.1,0,
RMORE,,,1.0E20,0.0,1.0,
RMORE,0.0,0,1.0,,1.0,0.5
RMORE,0,1.0,1.0,0.0,,1.0
KEYOPT,3,3,0
KEYOPT,3,4,0
KEYOPT,3,5,3
KEYOPT,3,7,0
KEYOPT,3,8,0
KEYOPT,3,9,0
KEYOPT,3,10,1
KEYOPT,3,11,0
KEYOPT,3,12,0
KEYOPT,3,2,0
! Generate the target surface
LSEL,S,,,8
CM,_TARGET,LINE
TYPE,2
NSLL,S,1
ESLN,S,0
ESURF
CMSEL,S,_ELEMCM
! Generate the contact surface
LSEL,S,,,3
CM,_CONTACT,LINE
TYPE,3
NSLL,S,1
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
FINISH
/SOL                                                        !定义边界条件和加力
nsll,s,1
d,all,,,,,,ux,,,,,
allsel,all
lsel,s,loc,x,-9.5,-9.5
nsll,s,1
d,all,,,,,,ux,uy,,,,
allsel,all
lsel,s,loc,y,-0.98,-0.98
nsll,s,1
dl,1,,symm
allsel,all
SFL,5,PRES,pressure,
slove
GMT+8, 23-4-2026 06:42 , Processed in 0.310854 second(s), 33 queries .
