发表于 23-12-2010 05:54:06
显示全部楼层
是一本书,比较专业。贴出目录供大家参考
Overview ix
Coolant Development in Asia—H. EGAWA,Y.MORI, AND M. L. ABEL 1
Heavy Duty Diesel Engine Coolant Technology: Past, Present, and Future—
H. J. DEBAUN AND F. C. ALVERSON 8
Field Test for Carboxylate Inhibitor Levels in OAT Coolants—R. J. PELLET,
L. S. BARTLEY,JR. AND P. O. FRITZ 17
A Comparison of Membrane Technologies for Engine Coolant Recycling—R. HUDGENS,
E. SCHMIDT, AND M. WILLIAMS 26
New Electrochemical Methods for the Evaluation of Localized Corrosion in Engine
Coolants—B. YANG,F.J.MARINHO, AND A. V. GERSHUN 45
Compatibility Testing of Multi-Vehicle Coolant Chemistries—A. P. SKROBUL,
S. L. BALFE, AND F. C. ALVERSON 59
Investigation of Interaction Between Coolant Formulations and Flux Loading/
Compositions in Controlled Atmosphere Brazed (CAB) Aluminum Surfaces in Heat
Exchanger Applications
—C. JEFFCOATE,M.RANGER,J.GRAJZL,B.YANG,P.WOYCIESJES, AND A. GERSHUN 69
Effect of Fluoride on Corrosion of Cooling System Metals in Ethylene Glycol-Based
Antifreeze/Coolants—B. YANG,A.V.GERSHUN,F.J.MARINHO, AND P. M.
WOYCIESJES 77
Heavy-Duty Diesel Engine Cavitation Test
—G. DAVIS AND M. SARLO 87
Component Durability and High Mileage Performance of a Full Carboxylate Coolant
in Heavy Duty Diesel (HDD) Engines—P.O.FRITZ,L.S.BARTLEY,JR.,
R. PELLET,V.MOSER, AND C. ULABARRO 96
Cavitation Protection Performance of Nitrite-Free Organic Acid Based Coolant
for Heavy-Duty Engines—Y. MORI,M.L.ABEL, AND Y. MIYAKE 109
Accelerated Oxidation and Corrosion Testing of Engine Coolants Using a Rotary
Pressure Vessel Oxidation Test—F. C. ALVERSON,S.L.BALFE, AND A. P. SKROBUL 119
Coolants at Elevated Temperatures—S. CLAEYS AND S. LIEVENS 129
Comparison of Bench Test Methods to Elevate Heavy Duty Coolant Thermal
Stability |
