  • 1637查看
卡车仿真出错ADAMS CAR
    发表于 10-7-2010 11:46:09 | 显示全部楼层 |阅读模式
    在仿真过程中出现以下错误,那位大侠能帮我看看,不胜感激!
    --- ERROR ----
       ***** ADAMS MEMORY OVERFLOW *****
       A larger MD array is required.
       The error occurred in subroutine "SYMFAC" while allocating " INTE" space
       from "TEMP" for the "IROW array".
       Space Available:  4250    Space Requested:  27748
       Adams/Solver requires more program memory to run this model.
       Be aware that the above figures for Space available and Space
       requested only reflect the current requirements.  Additional space
       may be required later in the solution process.
       Several off-the-shelf memory configurations are available and
       custom configurations may be created.  The available memory models
       and the corresponding array sizes are:
              NAME         MDSIZ
            STANDARD    1,100,000
            LARGE       3,000,000
            EX-LARGE   20,000,000
            HUGE       60,000,000
       where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
       the main memory array in Adams in words (one word is 4 bytes).
       To use an alternative setting, you have to start the Adams 'Settings'
       program.  It can be found using the Start menu:
         Start -> Programs -> MSC.Software -> Adams -> Adams-Settings
       Terminating Adams/Car usersubs...
          Adams/Solver execution terminated by subprogram MSPACE
    GMT+8, 10-4-2025 19:18 , Processed in 0.312147 second(s), 30 queries .
