  • 1443查看
NVH解释
发表于 5-10-2009 16:11:00 | 显示全部楼层 |阅读模式
Lesson Three
Automobile Noise and Vibration
汽車噪音與振動
I.  Context
A student is curious about automobile noise and vibration problems.  His teacher explains how to diagnose them.
II.  Dialogue
Teacher:        Today, we are discussing automobile noise and vibration.  We hear about NVH very often.  What does it stand for?
Student:        I guess N and V denote “Noise” and “Vibration”, respectively.  I don’t know what H means.
Teacher:         H is the abbreviation of “Harshness”, which is composed of an impact noise and vibration generated when tires are crossing a ramp or a crack.
Student:         Can you tell me how to troubleshoot automobile noise and vibration problems?
Teacher:        First, you need to understand the diagnosis procedure.
Student:        Could you explain it briefly?
Teacher:        First of all, listen and write down customers’ complaints carefully.  Then, judge the possible areas of the malfunction from the complaints.  After that, do test drive.  Finally, choose a suitable diagnosis method.
Student:        What should I be careful about during a test drive?
Teacher:        Pay special attention to vehicle speed, engine rpm and shift gear position of the transmission.
Student:        There are many diagnosis methods.  Can you name some of them?
Teacher:         The most common methods are the auscultation method, the change-load method, sticking tape to the suspected chink, as well as squeezing and shaking the suspected area.  OK, now its my turn to ask you some questions.
Student:        Please.
Teacher:        What is the unit for noise?
Student:        Decibels (dB).
Teacher:        Correct.  If one noise has a sound level
        of 60 decibels and another is 70, do these two noises together
        have the strength of 130 decibels?
Student:        Of course not.  If decibels could be added directly, then there would be so much noise in the environment, and our ear drums would break.
Teacher:        Good.  Could you give some examples of automobile noise and vibration?
Student:        Engine noise, tire noise, wind noise, exhaust noise, and steering wheel shake, etc.
Teacher:        Terrific.
Student:        Today, I have learned some basic knowledge about diagnosis of automobile noise and vibration problems.  Thank you.
III.  Vocabulary and Terminology
1.         vibration (n.) 振動
        The vibration of the car was making me sick.
          車子的振動讓我感覺不舒服。
Newr shock absorbers can reduce vibration of the vehicle.
新避震器能降低汽車的振動。
2.         troubleshoot (v.) 排除
It is important to learn how to troubleshoot problems.
        學習如何排除問題是很重要的。
3.         diagnosis (n.) 診斷
Doctors have to be careful with their diagnosis.
          醫生必須小心的診斷。
IV.  Sentence Patterns
1.         Of course not …當然不是
   Of course not, if lizards were mammals they would not lay eggs.
   當然不是,如果蜥蜴是哺乳類動物牠們就不會下蛋。
2.         Today, … 今天…
   Toady, I went to the zoo and saw many animals.
          今天我去動物園並看了許多動物。
发表于 19-10-2009 11:57:35 | 显示全部楼层
看不懂有中文版吗
GMT+8, 7-5-2026 09:23 , Processed in 0.482166 second(s), 35 queries .
