  • 2033查看
[求助] 请教板簧后悬架双轮跳动仿真错误?
发表于 29-5-2009 16:15:41 | 显示全部楼层 |阅读模式
板簧后悬架双轮平行跳动仿真,出现下列错误,不明白是什么意思,请高手指教:
Reading in property files...
Reading of property files completed.
Setting up assembly for analysis of loadcase: 'parallel_travel'...
Writing analysis information to ADAMS/Solver command file: 'a_parallel_travel'.
Simulation(s) are beginning...
   *                 MSC.Software Corporation                   *
   *                  A D A M S / S o l v e r                   *
   *      Automatic Dynamic Analysis of Mechanical Systems      *
   *      2009-05-29 15:07:13              Version 2005.2.0     *
   Enter ADAMS model file name or Carriage Return or ? (or STOP):
   No model input file (ADM file) is given.
   Enter Command:
   file/model=a_parallel_travel
   A new model supplied.  Initialization starts...
   The default input and analysis values will be restored.
   CPU time used = 0.27039 seconds
   ADAMS/Car 2005.2.0
   ID = 1
   Enter ADAMS output file name or ? (default is same as input):
     ADAMS model file .. a_parallel_travel.adm
   Default file names for output files
     Tabular output file:
     a_parallel_travel.out
     Diagnostic file    :
     a_parallel_travel.msg
     Message Database file    :
     a_parallel_travel.mdb
     Graphics file      :
     a_parallel_travel.gra
     Request file       :
     a_parallel_travel.req
     Results file       :
     a_parallel_travel.res
   Input Phase - Reading in Model
   ADAMS/Solver dataset Title:
   ADAMS/Car Assembly (v2005.2.0)
ERROR:  The MARKER referenced by ID number does not exist.
ERROR:     Value               : 114
ERROR:     Argument            : J
ERROR:     Statement           : JOINT/33
ERROR:     Line number         : 1918
ERROR:     Value               : 119
ERROR:     Argument            : J
ERROR:     Statement           : JOINT/34
ERROR:     Line number         : 1924
ERROR:  Errors in the MSC.ADAMS dataset prevent it from being loaded into the database.
   Reading of model complete.
   Input Phase - Populating Solver database
---- ERROR ----
   Error(s) found in input, no model available.
   Input Phase Complete.
   CPU time is 0.10014 seconds.
---- ERROR ----
   An error has been found in the model dataset supplied
   through the FILE/MODEL command.  Dataset file name is:
   Enter Command:
   control/ routine=acarSDM::con950, function=user(950)
---- ERROR ----
   No model is present in memory at this instant.
   Read in an ADAMS/Solver data set first.
   Enter Command:
   simulate/static, end=16.000000, steps=15
---- ERROR ----
   Enter Command:
   Enter Command:
   stop
   Terminating ADAMS/Car usersubs...
   ID = 1
   ADAMS/Solver execution terminated by subprogram A3TERM
   CPU time used = 0.11016 seconds
Loading analysis results...
ERROR: Cannot load results!  File 'a_parallel_travel.res' not found.
ERROR: Cannot load requests!  File 'a_parallel_travel.req' not found.
ERROR: Cannot load graphics!  File 'a_parallel_travel.gra' not found.
Loading results done.
GMT+8, 27-2-2025 20:12 , Processed in 0.528297 second(s), 35 queries .
