  • 1676查看
  • 7回复
发动机冷却系统水套有限元分析--ANSYS应用
发表于 2-5-2009 09:09:15 | 显示全部楼层 |阅读模式
[ 摘 要 ] 本文首先提出三种不同发动机冷却系统水套的设计方案,并通过UG对其进行精确建模。根据汽缸对称性及相邻汽缸温度相同截取1/2截面建立力学模型,同时加载水套边界条件,利用软件仿真计算出不同形式水套的稳态热分析。然后对不同冷却系统水套进行热应力、X轴方向应力、Y轴方向应力和剪应力分析,并对结果进行讨论,最后可选择出较好的设计方案。
[ 关键词 ] 发动机冷却系统,稳态,有限元方法,热应力
The FEA for Water Jackets in the Engine Cooling System
Liu Xintian 1, Liu Changhong 2,Tan Jingyi 2,Huang Hu 2
(1. School of Mechanical Engineering, Shanghai Jiaotong University, Shanghai, 200030;
2. College of Automobile Engineering, Shanghai University of Engineering Science, Shanghai, 200336)
[Abstract] This paper firstly brings forward three different designs for water jackets in the engine cooling system, and exactly builds their models by UG. According to the symmetry of the cylinder and the same temperature between the cylinders, secondly, the 1/2 section is intercepted and the mechanics model can be established. Thirdly, the boundary conditions are loaded. The steady-state can be simulated with ANSYS. Then the thermal stress, X-axis stress, Y-axis stress and shearing strength for water jackets in the engine cooling system can be attained. Based on the thermal stress analysis and the discussion of the three different water jackets, finally the better design can be selected.
[Key words] engine cooling system; steady-state; FEM; thermal stress.
1 引言
发动机冷却系统是汽车的重要组成部分之一,冷却系统的作用是使发动机在各种转速和各种行驶状态下都能有效的控制温度,其中水套是整个冷却系统的关键部分。当发动机工作产生大量的热量时,充满循环水的水套将发挥降温的功能,并对整个汽缸的散热起到
发动机冷却系统水套有限元分析.rar
412.73 KB, 下载次数: 40, 下载积分: 积分 -1
发表于 7-5-2009 20:56:25 | 显示全部楼层
这样的资料 怎么没有人顶
抢个沙发
发表于 17-5-2011 20:46:17 | 显示全部楼层
这个资料很不错
发表于 27-5-2011 13:01:27 | 显示全部楼层
下来看看~~
发表于 2-8-2011 23:17:27 | 显示全部楼层
谢谢,这个资料对目前的工作似乎很有帮助。
发表于 2-8-2011 23:20:25 | 显示全部楼层
好像我下不了啊,郁闷。
发表于 6-8-2011 11:57:01 | 显示全部楼层
是论文形式的,不适合初学者
发表于 1-9-2011 21:16:47 | 显示全部楼层
是英文的么?
GMT+8, 20-4-2026 03:55 , Processed in 0.451449 second(s), 42 queries .
