  • 1143查看
Robotic Welding
发表于 8-11-2008 18:52:11 | 显示全部楼层 |阅读模式
If an auto part is not welded well by a robot, I will check items of robotic welding system in
automation cell:
1. Current/Voltage parameters of robot's torch/tips
2. Feeder (for arc welding)
3. Presure of tips (for spot welding)
4. Power supply of welding machine
5. Calibrate TCP
6. The gap between torch/tips and the part, maybe reteach the position of robot with a
teach pendant
7. Contact size of welding tips, maybe they are worn out
8. Time (Welding time and Stop time)
9. The surge of voltage
10. Quality of welding material
11. Welding velocity
12. Angle of welding torch/tips
13.Weave condition (frequency and amplitude) for arc welding
what else?
Thanks
GMT+8, 26-11-2024 22:19 , Processed in 0.250948 second(s), 27 queries .
