  • 5284查看
螺紋標準大全
发表于 12-9-2008 06:02:13 | 显示全部楼层 |阅读模式
公制粗螺纹                                公制细螺纹
规格        标准径        最大        最小        规格        标准径        最大        最小        规格        标准径        最大        最小
M1.0*0.25        0.75        0.785        0.729        M1.0*0.2        0.8        0.821        0.783        M15*1.0        14        14.353        13.917
M1.1*0.25        0.85        0.885        0.829        M1.1*0.2        0.9        0.921        0.883        M16*1.5        14.5        14.676        14.376
M1.2*0.25        0.95        0.985        0.929        M1.2*0.2        1        1.021        0.983        M16*1.0        15        15.153        14.917
M1.4*0.3        1.1        1.142        1.075        M1.4*0.2        1.2        1.221        1.183        M17*1.5        15.5        15.676        15.376
M1.6*0.35        1.25        1.321        1.221        M1.6*0.2        1.4        1.421        1.383        M17*1.0        16        16.153        15.917
M1.7*0.35        1.35        1.421        1.321        M1.7*0.2        1.45        1.5        1.46        M18*2.0        16        16.21        15.835
M1.8*0.35        1.45        1.521        1.421        M1.8*0.2        1.6        1.621        1.583        M18*1.5        16.5        16.676        16.376
M2.0*0.4        1.6        1.679        1.567        M2.0*0.25        1.75        1.785        1.729        M18*1.0        17        17.153        16.917
M2.2*0.45        1.75        1.888        1.713        M2.2*0.25        1.95        1.985        1.929        M20*2.0        18        18.21        17.835
M2.3*0.4        1.9        1.979        1.867        M2.3*0.25        2.05        2.061        2.001        M20*1.5        18.5        18.676        18.376
M2.5*0.45        2.1        2.138        2.013        M2.5*0.35        2.2        2.221        2.121        M20*1.0        19        19.153        18.917
M2.6*0.45        2.2        2.238        2.113        M2.5*0.35        2.2        2.246        2.186        M22*2.0        20        20.21        19.835
M3.0*0.5        2.5        2.599        2.459        M3.0*0.35        2.7        2.721        2.621        M22*1.5        20.5        20.676        20.376
M3.0*0.6        2.4        2.44        2.28        M3.5*0.35        3.2        3.221        3.121        22*1.0        21        21.153        20.917
M3.5*0.6        2.9        3.01        2.85        M4.0*0.5        3.5        3.599        3.459        M24*2.0        22        22.21        21.835
M4.0*0.7        3.8        3.422        3.242        M4.5*0.5        4        4.099        3.959        M24*1.5        22.5        22.676        22.376
M4.0*0.75        3.25        3.326        3.106        M5.0*0.5        4.5        4.599        4.459        M24*1.0        23        23.153        22.917
M4.5*0.7        3.8        3.878        3.688        M5.5*0.5        5        5.099        4.959        M25*2.0        23        23.21        22.835
M5*0.8        4.2        4.334        4.134        M6.0*0.75        5.3        5.378        5.188        M25*1.5        23.5        23.676        23.376
M5*0.9        4.1        4.17        3.98        M6.0*0.5        5.5        5.55        5.4        M25*1.0        24        24.153        23.917
M6*1.0        5        5.153        4.917        M7.0*0.75        6.3        6.378        6.188        M26*1.5        24.5        24.676        24.876
M7*1.0        6        6.153        5.917        M7.0*0.5        6.5        6.55        6.4        M27*2.0        25        25.21        24.735
M8*1.25        6.8        6.912        6.647        M8.0*1        7        7.153        6.917        M27*1.5        25.5        25.676        25.376
M9*1.25        7.8        7.912        7.647        M8.0*0.75        7.3        7.378        7.188        M27*1.0        26        26.153        25.735
M10*1.5        8.5        8.676        8.376        M8.0*0.5        7.5        7.52        7.4        M28*2.0        26        26.21        25.835
M11*1.5        9.5        9.676        9.376        M9.0*1        8        8.153        7.917        M28*1.5        26        26.676        26.376
M12*1.75        10.3        10.24        10.106        M9.0*0.75        8.3        8.378        8.188        M28*1.0        27        27.153        26.917
M14*2.0        12        12.21        11.835        M10*1.25        8.8        8.912        8.647        M30*3.0        27        27.252        26.752
M16*2.0        14        14.21        13.835        M10*1.0        9        9.153        8.917        M30*2.0        28        28.21        27.835
M18*2.5        15        15.144        15.294        M10*0.75        9.3        9.378        9.188        M30*1.0        28        28.676        28.376
M20*2.5        17        17.744        17.294        M10*0.5        9.5        9.52        9.4        M32*2.0        30        29.153        28.917
M22*2.5        19        19.744        19.294        M11*1.0        10        10.153        9.917        M32*1.5        30        30.21        29.835
M24*3.0        21        21.252        20.752        M11*0.75        10.3        10.378        10.188        M33*3.0        30        30.676        30.376
M27*3.0        24        24.252        23.752        M12*1.5        10.5        10.676        10.376        M33*2.0        31        30.252        29.752
M30*3.5        26.5        26.771        26.211        M12*1.25        10.8        10.912        10.647        M33*1.5        31.5        31.21        30.835
                                M12*1        11        11.153        10.917        M35*1.5        33.5        33.676        31.376
                                M12*0.5        11.5        11.523        11.4        M36*3.0        33        33.252        32.752
                                M14*0.5        12.5        12.676        12.376        M36*2.0        34        34.21        33.835
                                M14*1.0        13        13.153        12.917        M36*1.5        34        34.676        34.376
                                M15*1.50        13.5        13.676        13.376
 楼主| 发表于 12-9-2008 06:02:59 | 显示全部楼层
公制细螺纹                                 公制标准螺纹
规格         标准径        2级螺纹内径                规格         标准径        1级-2级螺纹内径
                上限        下限                        上限        下限
M1*0.25        0.75        0.785        0.729        M1*0.20        0.8        0.821        0.783
M1.1*0.25        0.85        0.885        0.829        M1.1*0.20        0.9        0.921        0.883
M1.2*.25        0.95        0.985        0.929        M1.2*0.20        1        1.021        0.983
M1.4*0.3        1.1        1.142        1.075        M1.4*0.20        1.2        1.221        1.183
M1.6*0.35        1.25        1.321        1.221        M1.6*0.20        1.4        1.421        1.383
M1.7*0.35        1.35        1.421        1.321        *M1.7*0.20        1.45        1.5        1.46
M1.8*0.35        1.45        1.521        1.421        M1.8*0.20        1.6        1.621        1.583
M2*0..4        1.6        1.679        1.576        M2*0.25        1.75        1.785        1.729
M2.2*0.45        1.75        1.838        1.713        M2.2*0.25        1.95        1.985        1.929
M2.3*0.4        1.9        1.979        1.867        *M2.3*0.25        2.05        2.016        2.001
M2.5*0.45        2.1        2.138        2.013        M2.5*0.35        2.121        2.221        2.121
M2.6*0.45        2.2        2.238        2.113        *M2.6*0.35        2.2        2.246        2.186
M3*0.5        2.5        2.599        2.459        M3*0.35        2.7        2.721        2.621
*M3*0.6        2.4        2.44        2.28        M3.5*0.35        3.2        3.221        3.121
M3.5*0.6        2.9        3.01        2.85        M4*0.50        3.5        3.599        3.459
M4*0.7        3.3        3.422        3.242        M4.5*0.50        4        4.099        3.959
*M4*0.75        3.25        3.326        3.106        M5*0.50        4.5        4.599        4.459
M4.5*0.75        3.8        3.878        3.688        M5.5*0.50        5        5.099        4.959
M5*0.8        4.2        4.334        4.134        M6*0.75        5.3        5.378        5.188
*M5*0.9        4.1        4.17        3.93        *M6*0.5        5.5        5.55        5.4
M6*1        5        5.153        4.917        M7*0.75        6.3        6.378        6.188
M7*1        6        6.153        5.917        *M7*0.50        6.5        6.55        6.4
M8*1.25        6.8        6.912        6.647        M8*1.0        7        7.153        6.917
M9*1.25        7.8        7.912        7.647        M8*0.75        7.3        7.378        7.188
M10*1.5        8.5        8.676        8.376        *M8*0.50        7.5        7.52        7.4
M11*1.5        9.5        9.676        9.376        M9*1.0        8        8.153        7.917
M12*1.75        10.3        10.441        10.106        M9*0.75        8.3        8.378        8.188
M14*2        12        12.21        11.835        M10*1.25        8.8        8.912        8.647
M16*2        14        14.21        13.835
M18*2.5        15.5        15.744        15.249
M20*2.5        17.5        17.744        17.249
M22*2.5        19.5        19.744        19.249
M24*3        21        21.252        20.752
M27*3        24        24.252        23.752
M33*3.5        29.5        29.771        29.211
M36*4        32        32.27        31.67
M39*4        35        35.27        34.67
M42*4.5        37.5        37.779        37.129
M45*4.5        40.5        40.779        40.129
M48*5        43        43.279        42.587
发表于 30-10-2008 11:31:34 | 显示全部楼层
发表于 31-10-2008 19:40:08 | 显示全部楼层
不怎么看得懂
发表于 24-4-2010 11:26:48 | 显示全部楼层
LZ太有才了,我看的都有点眼花,敲的辛苦啊~
发表于 17-9-2011 21:07:33 | 显示全部楼层
楼主太厉害了
GMT+8, 27-1-2025 14:22 , Processed in 0.301815 second(s), 28 queries .
