  • 2529查看
有没有哪位高手知道的ZSt-37-2是什么材料?
发表于 6-8-2008 22:21:40 | 显示全部楼层 |阅读模式
请问ZSt37-2(1.0519)是什么材料,是德国的标准,谢谢!
发表于 6-8-2008 22:22:12 | 显示全部楼层
STEEL GRADE - High grade steel and plain refined steels
                  - Cold and bright drawn able, foldable
1.0159      ZSt 37-2
BB 24
SAW flux, fluoride-basic type
BB 25
BB 33 M
SAW flux, aluminium-rutile-type
BF 16
SAW flux, manganese-silicate-type
BW VII
rod for gas welding, mild steel
BW XII
EMK 6
GMAW solid wire, mild steel
EMK 6 (GTAW)
GTAW rod, mild steel
EMK 7
EMK 8
EML 5
EMS 2
SAW wire mild steel
EMS 2 // BB 24
SAW wire/flux-combination, mild steel
EMS 2 // BB 25
EMS 2 // BB 33 M
EMS 2 // BF 16
EMS 3
SAW wire, mild steel
EMS 3 // BB 24
EMS 3 // BB 25
EMS 3 // BB 33 M
SAW wire / flux-combination, mild steel
EMS 3 // BF 16
FOX CEL
SMAW stick electrode for vertical-down welding, cellulosic coated, pipe welding
FOX CEL 75
SMAW stick electrode for vertical-down welding, cellulosic coating, pipe welding
FOX CEL Mo
SMAW stick electrode for vertical-down welding cellulosic cating, pipe welding
FOX ETI
SMAW stick electrode milde steel, rutile-coated
FOX EV 47
SMAW  stick electrode, mild steel basic-coated
FOX EV 50
SMAW stick electrode mild steel, basic-coated
FOX EV 50-A
FOX EV 50-AK
SMAW stick electrode mild steel, rutile-basic-coated
FOX EV 50-W
FOX EV 51
FOX EV 55
FOX HL 160 Ti
SMAW stick electrode mild steel, high efficiency
FOX HL 180 Kb
FOX HL 180 Ti
SMAW stick electrode mild steel , high efficiency
FOX MST
SMAW stick electrode mild steel, rutile-cellulosic-coated
FOX MSU
FOX OHV
FOX SPE
FOX SPEM
SMAW stick electrode mild steel , rutile-basic-coated
FOX SUM
SMAW stick electrode mild steel, rutile-coated
FOX SUS
FOX TIS
FOX TMF
FOX UNA
HL 50-FD
GMAW flux cored wire, mild steel, metal-cored
HL 52-FD
Kb 52-FD
GMAW flux cored wire, mild steel, basic type
Ti 52-FD
GMAW flux cored wire, mild steel, rutile type
专业的,看不懂
发表于 6-8-2008 22:22:17 | 显示全部楼层
2L的确实太专业了,看不懂,还是3L的帮助大些,谢谢了
发表于 6-8-2008 22:22:21 | 显示全部楼层
ZSt37-2为非合金钢
根据联邦德国工业标准(din)钢铁产品牌号的表示方法中:
z : 可拉伸
st:以材料强度表示(仅用于非合金钢)
37:抗拉强度下限值
2:弯曲或顶锻
GMT+8, 23-12-2024 04:29 , Processed in 0.206805 second(s), 27 queries .
