  • 4227查看
304不锈钢是哪国标准?
发表于 6-8-2008 21:41:27 | 显示全部楼层 |阅读模式
有谁知道304不锈钢是哪国标准?
发表于 6-8-2008 21:41:50 | 显示全部楼层
美国AISI标准相当与国内0Cr18Ni9
发表于 6-8-2008 21:41:54 | 显示全部楼层
AISI Type 304
Category  Steel
Class  Stainless steel
Type  Austenitic standard
Common Names  Chromium-Nickel steel
Designations  France: AFNOR Z 6 CN 18.09
Germany: DIN 1.4301
Italy: UNI X 5 CrNi 18 10
Japan: JIS SUS 304
Sweden: SS 2332
United Kingdom: B.S. 302 S 17 , B.S. 304 S 15 , B.S. 304 S 16 , B.S. 304 S 18 , B.S. 304 S 25 , B.S. 304 S 40 , B.S. En.58 E
United States: AMS 5501 , AMS 5513 , AMS 5560 , AMS 5565 , AMS 5566 , AMS 5567 , AMS 5639 , AMS 5697 , ASME SA182 , ASME SA194 (Type 8) , ASME SA213 , ASME SA240 , ASME SA249 , ASME SA312 , ASME SA320 (B8) , ASME SA358 , ASME SA376 , ASME SA403 , ASME SA409 , ASME SA430 , ASME SA479 , ASME SA688 , ASTM A167 , ASTM A182 , ASTM A193 , ASTM A194 , ASTM A213 , ASTM A240 , ASTM A249 , ASTM A269 , ASTM A270 , ASTM A271 , ASTM A276 , ASTM A312 , ASTM A313 , ASTM A314 , ASTM A320 , ASTM A368 , ASTM A376 , ASTM A409 , ASTM A430 , ASTM A473 , ASTM A478 , ASTM A479 , ASTM A492 , ASTM A493 , ASTM A511 , ASTM A554 , ASTM A580 , ASTM A632 , ASTM A651 , ASTM A666 , ASTM A688 , FED QQ-S-763 , FED QQ-S-766 , FED QQ-W-423 , FED STD-66 , MIL SPEC M.IL-S-5059 , MIL SPEC MIL-F-20138 , MIL SPEC MIL-S-23195 , MIL SPEC MIL-S-23196 , MIL SPEC MIL-S-862 , MIL SPEC MIL-S-862 , MIL SPEC MIL-T-6845 , MIL SPEC MIL-T-8504 , MIL SPEC MIL-T-8506 , SAE 30304 , SAE J405 (30304) , UNS S30400
发表于 6-8-2008 21:41:57 | 显示全部楼层
一般说是日本牌号,参照JIS G4312和4305标准
发表于 6-8-2008 21:42:01 | 显示全部楼层
是日本或美国标准,一般美国的304可以表示为AISI304,日本的304可表示为SUS304
    难过
    2-2-2016 21:26
    发表于 6-7-2012 12:10:10 | 显示全部楼层
    楼上解释很清晰
    GMT+8, 22-12-2024 21:12 , Processed in 0.329977 second(s), 27 queries .
