  • 2703查看
【寻找】金的弹性模量和屈服强度
发表于 22-6-2008 08:00:18 | 显示全部楼层 |阅读模式
【寻找】金的弹性模量和屈服强度
如果有塑性变形以后的应力应变数据,我将激动得非要请他吃饭不行!!!!!!
发表于 22-6-2008 08:00:23 | 显示全部楼层
Gold
Au
Click here to return to Periodic Table
Find products containing this material in the following form:  All Foil Insulated Wire Lump Mesh Microfoil Microleaf Powder Rod Single Crystal Sphere Sputtering Target Tube Wire Search
General Description: This metal has been known since prehistoric times
Gold is a soft metal with a characteristic yellow color. It is the most malleable and ductile of any element. It is unaffected by air, water, alkalis and acids, with the exception of "aqua regia", HNO3/HCl. The fact that it is chemically unreactive means that it is often found in its natural state. It is a good thermal and electrical conductor and has excellent reflective properties to both light and infrared. It has an abundance in the earth's crust of 0.0011 ppm.
Most of the metal is retained for use as bullion reserves, but some is used within the electronics and jewellery industries, where it is frequently alloyed with other elements to improve the mechanical properties of the metal (e.g. copper and silver). Other uses for the metal are as a heat reflecting coating for glass as well as as a decorative medium.
Atomic Properties
Atomic number 79
Atomic radius - Goldschmidt ( nm ) 0.144
Atomic weight ( amu ) 196.9665
Crystal structure Face Centered Cubic
Electronic structure Xe 4f14 5d10 6s1
Ionization potential No. eV
  1 9.22
  2 20.5
Natural isotope distribution Mass No. %
  197 100
Photo-electric work function ( eV ) 4.8
Thermal neutron absorption cross-section ( Barns ) 98.8
Valences shown 1,3
Electrical Properties
Temperature coefficient ( K-1 ) 0.0040 @ 0-100C
Electrical resistivity ( μOhmcm ) 2.20 @ 20C
Thermal emf against Pt (cold 0C - hot 100C) ( mV ) +0.74
Mechanical Properties
Material condition Soft Hard Polycrystalline
Bulk modulus ( GPa )   171
Hardness - Vickers 20-30 60
Poisson's ratio   0.42
Tensile modulus ( GPa )   78.5
Tensile strength ( MPa ) 130 220
Yield strength ( MPa )  205
Physical Properties
Boiling point ( C ) 3080
Density ( g cm-3 ) 19.30 @ 20C
Melting point ( C ) 1064.4
Thermal Properties
Coefficient of thermal expansion ( x10-6 K-1 ) 14.1 @ 0-100C
Latent heat of evaporation ( J g-1 ) 1738
Latent heat of fusion ( J g-1 ) 64.9
Specific heat ( J K-1 kg-1 ) 129 @ 25C
Thermal conductivity ( W m-1 K-1 ) 318 @ 0-100C
不错,看来Daniel1588是费了一番功夫在网上找了这些资料!
不过我也有一些参考数据,跟你找的出入不大,仅供参考,由MathCAD提供:
Linear Expansion Coefficient 14.2e6
Modulus of Elasticity 7.446e10Pa
可是资料中很少给出应力应变曲线,特别是塑性变形以后的应力应变数据,这个可能就需要做实验了!
发表于 22-6-2008 08:00:24 | 显示全部楼层
非常感谢maliang_co2和Daniel1588的热心帮助,小弟在华中科技大学,EMAIL:fanzhuzi@peoplemail.com.cn,有事联系我。
GMT+8, 22-2-2025 22:15 , Processed in 0.516801 second(s), 37 queries .
