  • 2823查看
pro/e3.0安装问题
    发表于 17-6-2008 20:36:43 | 显示全部楼层 |阅读模式
    3.0安装问题
    安装许可证出现上述提示.打开C:\Program Files\flexnet\licensing\ptclmgrd.log,内容如下:
    17:16:55 (lmgrd) --
    17:16:55 (lmgrd)   Please Note:
    17:16:55 (lmgrd)
    17:16:55 (lmgrd)   This log is intended for debug purposes only.
    17:16:55 (lmgrd)   In order to capture accurate license
    17:16:55 (lmgrd)   usage data into an organized repository,
    17:16:55 (lmgrd)   please enable report logging. Use Macrovision's
    17:16:55 (lmgrd)   software license administration  solution,
    17:16:55 (lmgrd)   FLEXnet Manager, to  readily gain visibility
    17:16:55 (lmgrd)   into license usage data and to create
    17:16:55 (lmgrd)   insightful reports on critical information like
    17:16:55 (lmgrd)   license availability and usage. FLEXnet Manager
    17:16:55 (lmgrd)   can be fully automated to run these reports on
    17:16:55 (lmgrd)   schedule and can be used to track license
    17:16:55 (lmgrd)   servers and usage across a heterogeneous
    17:16:55 (lmgrd)   network of servers including Windows NT, Linux
    17:16:55 (lmgrd)   and UNIX. Contact Macrovision at
    17:16:55 (lmgrd)   www.macrovision.com for more details on how to
    17:16:55 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
    17:16:55 (lmgrd)   for your enterprise.
    17:16:55 (lmgrd)
    17:16:55 (lmgrd) --
    17:16:55 (lmgrd)
    17:16:55 (lmgrd)
    17:16:55 (lmgrd) pid 692
    17:16:55 (lmgrd) "chengqiang": Not a valid server hostname, exiting.
    17:16:55 (lmgrd) Valid license server system hosts are: "chengqiang.domain"
    17:16:55 (lmgrd) Using license file "C:\Program Files\flexnet\licensing\license.dat"
    其中倒数第三行错误提示:说什么主机名错误,其实我在编辑licnse时,用的是chengqiang.domain啊,应该不会错,因为,没有.domain系统不执行安装.
    还有我用的是XP-SP2.
    发表于 17-6-2008 20:36:59 | 显示全部楼层
    不防按下面的方法试试吧:
    必须采用浮动安装:1:填入PTC HOST ID用Crack目录下的注册机keygen算出一个授权文件,(keygen必需复制到硬盘才可以使用)(PTC HOST ID可在安装PRO/E界面上找到)
    2:安装PTC License Server,并使用由第1步生成的那个授权文件。不要改变目录。
    3:重新启动电脑。(一定要重启,我吃了好几次亏,不重启就会提示不适用于这个版本)
    4:安装Pro/Engineer Wildfire 3.0,授权类型选择Single Server license type(单机服务器)做为Pro/e授权方式。然后填写你的"your computer name"(电脑名可在安装PRO/E界面上找到)作为Hostname。(填写位置在7788数字前面那个空白框框内)
    经试验,锁定安装不可用.
    补充说明:安装前一定要虚拟网卡。具体方法可参照本戏列其它proe版本的安装说明。
    经试验,锁定安装不可用.
    补充说明:安装前一定要虚拟网卡。具体方法可参照本戏列其它proe版本的安装说明。但愿回想往事,对生活不感到负疚!
    旗下业务:论坛采集器┊ 域名注册┊空 间购买┊I DC服务┊多资源空间┊服务器合租
    使用,您可以瞬间建立一个拥有 庞大内容的网站。其丰富的规 则模板,全自动采集时得心应手。从现在开始,你可以抛弃过去重复乏味 的手工添 加工作! 站 :http:// 下载 。您现 在使用的软 件为 试用版本,  注册为
    GMT+8, 21-2-2025 19:13 , Processed in 0.516147 second(s), 34 queries .
