governor type 调节器式
grain boundary 晶粒号
grain size number 莱氏体
graphical symbol 标志
graphical symbol 识别标志
Gravimeter 重力计
Gross Vehicle Weight 车辆总重
ground Clearance 离地间隙
Ground-Contact Section and Contact Pressure 接地部位及接地压力
grouped lamp 组合灯
grouped, combined or reciprocally incorporated lamps 组合、复合或混合灯光组
guarantee by manufacturer 百分比抽样检查
halogen headlamp 卤素头灯
halogen sealed-beam unit (HSB unit) 卤素封闭式(HSB)
handle assy. , door I/S 车门内手柄总成
handle assy. , door O/S 前门外手柄总成
handle, liftgate lock 举升门锁芯手柄
handle, window regulator 玻璃升降器手柄
HANDLING PROCEDURE 管理规程
handling 处理办法
hanger 调耳
harmonization of standards 标准法
harmonized stndard 统一标准
harness 线束
harness, body 车身线束
harness, engine housing 发动机仓线束
harness, lift gate 尾门线束
hatch-back 掀背型
Hazard Warning Lamps 危险报警闪光灯
head form 头部模型
head performance criterion 头部性能指标
Head Restraint 头枕
head room probe 头部空间探测杆
head 缸盖
Headlamp cleaner 前照灯清洗器
headlamp dimmer switch 变光开关
headlamp switch 前照灯开关
Headlight tester 前照灯试验器
Heat Resistance Test 耐热性试验
heat-damage 热损害
heated hydrogen flame ionization detector 加热式氢火焰离子化检测器
heater & A/C panel lamp 暖风/空调开关灯
heater 加热器
heater, intake manifold 进气歧管加热器
heating-up time 穿透加热
Heavy oil 重柴油
hereinafter referred to as 下文称为
Hereinafter the same 下文同
hi-beem indicator lamp 组合仪表远光指示灯
high idle speed 高怠速
high pressure gas 高压气体
high range 高档
High-floor that can be opened in three ways 三向开启的高地板
High-floor 高地板
High-Pressure Gas Transport Devices 高压气体运输装置
hip angle quadrant 臀部角度量角器
hoist 举升
hold in winding 保持线圈
holddown pin 拉紧销钉
holddown spring 压紧弹簧
holding 奥氏体化
hole ladder type 带孔梯式
homogeneity of drafting 互换性
honeycomb cell axes 蜂窝单元轴
honeycomb ribbon axis 蜂窝条纹轴
horn relay 喇叭继电器
horn switch 喇叭按钮
Horns 喇叭
hose assy. , power steering return 动力转向回油管总成
hose assy. , power to pump 油罐到泵的油管总成
hose, coolant recover 冷却液回收管
hose, radiator inlet 散热器进水软管
hose, radiator to water pump 散热器至水泵软管
hose, thermostat to intake minifold 节温器至进气歧管软管
hot air 热空气
hot curing varnish 漆包线漆
hot idle mode 热怠速状态
hot idle screw 热怠速调整螺钉
housing assy. 壳总成
housing clutch 离合器壳
housing end plug 壳体端盖
housing, steering gear 转向器壳体
H-point pivot H点支轴
H-point sight button H点标记钮
HP微机 PC HP
hub & bearing assy. 轮毂与轴承总成
hub cap 车轮盖
hub gear 齿毂
hub range shift 换档毂
hub sleeve No 2 二号毂套
humidity correction factor 湿度修正系数
hydraulic tappet 液力挺柱
hydraulic type 液力式
Hydrocarbon measuring instrument 碳氢化合物分析仪
Hydrogen flame ionization detector 氢火焰离子化分析仪
hydrogen-relief annealing 深冷处理(冷处理)
Hyge滑车架 hyge sled fixture
I#厂房 I# shop
I/S locking rod 内锁止拉杆
I/S release rod 内开启拉杆
ICE与ISO间的联络 liaison between IEC and ISO
identical standard 国际协调标准
Identification Code 标记
idle fuel tube 怠速油管
idle fuel way 怠速油道
idle jet 怠速喷口
idle mixture screw 怠速混合气调整螺钉
idle tube 怠速油管
idling operation 怠速工况
Idling Speed 怠速
IEC/ISO 协议 IEC/ISO agreement
ignition coil type 点火线圈类型
ignition coil 点火线圈
ignition controler 点火控制器
ignition key 点火钥匙
ignition module 点火控制器
ignition point 燃点
ignition switch 点火开关
Ignition System 点火系
ignition wire 点火线
II号厂房 II # shop
Illuminating axis 光照轴
illuminating surface 透光面
Illumination angle 入射角
Illumination intensity 光照强度
Illumination of the retro-reflecting device 回复反射装置的照度
illuminations actually measured 实测照度
Illuminometer 照度计
IMPACT REDUCTION OF INSIDE REARVIEW MIRRORS 缓冲式室内后视镜
IMPACT REDUCTION TYPE OUTSIDE REARVIEW MIRRORS 缓冲式后视镜
Impact test 冲击试验
Impactor 碰撞块
import licence system 定额管理
IMPORTED MOTOR VEHICLE 进口机动车
impregnating resin 烘干漆
in connection with 与…有关
inclination angle 倾斜角
indicating section 指示部分
indicator lamp 指示灯
indirectly controlled wheel 间接控制车轮
Infant-carrying vehicles 幼儿专用车
information retrieval 触发电路
information work of standards 标准体系
information 资料
informative annex 标准的附录
inhibited oil 电负性气体
inhibiter 表面活性剂
initial choke valve clearance 初始阻风门间隙
initial inspection 初始检验
injection moulding 浸渍
Injection Nozzle 喷油嘴
Injection Pump 喷油泵
injector 喷油器
inlet hole 进气孔
inlet hose 进风口
inlet opening 进油口
inlet tube 进油管
inlet valve 进油阀
Inner Dimension 内部尺寸
inner quality standard 企业标准
inner shaft 内半轴
inner tube 内胎
input shaft 输入轴
input shaft, tranmission 变速器输入轴
inspection by certificate 合格质量检查
Inspection equipment 检验设备
inspection 不定期检验
inspecton body 许可证
inspecton of quality conformity 仲裁性质质量监督
install panel 安装板
instrument cluster 组合仪表(盘)
instrument harness 仪表板线束
instrument illumination lamps 组合仪表照明灯
instrument panel assy. 仪表板总成
instrument panels 仪表板
insulaion resistance 表面电阻率
insulating aterial 介质
insulating varnish 浸渍树脂
intake and exhaust device 进排气装置
intake duration 进气持续角
intake heater 进气加热器
intake silencer 进气消声器
intake valve timing 进气门定时
intake valve 进气门
integral place 整数
integral power steering 整体式动力转向器
integral type 整体式
integrated standardization 标准
intended performance 估计使用期
inter shaft assy. 动力转向中间轴总成
Intercooler 增压中冷器
interface standard 有关应提供数据的标准
intermediate axle shaft 中间半轴
intermediate guide 中间导向器
intermediate shaft 中间轴
internal fan 内风扇
international commerce agreement 国际商事仲裁
international commerce arbitration 对外贸易
international standard 地区标准
international standardization organization 标准机构
international standards organization 权力机构
international system of units(SI) 极限值
interpolated value 内插值
In-Use Motor Vehicles 在用车辆
isothermal transformation 退火
ISSUANCE OF NOTICE 通知书的发放
Issuance 发放
ist idle jet 第一怠速空气量孔
Items 项
I形发动机 I-engine
JAIA 日本汽车进口商协会
JAMA 日本汽车制造商协会
Japan Automobile Importers' Association 日本汽车进口商协会
Japan Automobile Manufacturers Association 日本汽车制造商协会
Japan Automobile Standards Internationalization Center 日本汽车标准国际化中心
Japanese Automobile Type Approval Handbook 日本车辆型式认证手册
Japanese Industrial Standards 日本工业标准
jeep 吉普车
Jiko No. 自公第…号通告
JIS 日本工业标准
Jisei No. 自整第…号
Jisha Circular 自车第…号通告
Jiyu No. 自运第…号
joint technical committee 联合技术规划委员会
joint working group 特别小组
journal cross assy. 十字万向节总成
JTPC 国家团体
jump, spark wire 高压电线
J型转弯试验 test of J turn
katakana 片假名
key 键
kick-type 反冲式
Kinematic viscosity 运动粘度
kingpin caster angle 主销后倾角
Kingpin inclination angle 主销内倾角
kingpin sidewise inclination angle 主销内倾角
knee angle quadrant 膝部角量角器
knock 敲击
Koshin No. 交审第xx号
kraft capacitor paper 钢纸(硫化纤维低)
kraft paper 电容器纸
labelling 语言
laboratory assessment 实验室评定者
laboratory assessor 认可的实验室的试验报告
laboratory certification 自愿认证制
laboratory qualification 实验室认证
labour hygiene standard 零部件标准
labour protectig standard 劳动卫生标准
lamination coating 纤维材料
lamp switch, 4WD 四轮驱动灯开关
lamp type 灯式
language 格式
Lap belt anchorages 腰带固定装置
Large-Sized Rear Reflex Reflectors 大型后回复反射器
Large-sized special 大型专用
latch assy. , front RH. Door 右前门锁总成
latch assy. , rear RH. Door 右后门总成
lateral level 横向水平仪
layout 图纸上的文字书写
leading shoe 领蹄
Leaf spring 片簧
left fog lamp 左雾灯
left headlamp 左前照灯
left horn 左喇叭
left steering 左转向
left tail lamp 左尾灯
legal body (person, entity) 名牌产品
legislation 自行认证
Length of trochoid 旋轮线
Length, Width and Height 全长、全宽、全高
Lens 配光镜
lens, cluster 表蒙
let in air 进气
letter symbol 注释
lettering on drawing 印刷用手稿
levels of standards 标准化档案
lever assy. , turn signal standard 综合开关操纵杆总成
licence 申请人
lifetime of product 及时地
lift gate 举升门
liftgate assy. 举升门总成
liftgate latch assy. 举升门锁总成
liftgate lock assy. 举升门锁芯总成
light source module 光源模组
Light Vehicles 轻型车辆
Light-Exposure and Light-and-Water-Exposure Apparatus 光线暴露及光线与水暴露设备
lighting device 照明装置
Lighting System 照明系统
light-van 小型货车
Limit towards blue 趋蓝极限
Limit towards red 趋红极限
limiting value 极限与配合
limiting valve body 限压阀壳体
limiting valve spring 限压阀弹簧
limits and fits 本地值
limousine 豪华轿车
Linearity error 线性误差
link assy. of front stabilizer 前稳定杆连杆总成
linkage type 联杆式
Liquefied Petroleum Gas-Fueled 燃用液化石油气机动车
load cell simulator 载荷传感器模拟装置
load sensing device 负载感受装置
Loaded goods 装载物
Loading Capacity 载重量
Loading platform offset 货箱偏移量
Loading platform 货箱
local heat treatmetn 预备热处理
Local Land Transport Office 地方陆运署
Local Office 地方署
local value 可能性
Location of business place 业务场所地点
lock CYL assy. , RH. door 右车门锁芯总成
lock piece, reverse gear 换档器锁片
locking & indexing plate 锁止刻度盘
Locking Device 锁止装置
Locking system 锁止装置
long axis 长轴
long-body 长车身
longitudinal center 纵向中心
longitudinal centerline 纵向中心线
longitudinal plane 纵向平面
longitudinally-mounted 纵向安装
loss index 介质损耗因数
low fuel warning indicator bezel 低燃油报警灯框
low fuel warning indicator lens 低燃油报警灯透片
low fuel warning module 低燃油报警组件
low idle system 低怠速系统
low range lock plate 抵挡锁止板
low range 抵挡
low speed jet 低速喷口
lower control arm 下控制臂总成
lower pressure switch 低压开关
lubricant capacity 润滑油加注油
lubricants 润滑油
lubricating system 润滑系
luminance factor 亮度因数
luminous flux 光通量
luminous intensity 光照强度
L形发动机 L-engine
L形燃烧室 L-combustion chamber
M / CYL / vacuum booster assembly 制动主缸及真空助力器总成
M/CYL push rod 主缸推杆
Magnification 增大率
mail car 邮车
main bearing journal clearance 主轴承间隙
main bearing journal diameter 主轴承轴径
main bearing journal width 主轴承宽度
main bearing 主轴承
main body, connector 化油器中体
main fuel system & vacuum reriched system 主油系及真空加泷系统
Main honeycomb block 主蜂窝块
main jet 主量孔
main oil gallery 主油道
main spring 主簧
mainfold presure 歧管压力
mainfold vacuum 歧管真空
Make and type 厂牌和型号
Management supervisor 主管人
mandatory standard 推荐性标准
manual transmission 手动变速器,手排挡变速箱
MANUFACTURER TEST 制造者试验
Manufacturer 制造者
manuscript for printing 乘号
mapping curve 瞬态性能曲线
mapping 瞬态性能
mark of acceptable product 合格证书
mark of conformity certification 合格品标志
mark of conformity 合格认证
mark of conformity 认证体系的利用
mark of safety certification 强制性认证
marker lamp, left front 左前示廓灯
marker lamp, right front 右前示廓灯
marking ,sign 熵
martensite 渗碳体
mass flow rate 质量流动速率
master cylinder and vacuum booster 制动主缸及真空助力器
master cylinder body 制动主缸缸体
master cylinder cover 制动主缸缸盖
master cylinder 制动主缸,总泵,刹车总泵
mate 合笼
matrix 晶界
max gas direct 混合器走向
max. amps 最大电流
MAX. power 最大功率
Max. torque 最大扭距
Maximum Loading Capacity 最大载重量
maximum out-of round(all journals) 最大不圆度(所有轴径)
maximum output 最大功率
Maximum Stable Inclination Angle 最大稳定倾斜角
maximum taper(all journals) 最大锥度(所有轴径)
Maximum Torque 最大扭矩
Measuring equipment 度量装备
Measuring tape 卷尺
mechanical steering 机械转向器
median seating plane 座椅中心面
medical treatment and epidemics prevention vehicle 医疗防疫车
meeting document.会议报告
meeting report 分委员会成员身分
member of certification system 批准
membership of SCs 技术委员会成员身分
membership of TCs 纪要
metal heat treatmetn 整体热处理
metallographic examination 相变点
Meter 仪表
metering rod arm assy. 计量杆摇臂总成
metering rod arm 计量杆摇臂
metering rod 计量杆
metering valve 限流阀,限压阀
mica splitting 陶瓷绝缘材料
mica 合成云母
micro-air direct 微量空气走向
microphone 话筒
Middle density foam rubber 中密度泡沫橡胶
min. output voltage at 1000r/min 1000r/min 最小输出电压
min. rpm 最小转速
Minimum Ground Clearance 最小离地间隙
Mini-sized 微型
mini-sized motor vehicle 小型机动车
Minister of Land, Infrastructure and Transport 国土交通大臣
Ministry of Land, Infrastructure and Transport 国土交通省
Ministry of Transport Ordinance 运输省令
Ministry of Transport 运输省
minutes 反对票
mirror for immediate front obstacle 前邻障碍观察镜
MLIT 国土交通省
Mobile deformable barrier 移动变形壁障
mobile mail car 邮政车
mobile telephone car 无线电车
mode of operation 耐热等级
modification 更改
Motor vehicle category 机动车类别
Motor Vehicle Inspection and Registration Office 机动车检验和注册署
Motor Vehicle 机动车
Motor Vehicles Carrying Dangerous Articles 危险用品运输车
Motor Vehicles Carrying Gunpowder 火药类运输车
Motor Vehicles for Passenger Carrying Business 客运车
Motor Vehicles for Road Maintenance 道路维修作业车
Motor Vehicles with Gas-Transporting Containers 装备气体运输容器的机动车
motor, front axle vacuum 真空马达
motor-driven cycle 摩托车
mounting bracket 安装支架
moving contactor 活动触盘
muffler assembly 消声器总成
multilateral arrangemetn 互利
multilaterally harmonized standard 双边协调标准
multilingual international standard 国际标准
multiple sampling 分层抽样
multiplication sign 铭牌
multistage sampling 二次抽样
multi-stress 诊断因子
mutatis mutandis 已作必要的修正
Name or Designation of Applicant 申请者姓名或名称
Name or Designation 姓名或名称
name-plate 分委员会编号
national and equal treatment 合格及有关的通用概念
national body 分委员会
national standard 部标准
national standard 地方标准
national standardization plan 行业计划
national standards body 地区标准组织
national technical committee for standardization 世界标准日
National Traffic Safety and Environment Laboratory 日本国家交通安全与环境实验室
national treatment 国家和平等待遇
NDIR 不分光红外线分析仪
needle bearing 滚针轴承
needle pin 针销
negative vote 成员
new edition 登记
new field of technical activity 准备阶段
new work item proposal 技术活动新领域提案
nitriding medium 洗涤剂
nitriding 渗硼
no load test with 11.5 volts 11.5V 空载试验
No. of sheets issued 发放份数
No.1 compression 1号气环
Noise Control Device 噪声控制装置
Noise level meter 声级计
Noise level test 噪声级试验
noise level 噪声级
noise 噪声
Nomenclature 名称
Nominal mass 名义质量
nondispersive infrared analyzer 不分光红外线分析仪
nonperiodic inspection 抽样检验
non-tarrif barrier 关税壁垒
normal operating pressure 正常工作压力
normal working 正常工作状态
normative annex 技术勘误表
normative reference 产品标准
not gate 禁止门
not if them gate 与门
Notation 注释
notchback 客货两用车
note 附录编号
Notice of Completion of Notification 完成认可通知书
notice 通知书
NOTIFICATION 认可
notified motor vehicle 获得认可的机动车
Number of cylinders 缸数
Number Plate Lamp 牌照灯
number 数字
numbering of annex 条款编号
numbering of clause 单元与分单元编号
numbering of division and subdivision 文件编号
numbering of document. 公式编号
numbering of equation 图表编号
numbering of figure 脚注编号
numbering of footnote 注释编号
numbering of note to table nad figue 部分编号
numbering of note 图表注释编号
numbering of part 章节编号
numbering of SCs 技术委员会编号
numbering of section 分条款编号
numbering of subclause 列表编号
numbering of table 符号
numbering of TCs 数码
numeral 数值
numerical value 校样
nut 螺母
nut, connecting rod 连杆螺母
nut, front output shaft 前输出轴螺母
nut, jack sealed 插座螺母
observer 最高执行官办公室
Observing angle 观测角
Observing axis 观测轴
Observing plane 观测平面
occupation standard 技术标准
odograph 记录仪
office of CEO P-成员
OFFSET COLLISION 侧面碰撞
Offset 偏置量
oil control 油环(槽)
oil control rail 刮油环
oil fill plug 注油螺塞
oil filter assy. 机油滤清器总成
oil filter 机油滤清器
oil gallery 油道
oil pan 油底壳
oil path, bypass valve 旁通阀油道
oil pressure gauge calibration 电压表电阻
oil pressure gauge 油压表
oil pressure relief 溢流压力
oil pressure sensor 机油压力传感器
oil pressure switch 油压开关
oil pump & inlet assy. 机油泵与进油管总成
oil pump assy. 油泵总成
oil pump 机油泵
oil resistance 耐燃性
oil seal 油封
oil soaked closing magnetic path model 油浸闭磁路式
OK range 合适范围
onboard diagnostic device 车载诊断设备
on-board diagnostic 车载诊断
opacimeter 不透光式烟度计
Open Flame Sunshine Carbon-Arc Type 明焰日光碳弧灯型
Opening roof 天窗
operating system 算法
Operation conditions 运行状态
Operational Limits 运行参数
operations research 情报检索
or gate 文件管理
Ordinary-sized 普通型
O-ring, seal O型油封
Outer diameter 外径
outer tube 外胎
outlet of combined pump 复合泵出油口
outlet opening 出油口
outlet valve 出油阀
outlet 出油口
Outline Marker Lamps 示廓灯
overall dimensions 外形尺寸
overall view 透视图
overhead hoist 吊运装置
Overhead valve 顶置气门
overrunning clutch 单向啮合器
P/S pump MTG bracket 动力转向泵安装支架
packaging standard 标志标准
pad 衬块
panel damper 仪表板风门
Paper tape recorder 纸带记录仪
Paragraph 项
park brake level 停车制动拉臂
park brake switch 手制动开关
park lamp, left front 左前小灯
park lamp, right front 右前小灯
parking brake cable 驻车制动拉线
parking brake lever 驻车制动操纵杆
Parking Brake System 驻车刹车系统
Parking Brake 驻车制动器
parking lamp 驻车灯
parking switch 手制动开关
Partial flow dilution 分流稀释
participant in certification system 认证体系的成员
particulate matter 颗粒物
parts of heating & air conditioning system 暖风系统部件
part-subassemble standard 试验标准
Passenger Accommodation 乘坐装置
passenger airbag deactivation system 乘客气囊禁用系统
Passenger Capacity and Maximum Loading Capacity 乘员定员及最大载重量
Passenger capacity 乘车定员
passenger compartment 乘客舱
passing beam 近光光束
Pattern 样式
pc overlay, gauges 仪表印刷电路板
pc overlay, tell-tales 指示灯印刷电路板
PCV and LTC system 发动机强制通风与低温怠速控制系统
PCV exhaust tube PCV 阀排气管
PCV filter PCV (阀)滤清器
PCV PCV 阀
PCV valve & elbow PCV 阀与弯头
PCV阀 PCV valve
pearlite 渗氮剂
Pelvic angle 骨盆角度
pelvis performance criterion 骨盆性能指标
Penetration resistance test 抗穿透性试验
percent sampling inspection 不合格判定数
performance standard 政府标准
performs stamping/embossment 打刚印/铸凸字
period of validity 安全标志
periodic inspection 交收检验
peripheral equipment 编排
permanent magnet 永久磁铁
personnel 职工
Phase delay time of a data channel 数据通道的相位延迟时间
Phase delay time 相位延迟时间
photometric characteristics 光学特性
PH值 PH value
PH值 PH value
pickling agent 防锈剂
pickup coil 点火信息传感器
pickup position 感受位置
pin package, sector 扇形板定位销组件
pin 定位销
ping 爆声
pinion seal 主动齿轮油封
pinion yoke 主动齿轮叉
pinion 驱动齿轮,主动齿轮
pintle hooks 铰链销吊钩
pintle valve seat 针阀座
pintle valve 针阀
piping system 管系
piston (second) 活塞(第二活塞)
piston assy. 压差阀柱塞总成
piston displacement 活塞总排量
piston oil slot 活塞油槽
piston pin 活塞销
piston ring gap clearance-compression 气环开口间隙
piston ring gap clearance-oil control 油环开口间隙
piston ring groove height 活塞环槽高度
piston ring side clearance 活塞环侧隙
piston ring 活塞环
piston rod 挺杆
piston slide 压差阀活塞滑套
piston spring 柱塞弹簧
piston stroke 活塞行程
piston to bore clearance 活塞与缸套间隙
pitman arm 转向摇臂
pitman shaft 摇臂轴
pivot assembly 枢轴
planet carrier 行星架
planet pinion shaft 行星(齿轮销)轴
planet pinion 行星齿轮
planetary gear assy. 行星减速器总成
planetary gear system 行星齿轮装置
plasma heat treatment 形变热处理
plasticizer 填料
plate 盘
plate, park brake guide 停车制动导向板
plug (活塞端)堵
plunger cap 挺杆座
plunger return spring 柱塞弹簧
plural tanks 多燃料箱
PM 颗粒物
P-member 会议日程安排
PNEUMATIC TIRES 气压轮胎
polarization current 介电常数
pole trailer 长材拖车
police car 警车
police vehicle 警车
Position Lamp 位置灯
position pin 定位销
possibility 规程
pot life working life 储存期
power booster 助力器
power brake 助力制动,动力刹车器
power distribution center 动力分配中心
power steer 动力转向机
power steering control valve 动力转向控制阀
power steering fluid 动力转向液
power steering gear 动力转向器(总成)
power steering principle view 动力转向原理示意图
power steering pump with intergral reservoir 动力转向泵
power steering pump without intergral reservoir 分体式动力转向泵
power steering system 动力转向系
power steering 动力转向器
Power Train 动力传动系
power transformer substation 配电站
power transmitting 力传递方向
powertrain system 传动系统
preceding quarter 上季度
pre-delivery 发车前准备
Preferential handling 优惠管理
Preferentially handled imported motor vehicle 符合优惠管理的进口机动车
Preliminary inspection 预备检验
Preliminary Review 预审
preparaton of normative document. 标准计划
preparatory stage 建议阶段
pre-silencer 前消声器
press board 薄纸板
press paper 云母
pressure cap 压力水箱盖
Pressure Container 耐压容器
Pressure Containers 压力容器
pressure difference valve piston 压差阀活塞
pressure hose assy. 动力转向压力管总成
pressure plate spring 弹簧
pressure plate 压力板
pressure rating 标点压力
pressure restrict valve 限压阀
pressure valve 压力阀
prestandard 协调标准
primary wire connector 低压线连接器
principal item 主要项目
procedure 程序
Procedure 规程
procedure 可靠性
process standard 服务标准
produciton inspeciton 生产定型检验
product approval 产品分等
product classificatin 产品规范
product design 产品质量
product management standard 产品计量单位
product percent of pass 产品系列化
product protection 产品定型
product quality inspection 产品质量监督检验
product quality management 产品质量检验
product quality mark 产品质量标准
product quality standard 产品质量管理
product quality supervision and inspection 产品质量认证标志
product quality 产品合格率
product seriation 产品管理标准
product specification 产品设计
product standard 法规
production approval inspeciton 验收检验
production licence 一致
proficiency testing 次品
program of meeting 工作规划
program of work 进度控制
progress control 项目
project approach 项目领导人
project leader 项目管理
project management 项目阶段
project stage 建议
proof voltage 定量(标重)
proof 文号
propeller ahaft & wheel assembly 传动轴与车轮总成
Propeller shaft type 传动轴型
Propeller Shaft 传动轴
proportioning device 比例装置
proposal for new field of technical activity 引用标准
proposal of the plant I layout 1号厂房工艺布置方案图
proposal stage 出版阶段
protect panel 护板
Protective system 防护系统
provincial standard 予标准
proving ground 试验场地
provision 规定
Pubic Symphysis Peak Force 耻骨结合点力峰值
public institute 公立研究所
publication stage 工作组文件
pull in winding 吸拉线圈
pull rod 推杆
pulley 皮带轮
pulley, P/S pump 动力转向泵皮带轮
pulley, power steering pump 动力转向泵皮带轮
pump assy. , power steering 动力转向泵
pump housing (油泵)壳体
pump ring 定子
pump shaft bearing 轴承
pump shaft seal 油泵轴油封
pump shaft 转向泵轴,油泵轴
push bar 推杆
push rod 挺杆
pushin bumper 牌照板缓冲快
Q21-5B冲型剪机 Q21-5B stamping and shearing machine
Qualification status 资格状况
quality arbitration 质量保证体系
quality assessment 质量保证
quality assurance system 质量检验阶段
quality assurance 评价型质量监督
quality control 质量体系
quality diagnosis 质量指标
quality index 质量仲裁
quality inspection 质量控制
quality inspecton phase 质量评定规则
quality loop 质量标准
quality management 质量监督
quality standard 质量管理
quality supervision for approval 全面质量管理
quality supervision for arbitration 产品保护
quality supervision 质量检验
quality system 质量诊断
quality 质量评价
quantitative test 出口管理
quench hardening 预防白点退火
quench-hardened case 调质
quenching and tempering 时效
quota management 非关税壁垒
quoted standard 专业标准
R/S stretching skin ( road side ) 左侧围应力蒙皮
racing car 赛车
rack piston 齿条活塞
Radial load 径向负荷
Radiator 散热器
radiator assy. 散热器总成
radiator pressure cap 散热器盖
Radius of curvature 圆角半径
rated output 额度功率
Ratio of the circumference of a circle to its diameter 圆周率
Raw exhaust 原始排气
RC-12LYC protruding resistance model RC-12LYC突出式电阻器
RC-14YC normal resistance model RC-14YC一般式电阻器
rear axle assy. 后桥总成
rear axle 后桥
rear bearing 后轴承
rear bearing, input shaft 输入轴后轴承
rear bearing, output shaft 输出轴后轴承
rear bearing, rear output shaft 后输出轴后轴承
rear brake assembly 后制动器总成
rear brake line 后制动油管
rear braker assy. 后制动器总成
rear case of vacuum booster 助力器后壳体
rear combined lamps 后组合灯
rear edge 后边缘
rear end of shield 发电机后壳
rear facing child restraint system 儿童转身约束系统
Rear Fog Lamp 后雾灯
rear housing 后壳体
rear opening 出油口
Rear overhang 后悬
rear pinion bearing 后主动齿轮轴承
rear port 后接口
rear propeller shaft assy. 后传动轴总成
rear propeller shaft 后传动轴
rear rear axle 后后桥
Rear Reflex Reflectors 后回复反射器
rear stabilizer 稳定杆
rear suspension 后悬吊
rear thrust plate 后配流盘
rear tube failure 后管路失效状态
Rear Under-ride Bumper 防钻撞后保险杠
Rear Underrun Protection Devices 后下防护装置
rear wall side cover 后围侧板
rear washer pump 后洗涤器泵
rear wheel brake 后轮制动器
rear wheel 后轮
rear wiper motor 后刮水器发动机
rear wiper relay 后刮水器继电器
Rear-End Outline Marker Lamps 后端示廓灯
Rear-view mirror 后视镜
Rearward-facing 面向后的
reciprocally incorporated lamp 混合灯
Reciprocating engine 往复式发动机
reciprocating type 往复式
recirculating pump 再循环泵
recirculating-ball steering gear 回旋滚珠式齿轮
recirculating-ball-plug rack and sector gear style 循环球-柱塞齿条齿扇式
recognition and approval arrangement 承认协议
recognition arrangement 单边协议
recommendation 决议
recommended standard 国家标准
reconditioning 再处理
reconditioning 再生
recur damper 内循环风门
re-doing 返工
Reduction Ratio 减速比
reference axis 基准轴
reference cycle work 基准循环功
Reference data 基准数据
Reference line 基准线
Reference mass 基准质量
reference material 标准学
reference number 表决报告
Reference Point 基准点
reference surface 基准面
reference to standard 参考著作
reference value 参考值
reference works 技术图纸
Reflex Reflector 回复反射器
refrigerant oil 冷冻油
refrigerant 冷媒
refrigerative van 冷藏车
reginal standardization organization 国际标准化组织
reginal standards organization 国际标准组织
regional standard 国家标准
regionally harmonized standard 多边协调标准
registration 编缉性修改
regulator assy. , front RH. Door 右前门玻璃升降器总成
regulator assy., rear RH. Door 右后门玻璃升降器总成
regulatory authorities 认证活动
regulatory authority 执行机构
rejection number 不合格质量水平
rejecton quality level 抽查型质量监督
relative permitivity 介质损耗
Relative time delay 相对时延
Relaxation of regulations 标准的放宽
relay, efe heater 进气加热器继电器
release bearing assy. 分离轴承
release control 释放控制设备
release position 释放状态
Remarks 备注
repeatabilty 预期使用期
report of voting 报导秘书处的情况
reporting of secretariat 再版文本
Requirements 判定标准
reservoir assy. , power steering fluid 动力转向液油罐总成
reservoir-power steering fluid 转向液油罐
resin 绝缘漆
resistor 电阻
resolution 复审国际标准
resonator assy. , exhaust 共振器总成
rest room 更衣室
resultant acceleration 合成加速度
retainer ring 弹簧卡环
retainer 弹簧座,保持架
retainer, choke rod 定位圈
retainer, door lock rods 拉杆保持架
retainer, front door lock CYL. 前门锁芯弹簧卡片
retainer, liftgate lock 举升门锁芯弹簧卡片
retainer, rod end 杆端卡圈
retaining ring 弹簧卡环
retaining ring, thrust plate 配流盘卡环
Retro-reflecting device 回复反射装置
Retro-reflecting optical unit 回复反射光学单元
Retro-reflection coefficient 向后反射系数
Retro-reflection 回复反射
Retro-Reflective Materials 回复反射材料
return opening 回油口
return spring of throttle 节气门回位弹簧
return spring 回位弹簧
return tube 回油管
reverse gear (中间轴)倒档齿轮
reverse gear shaft 倒档轴
reverse shift arm and fork 换档拨叉和拨叉臂
reverse shift fork 换档拨叉
Reversing Lamps 倒车灯
review of international standard 秘书处
Rib Deflection Criterion 肋骨变形指标
Riding Accommodation 乘坐装置
right axle shaft 右半轴
right fog lamp 右雾灯
right headlamp 右前照灯
right steering 右转向
rim 轮辋
ring gear , rear axle drived 被动齿轮
ring gear back face runout 被动齿轮背面圆跳动
ring gear diameter 被动齿轮直径
ring gear 被动齿轮
ring 装饰圈
road roller 压路机
road service car 道路维修车
road stabilizer 道路加固机
Road Transport Bureau 交通局
Road Vehicles Act 道路车辆法
roadster 敞蓬车
rocker arm shaft 摇臂轴
rocker arm, fuel pump 燃油泵摇臂
rod & link assy. 转向拉杆和横拉杆总成
rod, front RH. Door I/S locking 右前门内锁止拉杆
rod, front RH. Door I/S release 右前门内开启拉杆
rod, front RH. Door key CYL 右前门锁芯拉杆
rod, front RH. door O/S release 右前门外开启拉杆
rod, rear door O/S release 后门外开启拉杆 |
