  • 2560查看
最全,最好的ug4.0快捷键
发表于 15-2-2008 18:59:50 | 显示全部楼层 |阅读模式
文件(F)-新建(N)...                  Ctrl+N          UG_FILE_NEW                    Global
文件(F)-打?(O)...                  Ctrl+O          UG_FILE_OPEN                  Global
文件(F)-保存(S)                    Ctrl+S          UG_FILE_SAVE_PART                Global
文件(F)-另存?(A)...                Ctrl+推移+A      UG_FILE_SAVE_AS                Global
文件(F)-??(L)...                  Ctrl+P          UG_FILE_PLOT                  Global
文件(F)-?入(M)-部件(P)...            Ctrl+1          UG_FILE_IMPORT_PART              Global
文件(F)-?入(M)-I-DEAS...              Ctrl+7          UG_FILE_IMPORT_IDEAS_PART          Global
文件(F)-?入(M)-Parasolid...            Ctrl+2          UG_FILE_IMPORT_PARASOLID          Global
文件(F)-?入(M)-NX-2D...              Ctrl+8          UG_FILE_IMPORT_NX2D              Global
文件(F)-?入(M)-CGM...                Ctrl+9          UG_FILE_IMPORT_CGM              Global
文件(F)-?入(M)-STL...                Ctrl+0          UG_FILE_IMPORT_STL              Global
文件(F)-?入(M)-IGES...              Ctrl+3          UG_FILE_IMPORT_IGES              Global
文件(F)-?入(M)-Step203...            Ctrl+4          UG_FILE_IMPORT_STEP203            Global
文件(F)-?入(M)-DXF/DWG(&D)...          Ctrl+5          UG_FILE_IMPORT_DXF              Global
文件(F)-?出(E)-部件(P)...            推移+1          UG_FILE_EXPORT_PART              Global
文件(F)-?出(E)-Parasolid...            推移+2          UG_FILE_EXPORT_PARASOLID          Global
文件(F)-?出(E)-CGM...                推移+9          UG_FILE_EXPORT_CGM              Global
文件(F)-?出(E)-JPEG...              推移+8          UG_FILE_EXPORT_JPEG              Global
文件(F)-?出(E)-TIFF...              推移+7          UG_FILE_EXPORT_TIFF              Global
文件(F)-?出(E)-IGES...              推移+3          UG_FILE_EXPORT_IGES              Global
文件(F)-?出(E)-Step203...            推移+4          UG_FILE_EXPORT_STEP203            Global
文件(F)-?出(E)-DXF/DWG...            推移+5          UG_FILE_EXPORT_DXF              Global
文件(F)-?出(E)-2D ??(2)...          推移+6          UG_FILE_EXPORT_UGTO2D            Global
文件(F)-?行(T)-?形交互?程(Grip)...      Ctrl+G          UG_FILE_RUN_GRIP                Global
文件(F)-?行(T)-Grip ??(D)...          Ctrl+推移+G      UG_FILE_RUN_GRIP_DEBUG            Global
文件(F)-?行(T)-NX 打?...            Ctrl+U          UG_FILE_RUN_UFUN                Global
??(E)-撤?列表(U)-1 ?入"建模"        Ctrl+Z          UG_EDIT_UNDO                  Global
??(E)-粘?(P)                    Ctrl+V          UG_EDIT_PASTE                  Global
??(E)-?除(D)...                  Ctrl+D          UG_EDIT_DELETE                  Global
                              Delete                                    Global
??(E)-??(L)-全?(A)              Ctrl+A          UG_SEL_SELECT_ALL                Global
??(E)-?藏(B)-?藏(B)...            Ctrl+B          UG_EDIT_BLANK_SELECTED            Global
??(E)-?藏(B)-互??示与?藏(R)        Ctrl+推移+B      UG_EDIT_REVERSE_BLANK_ALL          Global
??(E)-?藏(B)-不?藏所?的(S)...        Ctrl+推移+K      UG_EDIT_UNBLANK_SELECTED          Global
??(E)-?藏(B)-?示部件中所有的(A)      Ctrl+推移+U      UG_EDIT_UNBLANK_ALL_OF_PART        Global
??(E)-??(N)...                  Ctrl+T          UG_EDIT_TRANSFORM                Global
??(E)-?象?示(J)...                Ctrl+J          UG_EDIT_OBJECT_DISPLAY            Global
??(E)-曲?(V)-全部(A)...            推移+E          UG_EDIT_CURVE_ALL                Global
??(E)-曲?(V)-修整(T)...            推移+T          UG_EDIT_CURVE_TRIM              Global
??(E)-曲?(V)-裁剪角(C)...            推移+C          UG_EDIT_CURVE_TRIM_CORNER          Global
??(E)-曲?(V)-分割(D)...            推移+D          UG_EDIT_CURVE_DIVIDE              Global
??(E)-曲?(V)-Curve Length...          推移+L          UG_EDIT_CURVE_ARC_LENGTH          Global
??(E)-特征(F)-去除??(V)...          推移+V          UG_MODELING_EDIT_FEATURE_REMOVE_PARAMETERS Global
??(E)-曲面(R)-?大(A)...            Alt+推移+L      UG_MODELING_EDIT_FF_ENLARGE        Global
??(E)-面(A)...                    G            UG_MODELING_EDIT_FACE            Global
??(V)-操作(O)-?放(Z)...            Ctrl+推移+Z      UG_VIEW_ZOOM                  Global
??(V)-操作(O)-旋?(R)...            Ctrl+R          UG_VIEW_ROTATE                  Global
??(V)-操作(O)-截面(C)...            Ctrl+H          UG_VIEW_SECTIONING              Global
??(V)-布局(L)-新建(N)...            Ctrl+推移+N      UG_LAYOUT_NEW                  Global
??(V)-布局(L)-打?(O)...            Ctrl+推移+O      UG_LAYOUT_OPEN                  Global
??(V)-布局(L)-充?所有??(F)          Ctrl+推移+F      UG_LAYOUT_FIT_ALL_VIEWS            Global
??(V)-可?化(V)-高?量?片(H)...        Ctrl+推移+H      UG_VIEW_HIGH_QUALITY_IMAGE          Global
??(V)-信息窗口(I)                  F4            UG_VIEW_INFO_WINDOW              Global
??(V)-重?方位(E)                  Ctrl+F8        UG_VIEW_RESET_ORIENTATION          Global
插入(S)-基准/?(D)-基准平面(D)...        D            UG_MODELING_DATUM_PLANE_FEATURE      Global
插入(S)-基准/?(D)-?(P)...            P            UG_CURVE_ASSO_POINT              Global
插入(S)-基准/?(D)-?集(S)...          Q            UG_CURVE_POINT_SET              Global
插入(S)-曲?(C)-弧/?(C)...            Ctrl+C          UG_CURVE_ASSO_ARC                Global
插入(S)-曲?(C)-基本曲?(B)...          B            UG_CURVE_BASIC_CURVES            Global
插入(S)-曲?(C)-矩形(R)...            推移+R          UG_CURVE_RECTANGLE              Global
插入(S)-曲?(C)-多?形(P)...            推移+Y          UG_CURVE_POLYGON                Global
插入(S)-曲?(C)-螺旋(X)...            推移+H          UG_CURVE_HELIX                  Global
插入(S)-曲?(C)-?律曲?(W)...          推移+W          UG_CURVE_LAW_CURVE              Global
插入(S)-曲?(C)-??(S)...            S            UG_CURVE_SPLINE                Global
插入(S)-曲?中的一?曲?(F)-偏置(O)...    推移+O          UG_CURVE_OFFSET                Global
插入(S)-曲?中的一?曲?(F)-在面上偏置...  推移+F          UG_CURVE_OFFSET_FACE              Global
插入(S)-曲?中的一?曲?(F)-?接(B)...    推移+B          UG_CURVE_BRIDGE                Global
插入(S)-曲?中的一?曲?(F)-?化(S)...    推移+M          UG_CURVE_SIMPLIFY                Global
插入(S)-曲?中的一?曲?(F)-合并(J)...    推移+J          UG_CURVE_JOIN                  Global
插入(S)-曲?中的一?曲?(F)-投影(P)...    推移+P          UG_CURVE_PROJECT                Global
插入(S)-曲?中的一?曲?(F)-?合投影(C)...  推移+N          UG_CURVE_COMBINE                Global
插入(S)-曲?中的一?曲?(F)-??/展?(W)...  推移+Q          UG_CURVE_WRAP                  Global
插入(S)-体的曲?(U)-相交(I)...          推移+I          UG_CURVE_INTERSECT              Global
插入(S)-体的曲?(U)-截面(S)...          推移+S          UG_CURVE_SECTION                Global
插入(S)-体的曲?(U)-抽取(E)...          推移+X          UG_CURVE_EXTRACT                Global
插入(S)-??特征(E)-拉伸(E)...          X            UG_MODELING_EXTRUDED_FEATURE        Global
插入(S)-??特征(E)-回?...            V            UG_MODELING_REVOLVED_FEATURE        Global
插入(S)-??特征(E)-?方体(K)...        K            UG_MODELING_BLOCK_FEATURE          Global
插入(S)-??特征(E)-?柱体(C)...        Y            UG_MODELING_CYLINDER_FEATURE        Global
插入(S)-??特征(E)-??(O)...          O            UG_MODELING_CONE_FEATURE          Global
插入(S)-??特征(E)-球(S)...            R            UG_MODELING_SPHERE_FEATURE          Global
插入(S)-??特征(E)-孔(H)...            Alt+H          UG_MODELING_HOLE_FEATURE          Global
插入(S)-??特征(E)-?台(B)...          Alt+B          UG_MODELING_BOSS_FEATURE          Global
插入(S)-??特征(E)-腔体(P)...          Alt+K          UG_MODELING_POCKET_FEATURE          Global
插入(S)-??特征(E)-凸?(A)...          Alt+D          UG_MODELING_PAD_FEATURE            Global
插入(S)-??特征(E)-Emboss...          Alt+Z          UG_MODELING_NX_EMBOSS_FEATURE        Global
插入(S)-??特征(E)-?槽(L)...          Alt+L          UG_MODELING_SLOT_FEATURE          Global
插入(S)-??特征(E)-?槽(G)...          Alt+G          UG_MODELING_GROOVE_FEATURE          Global
插入(S)-??复制(A)-抽取(E)...          Alt+X          UG_MODELING_EXTRACT_FEATURE        Global
插入(S)-??复制(A)-引用(I)...          I            UG_MODELING_INSTANCE_FEATURE        Global
插入(S)-?合体(B)-并(U)...            Alt+U          UG_MODELING_UNITE_FEATURE          Global
插入(S)-?合体(B)-差(S)...            Alt+S          UG_MODELING_SUBTRACT_FEATURE        Global
插入(S)-?合体(B)-相交(I)...            Alt+I          UG_MODELING_INTERSECT_FEATURE        Global
插入(S)-?合体(B)-?合(W)...            E            UG_MODELING_SEW_FEATURE            Global
插入(S)-Trim-Divide Face...            Alt+J          UG_MODELING_DIVIDEFACE_FEATURE      Global
插入(S)-Trim-合并面(J)...              Alt+Q          UG_MODELING_JOINFACE_FEATURE        Global
插入(S)-Trim-Trim Body...              T            UG_MODELING_TRIM_FEATURE          Global
插入(S)-Trim-分割(P)...              Alt+P          UG_MODELING_SPLIT_FEATURE          Global
插入(S)-Trim-修整片体(R)...            Alt+推移+T      UG_MODELING_FF_TRIMMED            Global
插入(S)-Offset/Scale-Offset Surface...    Alt+V          UG_MODELING_FF_OFFSET            Global
插入(S)-Offset/Scale-偏置面(F)...        Alt+O          UG_MODELING_OFFSET_FEATURE          Global
插入(S)-Offset/Scale-比例(S)...          Alt+A          UG_MODELING_SCALE_FEATURE          Global
插入(S)-Offset/Scale-加厚片体(T)...      F2            UG_MODELING_FF_THICKEN            Global
插入(S)-Offset/Scale-Shell...          H            UG_MODELING_HOLLOW_FEATURE          Global
插入(S)-Offset/Scale-包含几何体(G)...      F3            UG_MODELING_WRAP_GEOMETRY_FEATURE    Global
插入(S)-??特征(L)-?倒?(E)...        Alt+E          UG_MODELING_BLEND_FEATURE          Global
插入(S)-??特征(L)-面倒?(F)...        Alt+F          UG_MODELING_FF_FACE_BLEND          Global
插入(S)-??特征(L)-?倒?(S)...        Alt+推移+F      UG_MODELING_FF_SOFT_BLEND          Global
插入(S)-??特征(L)-?接(B)...          Alt+推移+B      UG_MODELING_FF_BRIDGE            Global
插入(S)-??特征(L)-倒角(C)...          Alt+C          UG_MODELING_CHAMFER_FEATURE        Global
插入(S)-??特征(L)-草?(T)...          Alt+T          UG_MODELING_TAPER_FEATURE          Global
插入(S)-曲面(R)-延伸(X)...            Alt+推移+X      UG_MODELING_FF_EXTENSION          Global
插入(S)-曲面(R)-由四??定的曲面(4)...    Alt+推移+4      UG_MODELING_FF_SURF4P            Global
插入(S)-曲面(R)-通??(H)...            Alt+推移+P      UG_MODELING_FF_THROUGH_POINTS        Global
插入(S)-网格曲面(M)-直?面(R)...        L            UG_MODELING_FF_RULED              Global
插入(S)-网格曲面(M)-通?曲?(T)...        U            UG_MODELING_FF_THROUGH_CURVES        Global
插入(S)-网格曲面(M)-通?曲?网格(M)...    M            UG_MODELING_FF_CURVE_MESH          Global
插入(S)-网格曲面(M)-1x1...            Alt+1          UG_MODELING_FF_STUSRF_1X1          Global
插入(S)-网格曲面(M)-1x2...            Alt+2          UG_MODELING_FF_STUSRF_1X2          Global
插入(S)-网格曲面(M)-2x0...            Alt+3          UG_MODELING_FF_STUSRF_2X0          Global
插入(S)-网格曲面(M)-2x2...            Alt+4          UG_MODELING_FF_STUSRF_2X2          Global
插入(S)-网格曲面(M)-nxn...            Alt+5          UG_MODELING_FF_STUSRF_NXN          Global
插入(S)-网格曲面(M)-截面(S)...          Alt+推移+S      UG_MODELING_FF_SECTION            Global
插入(S)-网格曲面(M)-N ?表面(I)...        Alt+推移+N      UG_MODELING_FF_NSIDED            Global
插入(S)-?描(W)-?描(S)...            W            UG_MODELING_FF_SWEPT              Global
插入(S)-?描(W)-沿?引??描(G)...        Alt+W          UG_MODELING_SWEEP_FEATURE          Global
插入(S)-??曲面(G)-按?律延伸(L)...      Alt+推移+W      UG_MODELING_FF_LAWEXT            Global
插入(S)-直接建模(I)-替?面(R)...        F            UG_MODELING_REPLACE_FACE_FEATURE      Global
格式(R)-?的?置(S)...                Ctrl+L          UG_LAYER_SETTINGS                Global
格式(R)-在??中可?(V)...            Ctrl+推移+V      UG_LAYER_VIEW                  Global
格式(R)-WCS-原?(O)...                Alt+0          UG_WCS_ORIGIN                  Global
格式(R)-WCS-旋?(R)...                Alt+9          UG_WCS_ROTATE                  Global
格式(R)-WCS-方位(N)...                Alt+8          UG_WCS_ORIENT                  Global
格式(R)-WCS-?示(P)                  Alt+7          UG_WCS_DISPLAY                  Global
格式(R)-WCS-保存(S)                  Alt+6          UG_WCS_SAVE                    Global
工具(T)-表?式(X)...                Ctrl+E          UG_INSERT_DLEXPRESSION            Global
工具(T)-日?(J)-播放(P)...            Alt+F8          UG_JOURNAL_PLAY                Global
工具(T)-日?(J)-??(E)              Alt+F11        UG_JOURNAL_EDIT                Global
工具(T)-宏(R)-?始??(R)...            Ctrl+推移+R      UG_MACRO_RECORD                Global
工具(T)-宏(R)-回放(P)...              Ctrl+推移+P      UG_MACRO_PLAYBACK                Global
工具(T)-宏(R)-步?(S)...              Ctrl+推移+S      UG_MACRO_STEP                  Global
信息(I)-?象(O)...                  Ctrl+I          UG_INFO_OBJECT                  Global
信息(I)-?(P)...                    C            UG_INFO_GEOMETRIC_POINT            Global
分析(L)-距离(D)..                  N            UG_INFO_GEOMETRIC_DISTANCE          Global
分析(L)-角度(A)...                  A            UG_INFO_GEOMETRIC_ANGLE            Global
分析(L)-曲?(C)-Refresh Curvature Graphs    Ctrl+推移+C      UG_INFO_MB_SHOW_GRAPHS            Global
分析(L)-??干涉(I)...                Ctrl+X          UG_INFO_ANALYSIS_INTERFERENCE        Global
??置(P)-?象(O)...                Ctrl+推移+J      UG_PREFERENCES_OBJECT            Global
??置(P)-??(E)...                Ctrl+推移+T      UG_PREFERENCES_SELECTION          Global
?用(N)-建模...                    Ctrl+M          UG_APP_MODELING                Global
?用(N)-外?造型??(T)...            Ctrl+Alt+S      UG_APP_STUDIO                  Global
?用(N)-制?(D)...                  Ctrl+推移+D      UG_APP_DRAFTING                Global
?用(N)-加工(N)...                  Ctrl+Alt+M      UG_APP_MANUFACTURING              Global
?用(N)-?配(L)                    Ctrl+Alt+W      UG_APP_ASSEMBLIES                Global
?用(N)-基??境(G)...                Ctrl+W          UG_APP_GATEWAY                  Global
?助(H)-在??助(C)...                F1            UG_HELP_ON_CONTEXT              Global
刷新(S)                          F5            UG_VIEW_POPUP_REFRESH            Global
适合窗口(F)                      Ctrl+F          UG_VIEW_POPUP_FIT                Global
?放(Z)                          F6            UG_VIEW_POPUP_ZOOM              Global
旋?(O)                          F7            UG_VIEW_POPUP_ROTATE              Global
??方向(R)-正二???(T)              Home          UG_VIEW_POPUP_ORIENT_TFRTRI        Global
??方向(R)-正等???(I)              End            UG_VIEW_POPUP_ORIENT_TFRISO        Global
??方向(R)-俯??(O)                Ctrl+Alt+T      UG_VIEW_POPUP_ORIENT_TOP          Global
??方向(R)-前??(F)                Ctrl+Alt+F      UG_VIEW_POPUP_ORIENT_FRONT          Global
??方向(R)-右??(R)                Ctrl+Alt+R      UG_VIEW_POPUP_ORIENT_RIGHT          Global
??方向(R)-左??(L)                Ctrl+Alt+L      UG_VIEW_POPUP_ORIENT_LEFT          Global
捕捉??(N)                      F8            UG_VIEW_POPUP_SNAP_VIEW            Global
GMT+8, 22-12-2024 18:00 , Processed in 0.199672 second(s), 27 queries .
