  • 3082查看
制动衬块-Ceramic Brake Pads[英文]
发表于 26-12-2007 21:09:58 | 显示全部楼层 |阅读模式
Ceramic Brake Pads
Ceramic brake pads are popular with many motorists today because they restore like-new brake performance, are quiet, long lasting, low dusting and provide safe sure stops. They handle heat much better than most nonasbestos organic (NAO) friction materials, and are quieter and kinder to rotors than most semi-metallic friction materials.
Ceramic brake pads first appeared in the early 90’s. Some vehicle manufacturers began using ceramic-based disc brake pads in place of conventional semi-metallic pads to address customer complaints about brake noise, dust and wear. Many of these ceramic pads were supplied by Akebono. Following the OEM lead, Raybestos Brakes, and other major aftermarket brake suppliers introduced their own ceramic-based friction materials. The aftermarket ceramic pads are designed to replace OEM ceramic disc brake pads and to upgrade brake performance on vehicles that were not originally equipped with ceramic-based pads.
HOW CERAMIC PADS DIFFER FROM ORDINARY PADS
One of the main differences between ceramic-enhanced friction materials and semi-metallic brake linings is that ceramic pads contain no steel wool or fibers. Steel provides strength and conducts heat away from rotors, but it also makes pads noisy. Steel also acts like an abrasive and causes rotor wear. Substituting ceramic materials and copper fibers for steel allows ceramic pads to handle the high brake temperatures with less heat fade, to recovery quickly, to experience less wear on both the pads and rotors, and to virtually eliminate noise. Annoying brake squeal is eliminated because the ceramic-enhanced compound dampens noise and moves vibrations to a frequency beyond our range of hearing.
Other features that help make ceramic pads extra quiet include chamfers, slots and insulator shims. These features are also found on other types of pads, but may not be used on all applications.
Chamfers are angled or beveled edges on the leading and trailing ends of the pad that reduce "tip-in" noise when the brakes are first applied. Chamfers also reduce the surface area of the brakes slightly, which increases the clamping force applied by the pads against the rotors. This further helps to dampen sound-producing vibrations.
Slots are grooves cut vertically, diagonally, or horizontally in the pads to reduce noise by changing the frequency of vibration from an audible level to a higher, inaudible frequency beyond the range of the human ear. Slots also help reduce brake fade by providing a passage for gases and dust to escape at high brake temperatures.
Insulator shims provide a dampening layer to absorb and dissipate vibrations before they can cause noise.
CERAMIC PADS REDUCE BRAKE DUST
Another features of ceramic pads is less visible brake dust on the wheels. All brake pads produce dust as they wear. But the ingredients in ceramic pads typically produce a light colored dust that is much less noticeable, and it does not stick to wheels like ordinary brake dust. Consequently, alloy wheels stay cleaner longer.
LONGER PAD LIFE
Ceramic pads also extend brake life compared to most conventional lining materials. Akebono and Raybestos both say their durability testing has shown significantly longer life with no sacrifice in noise control, rotor life or braking performance when ceramic pads are used compared to other friction materials.
CERAMIC PAD APPLICATIONS
Ceramic pads can be installed on any vehicle that is originally-equipped with OEM ceramic pads, or on vehicles that are equipped with Nonasbestos Organic (NAO) linings. Ceramic pads are NOT recommended to replace semi-metallic pads, especially on larger, heavier vehicles. On trucks and large SUVs, semi-metallic linings are typically needed to handle higher loads and braking temperatures.
发表于 4-3-2008 13:43:49 | 显示全部楼层
能读懂的话就下了,。
不错的,增加学习外语的机会和能力:lol
GMT+8, 26-1-2025 15:30 , Processed in 0.370075 second(s), 29 queries .
