  • 15616查看
BMW宝马汽车缩略语
发表于 24-9-2007 20:37:03 | 显示全部楼层 |阅读模式
BMW宝马汽车缩略语
缩写    英文                              中文
AG      Automatic Transmission            自动变速箱(AT)
DK      Throttle Valve                    节气门(TV)
DME     Digital Motor Electronics         数字式引擎控制电脑
DWA     Burglar Alarm                     防盗警报系统
EGS     Electronic Transmission Control   电子变速箱控制系统(EAT)
EKP     Electric Fuel Pump                电动油泵(FP)
EV      Fuel Injector                     喷油嘴
HG      Manual Transmission               手动变速箱(MT)
KD      Kick Down                         强迫降档
KW      Crankshaft                        曲轴
LL      Idle Speed                        怠速
LLS     Idle Speed Control                怠速空气控制阀(IAC)
LMM     Mass Air Flow                     空气流量表(MAF)
MF      Microfilm                         微缩胶片
MV      Solenoid                          电磁阀(SV)
NW      Camshaft                          凸轮轴
RxD     Diagnosing Sensing Line           自诊闪码电路
TD      Speed Signal Once Each Ignition   点火信号(CPS)
TE      Tank Venting                      活性碳罐电磁阀(EEC)
TI      Injection Time                    喷射电子脉波宽度
TL      Partial Load                      部份负荷
TL      Load Signal                       负荷信号
TR      Speed Signal per Revolution       转速信号(CKP)
TD      Diagnosing Data Line              自诊输入触发电路
SG      Control Unit                      电脑盒
U-batt  Battery Voltage                   电瓶供电电压(BU,BV)
U-vers  Power Supply                      系统供应电源(PW)
VL      Full Load                         全负荷
OBC     On-Board Computer                 随车自诊电脑
RPS     Rollover Protection System        翻车防护装置
EML     Electronic Engine Power Control   电子引擎功率控制
LKM                                       灯泡烧毁监控器
TSH                                       中控锁自动加温系统
FH                                        中控电动镜
ZV                                        中控锁系统
SM/SPM                                    电动椅/电动镜记忆系统
SHD                                       电控天窗
SRA                                       大灯清洗器
K/CC                                      仪表资讯简易自诊
IB                                        车内灯光控制器
IHKR-F3                                   电脑恒温系统
BMW Abbreviations
BMW Abbreviations and Acronyms
Throughout your career as a BMW Group Service Technician you will come across many acronyms in the various Technical publications. Even
BMW is an acronym. An acronym is a word formed from the initial letters of a longer word. These are a list of acronyms describing various
systems on BMW Group automobiles and SAVs.
Remember this is only a partial list. The BMW Group is a dynamic company and is always adding new systems to its products. Look for new
systems and acronyms with new Technical Training courses, Service Information, and Technical Information Bulletins.
A      Processed Vehicle Speed
AB    Airbag
ABS  Anti-lock Braking System
ADS   Engine Intake Air Control
ADV W/wiper Pressure Control
AGS Adaptive Transmission Control
AIC Automatic Interval Control (rain sensor)
ARS Active Roll Stabalization
ASC All Season Traction
ASC+T ASC+Traction
ASK Audio System Controller
AST Slip Control (Marketing term)
AUC Automatic Air Recirculation
B Benzene (gasoline)
BC Board Computer
BC1 Body Controller 1
BLS Brake Light Switch
BMBT Board Monitor
BS Block Diagram
BST Battery Safety Terminal
BZM Center Consol Control Center
CAS Car Activation System
CBC Corner Braking Control
CAN-BusController Area Network(bus)
CCM Check Control Module
CIM Chassis Integration Module
CVM Convertible Top Module
CVT Constantly Variable Trans.
D-Bus Diagnosis Bus (same as TXD)
DBC Dynamic Brake Control
DCS Dealer Communication System
DDE Digital Diesel Electronics
DIN German Industrial Standards
DIS Diagnosis and Information System
DISA Differential Air Intake Control
DK Throttle Housing
DKI Throttle Position
DM-TL Diag.Module Tank Leakage
DSC Dynamic Stability Control
DSP Digital Sound Processing
DTC Diagnostic Trouble Code
DWA Theft Deterrent System
DWS Tire Pressure Warning System
EBV Electronic Brake Proportioning
E-KAT Electrically Heated Catalytic Converter
ECM Engine control module (SAE)
EDC Electronic Dampening Control
EDK Electronic Throttle Valve
EH Electronic Hydraulic
EHC Electronic Height Control
EKM Electronic Body Module
EKP Electronic Fuel Pump
ELV Electronic Steering Lock
EM Electro-Mechanical
EME Electro-Mechanical Emergency Brake
EML Electronic Motor Load Regulation
EO Component Location
EPC Electronic Parts Catalog
ETM Elec. Troubleshooting Manual
EWS Electronic Driveaway Protection
FB Function Description
FBZV Radio Frequency Locking
FRU Flat Rate Unit
GAL Speed Dependent Volume
GM General Module
GMR Yaw Moment Control
GRII Cruise Control
GPS Global Positioning System
HDC Hill Decent Control
HFM Hot Film Air Mass Meter
IB Interior lighting Control Signal
I-Bus Information Bus
IHKA Automatic Heating and A/C
IHKR Regulated Heating and A/C
IHKS Standard Heating and A/C
IKE Instrument Cluster Electronics
IR Infrared
ISIS Intelligent Safety Integration System
ISN Individual Serial Number
KAT Catalytic Converter
KATON Converter Heating (signal)
K-Bus Body Bus
KL Terminal Designation
KO Compressor "ON" Signal
KOMBI Instrument Cluster
KOREL Compressor Relay Signal
KW Crankshaft
LCM Lamp Check Module
LDP Leak Diagnosis Pump
LEV Low Emissions Vehicle
LKM Lamp Control Module
LL Closed Throttle
LRA Vertical Headlight Aiming
LSM Steering Column Memory
LSZ Lamp Switching Center
LVA Air Supply System
LWR Vertical Headlight Aiming
LWS 5 Steering Angle Sensor
MBC Maximum Brake Control
MDK Motororized Throttle Valve
MFL Multi-Function Steering Wheel
MEC Multi-Function Controller
MID Multi-Information Display
MoDiC Mobile Diagnostic Computer
MRS Multiple Restraint System
MSR Engine Drag Torque Reduction
NG New Generation
OBD On-Board Diagnosis (SAE)
PB Pin Assignments
P-Bus Periphery Bus
PDC Park Distance Control
PWG Pedal Position Sensor
RDC Tire Pressure Control
RDW Tire Pressure Warning
RM Relay Module
RPW Tire Puncture Warning
RXD Wake-up Diagnosis Line
RZV Direct Stationary Ignition
SB Fuse Assignments
SBE Seat Occupancy Detector
SCA Soft Close Actuator
SG Control Unit
SGS Seat Integrated Belt System
SHD Sunroof Module
SII Service Interval Indicator
SM Seat Module
SP Schematic
ST Connector Views
SZM Central Switch Center Module
TD Engine Speed
ti Injector on time
TL Part Throttle
TLEV Transitional Low Emission Vehicle
TRS Battery Isolation Switch
TSH Door Lock Heating
TU Technical Update
TXD Transmitting Diagnosis Line
VANOS Variable Camshaft Timing
VL Full load - wide open throttle
WK Converter Lock-up Clutch
ZAE Central Airbag Electronics
ZGM Central Gateway Module
ZKE Central Body Electronics
ZV Central Locking System
ZVM Central Locking Module
ZWD Idle Control Valve
A 安培
AAMVA 美国汽车管理人员协会
ABE 一般运行许可
ABS 防抱死系统
ABS/ASC 防抱死系统与自动稳定控制系统
Abt. 部门
ACEA 欧洲汽车制造商协会
ACK 确认
ADAC 全德汽车俱乐部
ADB 自动差速制动器
ADS 有源诊断插头
ADV 压紧力调节
ADW 车身动态调节值
AE 显示单位
AF 代用频率
AG 股份公司;自动变速箱
AGB 副水箱
AGD 进气消音器
AGR 废气再循环
AH 挂车
Ah 安培小时
AHK 后桥调节系统;挂车挂钩
AHPS 高级头部保护系统
AKF 活性碳过滤器
AKS 主动式头枕
AL 近光灯
Al 铝
AM 调幅
AMPS 高级移动电话系统
ANSI 美国国家标准协会
ANZ 显示
AP 工位
API 美国石油协会
APM 高级电源管理
APS 交替驻车位置
ARCNET ARCnet 网络
ARD 德国国营广播电台工作联合会
ASAP 售后服务援助入口;尽快
ASC+T 自动稳定控制系统加牵引力控制装置
ASE 高级安全电子装置
ASIC 专用集成电路
AT 翻新件
ATL 废气涡轮增压器
AU 排放检查
AUC 自动车内空气循环控制系统
AUS 澳大利亚
AW 工时单位
AW-Nr. 工作编号
AWL 安全气囊指示灯
AZ 拧紧力矩
AZD 拧紧力矩
B
B 宽度
BA 使用说明
BC 车载电脑
BF 前乘客侧
BFD 制动减速度显示
BFT 前乘客侧车门
BIT 电话基础接口
Bit/s 位 / 秒
BJ 制造年
BKV 制动助力器
bl 蓝色
BLS 制动信号灯开关
BR 巴伐利亚广播电台
br 棕色
BSD 串行数据接口
C
C2H2F4 聚四氟乙烯
CAD 计算机辅助设计
CAM 计算机辅助制造
CAN 控制器区域网络
CARB 加利福尼亚空间资源管理局
CB 蜂房广播
CBC 弯道制动控制系统
CBS 车况保养
CBT 基于计算机的培训
CC 检查控制;巡航模式;库仑
CD CD 光盘;控制显示
CD-ROM CD 光盘只读存储器
CDN 加拿大车型
CDW CD 光盘转换匣
CE 欧洲委员会
CF2Cl2 二氯二氟甲烷
CH 瑞士
CI 企业视觉形象识别
CIFI 气缸独立燃油喷射
CIP 设码、个性化设置和编程
CKM 车辆和钥匙记忆功能
cm 厘米
CNG 液化气
CO 一氧化碳
CO2 二氧化碳
CR 共轨
CRC 检验总数比较;铜涂料
CVBS 彩色图像消隐同步信号
CVT 型号编码表
D
D 驱动器
DAB 数字音频广播
DBC 动态制动控制系统
DBS 动态制动助力系统
DDE5 数字式柴油机电子伺控系统 5
DDK 旋转按钮
DECT 增强数字式无线通讯
DEL 定界符
DFU 数据远程传输
DI 直接喷射
DIN 德国标准研究院
DIS 诊断信息系统
DISA 可变进气系统
DKP 节气门电位器
DKV 节气门规定值;节气门调节
DMS 文件管理系统;数字式发动机控制;
扭矩减小接口
DMTL 燃油泄漏诊断模块
dohc 双顶置凸轮轴
DPF 柴油滤清器
dpi 每英寸点数
DR 压力调节器
DRAM 动态随机存取存储器
DTC 动态牵引力控制系统
DTMF-Nr. 多频拨号音
DTP 桌面出版系统
DVD 数字多用途光盘
DWA-LED DWA 发光二极管
DWAH 防盗报警系统警笛
DZM 转速表
E
E-OBD 欧洲车载诊断系统
E/A 输入端 / 输出端
EAZ 试车和发货中心
EBA 安装说明
EBS 后座安全带拉紧装置
EBV 电子制动力分配
ECD 电子可调式减速
ECE 欧洲经济委员会
ECO 电控节流孔
ECU 电子车辆控制单元
EDS 电子压力控制阀
EDV 电子数据处理
EEPROM 电可擦写可编程只读存储器
EH 扩展界限
EHPS 电动液压转向助力系统
EHV 防暴玻璃
EKM 车身电子模块
EKS 防夹功能
EMK 电磁力
EMV 电磁相容性
EN 欧洲标准
EO 安装位置
EOF 帧结束
EON 其它增强型网络
EPDW 压力变换器
EPROM 可擦写可编程只读存储器
ER 解除联锁
ESG 单片安全玻璃
ESV 喷油阀
ET 车轮偏置距
ETK 计算机管理零件目录
ETM 电子故障查询手册
EURO 欧洲车型
EUV 电动转换阀
EVG 电子稳流装置
EWD 单绕组旋转调节钮
F
F 法拉
F-CAN 底盘 CAN
F.I.R.S.T. Fully Integrated Road Safety Technology
FA 驾驶员侧;车辆任务
FASTA 车辆运行数据和保养数据的传输和分析
FAT 驾驶员侧车门
FB 遥控器;功能描述
FBAS 彩色图像消隐同步信号
FBD 遥控服务
FBS Fading Brake Support
FCKW 氟氯碳氢化合物
FDC 动态行驶控制
FDR 动态行驶调节
FDS Field Detection System
FET 场效应晶体管
FFB 无线电遥控;后座区遥控器
FGR 定速控制
FH 车窗升降机
FIS 无线电车内防盗监控传感器
FIZ 研发中心
FKC 底盘组件控制
FKS 紧凑型无线电联锁系统
FL 远光灯
FM 调频;新鲜空气风门马达
FPM 加速踏板模块
FS Flash 插头 (MOST 直接接口);故障保险
FSS 无线电联锁系统
FTZ 通信技术总局
FZD 车顶功能中心
FZV 无线电中控锁
G
g 克
GAL 根据车速音量自动调节
GAP 通用访问应用
GAZ 旧汽车中心
GB 英国
GByte 千兆字节
ge 黄色
GF 玻璃纤维
GJ 会计年度
GM 通用发动机
GMPT 通用发动机传动系
gn 绿色
GND 接地
GPS 全球定位系统
gr 灰色
GRAV 减轻重量的铝合金车头
GRL 行李箱照明灯
GRS 偏航角速率传感器
GS 组标准;安全带拉紧装置;变速箱控制
GSM 全球移动通信系统
GT1 Group Tester One
GUI 图形用户界面
GW 保修;极限值;网关
GWK 可调式变矩器离合器
GWSZ 总行驶里程表
GWTZ 保修件中心
H
H 高度;亨
h 小时
HA 后桥
HAG 后驱动桥
Hall-IC Hall 集成电路
HB 代理商比较
HC 碳氢化合物
HD 高压,生产日期
HDC 下坡车速控制
HF 高频
HFM 热膜式空气质量计
HG 总成分组
HHS 后窗加热装置
HIC 头部碰撞系数 (Head Impact Coefficient)
HiFi 高保真
HK 后行李箱盖
HKA 冷暖空调
HKM 后行李箱盖模块
hl 左后
HLI 热线信息
HLM 热线式空气质量计
HO 代理商机构
HP 液压压力;高功率;马力
hPa 百帕
hr 右后
HSV 高压控制阀
HTML 超文本标记语言
HUS 热线支持系统
HVA 液压阀门间隙补偿
HVBG 工商业同业工伤事故保险联合会总会
HW 硬件;硬件热交换器
HWB 代理商和修理厂需求
HW 暖风热交换器
Hz 赫兹
I
i. A. 受委托
i. V. 代表
IBS 智能型蓄电池传感器
IC 集成电路
ID 身份识别
IDC 诊断和设码信息
IDES 交互式信息和诊断系统
IFS Inter Frame Space
IHKR 自动恒温空调
IMSI 国际移动设备识别
IR 红外线
IRIS 集成式收音机和信息系统
IRZV 红外线中控锁
ISD 集成式流体阻尼器
ISDN 综合业务数字网
ISIS 智能型全面安全系统
ISM 工业、科研、医疗
ISN 各个控制单元号码
ISO 国际标准化组织
IT 信息处理
ITS 充气管状结构
IV 信息处理
IVM 集成供电模块
IWV 脉冲拔号法
IWZ 重复修理频率
J
J 焦耳
JAP 日本车型
K
K 开
K-CAN 车身控制器区域网络
K-LWL 塑料光缆
KBA 联邦机动车辆管理局
KBit 千位
kBit/s 千位 / 秒
KBT 校验位
KByte 千字节
KDS 四轮定位系统
Kfz 车辆
kg 千克
KHA 耳机接口模块
KHI 耳机接口
KHV 头枕高度调整
kHz 千赫兹
Kl. 总线端
km 千米
km/h 千米 / 小时
kN 千牛顿
KNV 头枕倾斜度调整装置
KoGr 设计小组
KOREL 空调压缩机继电器信号
kPa 千帕
KS 爆震传感器
KSD 销售服务信息
KSE 儿童座椅识别
KSG 曲轴起动器发电机
KSV 冷起动联锁
KT 售后服务培训
KVA 供油装置;燃油消耗表
KW 短波
kW 千瓦
KWG 曲轴传感器
L
L 长度,Low
l 升
LA 国家规格
LAN 局域网
LBV *背宽度调整
LC 液晶
LCD 液晶显示器
LDA 怠速转速提升
LDF 增压压力传感器
LDR 光敏电阻
LDS 方向盘旋转振动
LDW 纵向动态值
LED 发光二极管
LEV 低排放车辆
LHV 腰部支撑高度调整
LHZ 方向盘加热
LIN 区域互联网
LKV 头枕调整
Lkw 载重汽车
LL 左座驾驶型;怠速;阅读灯
LL-CO 怠速一氧化碳
LLFS 怠速充气控制
LLK 增压空气冷却器
LLS 怠速阀
LM 轻合金
LMM 空气质量计
LNV *背倾斜度调整
LRE 方向盘电子控制装置
LS 氧传感器
LSE 转向柱电子装置
LSH 加热式氧传感器
LSM 转向柱记忆
LSS 转向柱开关
Ltg. 导线
LTV 腰部支撑深度调整
LV 蓄能器增压阀
LVA 供气装置
LVDS 低压差分信号
LW 长波
LW 光缆
LWS 潜热蓄能器
LWS-EEPROM 方向盘角度传感器 EEPROM
M
m 米
m2 平方米
mA 毫安
M 接地,发动机
MAG 熔化极活性气体
MAP 歧管绝对压力
MAX 最大
max. 最大的
MBit 兆位
MBit/s 兆位 / 秒
MBS 最大制动助力
MByte 兆字节
MC 音乐磁带;微控制器
MD 迷你光盘
MD-Ind 发动机扭矩指示值
MDK 节气门
ME 机构单位
MFK 多功能检测导线
MF 多功能座椅,缩微胶片
MFV 多频拔号法
mi 英里
MID 多功能信息显示器
MIG 金属惰性气体
MIN 最小
min 分钟
MIN-TH 制动盘最小厚度
min. 最小的
MIPS 每秒百万指令
MIR 多信息收音机
MJ 年款
MK 中级
Mk 样品
ml 毫升
mls/h 英里 / 小时
mm 毫米
Mod. 车型
MoDiC 便捷式诊断电脑
MOSFET 金属氧化物半导体场效应晶体管
MOZ 发动机辛烷值
MPEG 活动图像专家组
mpg 英里 / 加仑
mph 英里 / 小时
MRS3 多重乘员保护系统 3
MSISDN 移动用户综合业务数字网
MSR 发动机牵引力矩控制系统
MSV 量控阀
MTK 发动机局部通流冷却系
MV 电磁阀
MW 中波
N
N 牛顿;空档
ND 低压
NF 低频
NiMH 镍金属氢化物
NL 分部
Nm 牛顿米
NMA 零量调校
NOx 氧化氮
Nr. 编号
NSD 后消音器
NSL 后雾灯
NSW 前雾灯
NTC 负温度系数
O
o. A. 或其它类似的
O2 氧气
OBD 车载诊断系统
OBD2 车载诊断系统 2
OCN On-Chip-Navigation
OCR 光学字符识别
ohc 顶置式凸轮轴
OPPS 光学检测和编程系统
OPS 光学编程系统
or 桔黄色
ORVR 车载加油蒸发汽回收装置
OT 上死点
OWWT 油-水热交换器
OZ 辛熔值
OZS 机油状态传感器
P
P 驻车
PA 聚酰胺
Pa 帕
PCM 脉冲编码调制
PDA 个人数字助理
PDC 个人数字通信;驻车距离报警系统
PE 聚乙烯
PG 塑料线间隙规
PI 程序识别
PIN 身份识别码
Pkw 轿车
PMMA 有机玻璃
POI 重点
Pos. 位置
Power-LED 电源电压 LED 指示灯
Powertrain-CAN 传动系控制器区域网络
PP 聚丙烯,挡板
PP/EPDM 聚丙烯 / 乙烯-丙烯三聚物橡胶
PS 马力
psi 每平方英寸磅
PT 驱动系
PT-CAN 传动系控制器区域网络
PTC 正温度系数
PU 聚氨酯,中断生产
PUK 个人解锁密码
PVC 聚氯乙烯
PWG 踏板位置传感器
PWM 脉冲宽度调制
Q
QM 质量管理
R
R 电阻,往回,燃油储备
RA 维修说明
RAM 内存
RAS 远程访问服务
RDA 冗余数据存储
RDDWA 轮胎压力监控 - 防盗报警系统接口
RDS 收音机数据系统
RDW 车轮动态值
RDZ 回收拆卸中心
RGB 红绿蓝
RL 右座驾驶型,运行消耗
RME 菜子油甲基酯
RNABE 收音机导航显示和操作面板
RNC 路网覆盖
ROM 只读存储器
ROZ 研究法测定的辛烷值
RPA 轮胎失压显示
RS 编辑系统;倒车档信号
RSK 复位触头
rt 红色
RWS 矫直固定组件
RxD 接收数据
RZV 静态点火分电系统
S
s 秒
SA 特种装备
SAC 自调整式离合器
SAE 汽车工程师学会
SAM 接车服务模块
SAV 运动用途汽车
SBA 保养需求显示
SBE 座位占用识别装置
SBK 安全蓄电池接线柱
SBT BMW 售后服务技术
SCA 自动软关系统
SCSI 小型计算机系统接口
SDARS 卫星数字音频广播服务
SDR 短距离雷达
SDRAM 同步动态随机存取存储器
SE 批量生产
SEFI 全序列喷油
SG 控制单元;手动变速箱
SGBD 控制单元描述文件
SGML 标准通用置标语言
SGS 座椅集成安全带系统
SHFM 二次空气热膜式空气质量计
SHV 座椅高度调整
SI 维修信息,保险丝
SIA 保养周期显示
SIM 客户识别模块;安全和信息模块
SIP 培训自学程序
SKA 燃油关闭装置
SKE 薄壳结构标准外壳
SLM 转向柱位置记忆
SLP 二次空气泵
SLV 座椅纵向调整;二次空气阀
SM 座椅模块;座椅记忆
SMD 表面贴片装置
SMG 自动换档控制的手动变速箱
SMS 短信息服务;短信息 (文本信息)
SNV 座椅倾斜度调整
SOF 帧开始
SPM/SM 座椅后视镜记忆 / 座椅记忆
SRA 大灯清洗装置;车窗清洗装置
SRAM 静态随机存取存储器
SRS 汽车安全气囊系统
SSG 自动换档控制的手动变速箱
SSS Software Service Station
STV 座椅深度调整
StVG 交通法
StVO 交通规则
StVZO 车辆使用技术要求条件
SUV 多功能越野车
SW 开口宽度;软件
sw 黑色
SWZ 专用工具
SZ 特殊附件
T
T 深度
TA 交通广播通知
TAGE 车门外把手电子装置
TD 技术数据
td 涡轮柴油机
TFT 薄膜晶体管
TGK 车门把手触头
THZ 串联式制动主缸
ti 喷射时间
TiO2 二氧化钛
TIS 技术信息系统
TK 车门触头
TL 部分负荷;项目表
TLEV 过渡期低排放车辆
TM 车门模块
TMC 交通信息通道
TMOT 发动机温度传感器
TN 零件号码
TR 温度调节器
TSH 车门锁加热装置
TSV 燃油箱安全阀
TU 技术更新
TUV 技术监督协会
TV 电视
TWI 磨损指示器
TWSZ 分行驶里程表
TxD 发送数据
U
U 电压
U-Batt 蓄电池电压
U/min rpm (每分转)
UBV 底部饰件
UIS 超声波车内防盗监控传感器
UKW 超短波
ULEV 超低排放车辆
Update-CD 更新 CD 光盘
UPE 不具有约束效力的建议价格
URSS 翻车保护系统
US 美国车型
USIS 超声波车内防盗报警传感器
USV 转换阀
UT 下死点
UVV 安全防护法规
V
V 伏特
VA 前桥;用电器断开
VAG 前驱动桥
VANOS 可调式凸轮轴控制装置
VbF 可燃液体规定
VDA 汽车工业联合会
VDE 德国电气、电子和信息技术联合会
VDI 德国工程师协会
VG 经销商
VHS Video Head System
VL 全负荷
vl 左前
VLP 预增压泵
VNT 可变截面喷嘴涡轮机
Vol. 容积
VP 分配式喷射泵
VR 联锁
vr 右前
VS 销售服务
VSG 复合安全玻璃
vt 紫色
W 瓦
WAN 广域网
WAP 无线应用协议
WDCT 世界数字无绳电话
WEP 修理厂设备规划文件
ws 白色
WSA 双向通话装置
WWM 刮水清洗模块
Z
ZA 南非车型
ZB 组装
ZCS 中央主密码
ZDF 德国电视二台
ZDK 德国汽车销售协会
ZEV 零排放车辆
ZF 中频;Friedrichshafen 齿轮厂
ZK 气缸盖,引爆电容器
ZKD 气缸盖密封件
ZKU 点火电路监控
ZL 辅助风扇
ZrO2 二氧化锆
ZS 中央保险,点火线圈
ZSD 中间消声器
ZSR 点火电流反馈信息
ZTA 零件供应中心
ZVM 中控锁模块
ZWD 双绕组旋转式调节器
ZWP 辅助水泵
ZWV 点火角度调整
发表于 28-11-2007 09:13:56 | 显示全部楼层
好东西,搂住强悍
发表于 15-12-2007 22:21:16 | 显示全部楼层
有用的好东西
发表于 12-9-2008 14:20:16 | 显示全部楼层
好,受用了,谢谢
GMT+8, 29-3-2025 04:38 , Processed in 0.319224 second(s), 37 queries .
