  • 2802查看
Defects - hydrogen cracks in steels (焊接专业英语)
发表于 5-9-2007 20:46:30 | 显示全部楼层 |阅读模式
Defects - hydrogen cracks in steels - prevention and best practice
Preheating of a jacket structure to prevent hydrogen cracking
Techniques and practical guidance on the avoidance of hydrogen cracks are described.
Preheating, interpass and post heating to prevent hydrogen crackingThere are three factors which combine to cause cracking in arc welding:
  • hydrogen generated by the welding process
  • a hard brittle structure which is susceptible to cracking
  • tensile stresses acting on the welded joint
Cracking generally occurs when the temperature has reached normal ambient. In practice, for a given situation (material composition, material thickness, joint type, electrode composition and heat input), the risk of hydrogen cracking is reduced by heating the joint. PreheatPreheat, which slows the cooling rate, allows some hydrogen to diffuse away, and prevents a hard, crack-sensitive structure being formed. The recommended levels of preheat for carbon and carbon manganese steel are detailed in EN 1011-2: 2001 (which incorporates the nomograms from BS 5135). The preheat level may be as high as 200°C for example, when welding thick section steels with a high carbon equivalent (CE) value. Interpass and post heatingAs cracking rarely occurs at temperatures above ambient, maintaining the temperature of the weldment during fabrication is equally important. For susceptible steels, it is usually appropriate to maintain the preheat temperature for a given period, typically between 2 to 3 hours, to enable the hydrogen to diffuse away from the weld area. In crack sensitive situations such as welding higher CE steels or under high restraint conditions, the temperature and heating period should be increased, typically 250-300°C for three to four hours. Post-weld heat treatment (PWHT) may be used immediately on completion of welding, i.e. without allowing the preheat temperature to fall. However, in practice, as inspection can only be carried out at ambient temperature, there is the risk that 'rejectable,' defects will only be found after PWHT. Also, for highly hardenable steels, a second heat treatment may be required to temper the hard microstructure present after the first PWHT.
Under certain conditions, more stringent procedures are needed to avoid cracking than those derived from the nomograms for estimating preheat in Fig. C2 of EN 1011-2. Section C.2.9 of this standard mentions the following conditions:
  • high restraint, including welds in section thicknesses above approximately 50mm, and root runs in double bevel joints
  • thick sections ( approximately 50mm)
  • low carbon equivalent steels (CMn steels with C 0.1% and CE approximately 0.42)
  • 'clean' or low sulphur steels (S approximately 0.008%), as a low sulphur and low oxygen content will increase the hardenability of a steel.
  • alloyed weld metal where preheat levels to avoid HAZ cracking may be insufficient to protect the weld metal. Low hydrogen processes and consumables should be used. Schemes for predicting the preheat requirements to avoid weld metal cracking generally require the weld metal diffusible hydrogen level and the weld metal tensile strength as input.
Use of austenitic and nickel alloy weld metal to prevent crackingIn situations where preheating is impractical, or does not prevent cracking, it will be necessary to use an austenitic consumable. Austenitic stainless steel and nickel electrodes will produce a weld metal which at ambient temperature, has a higher solubility for hydrogen than ferritic steel. Thus, any hydrogen formed during welding becomes locked in the weld metal, with very little diffusing to the HAZ on cooling to ambient. A commonly used austenitic MMA electrode is 23Cr:12Ni, e.g. from EN 1600: 1987. However, as nickel alloys have a lower coefficient of thermal expansion than stainless steel, nickel austenitic electrodes are preferred when welding highly restrained joints, to reduce the shrinkage strain. Figure 1 is a general guide on the levels of preheat when using austenitic electrodes. When welding steels with up to 0.2%C, a preheat would not normally be required. However, above 0.4%C a minimum temperature of 150°C will be needed to prevent HAZ cracking. The influence of hydrogen level and the degree of restraint are also illustrated in the figure.
Fig.1 Guide to preheat temperature when using austenitic MMA electrodes at 1-2kJ/mm
a) low restraint (e.g. material thickness <30mm)
b) high restraint (e.g. material thickness >30mm)
Best practice in avoiding hydrogen crackingReduction in weld metal hydrogenThe most effective means of avoiding hydrogen cracking is to reduce the amount of hydrogen generated by the consumable, ie by using a low hydrogen process or low hydrogen electrodes. Welding processes can be classified as high, medium, low, very low and ultra low, depending on the amount of weld metal hydrogen produced. The weld metal diffusible hydrogen levels (ml/100g of deposited metal), and the hydrogen scale designations of EN 1011-2: 2001 are as follows:
High>15Scale A
Medium>10 <15Scale B
Low>5 <10Scale C
Very low>3 <5Scale D
Ultra-low3Scale E
Figure 2 illustrates the relative amounts of weld metal hydrogen produced by the major welding processes. MMA, in particular, has the potential to generate a wide range of hydrogen levels. Thus, to achieve the lower values, it is essential that basic electrodes are used and they are baked in accordance with the manufacturer's recommendations. For the MIG process, cleaner wires will be required to achieve very low hydrogen levels.
Fig.2 General relationships between potential hydrogen and weld metal hydrogen levels for arc welding processes
General guidelinesThe following general guidelines are recommended for the various types of steel but requirements for specific steels should be checked according to EN 1011-2: 2001 -
Mild steel (CE <0.4) - readily weldable, preheat generally not required if low hydrogen processes or electrodes are used - preheat may be required when welding thick section material, high restraint and with higher levels of hydrogen being generated
C-Mn, medium carbon, low alloy steels (CE 0.4 to 0.5) - thin sections can be welded without preheat, but thicker sections will require low preheat levels, and low hydrogen processes or electrodes should be used
Higher carbon and alloyed steels (CE >0.5) - preheat, low hydrogen processes or electrodes, post weld heating and slow cooling required. More detailed guidance on the avoidance of hydrogen cracking is described in EN 1011-2: 2000.
Practical TechniquesThe following practical techniques are recommended to avoid hydrogen cracking:
  • clean the joint faces and remove contaminants such as paint, cutting oils, grease
  • use a low hydrogen process, if possible
  • dry the electrodes (MMA) or the flux (submerged arc) in accordance with the manufacturer's recommendations
  • reduce stresses on the weld by avoiding large root gaps and high restraint
  • if preheating is specified in the welding procedure, it should also be applied when tacking or using temporary attachments
  • preheat the joint to a distance of at least 75mm from the joint line, ensuring uniform heating through the thickness of the material
  • measure the preheat temperature on the face opposite that being heated. Where this is impractical, allow time for the equalisation of temperature after removing the preheating before the temperature is measured
  • adhere to the heat input requirements
  • maintain heat for approximately two to four hours after welding, depending on crack sensitivity
  • In situations where adequate preheating is impracticable, or cracking cannot be avoided, austenitic electrodes may be used
Acceptance standardsAs hydrogen cracks are linear imperfections which have sharp edges, they are not permitted for welds meeting the quality levels B, C and D in accordance with the requirements of EN ISO 5817. Detection and remedial actionAs hydrogen cracks are often very fine and may be sub-surface, they can be difficult to detect. Surface-breaking hydrogen cracks can be readily detected using visual examination, liquid penetrant or magnetic particle testing techniques. Internal cracks require ultrasonic or radiographic examination techniques. Ultrasonic examination is preferred as radiography is restricted to detecting relatively wide cracks parallel to the beam. Most codes will specify that all cracks should be removed. A cracked component should be repaired by removing the cracks with a safety margin of approximately 5mm beyond the visible ends of the crack. The excavation is then re-welded.
To make sure that cracking does not re-occur, welding should be carried out with the correct procedure, ie preheat and an adequate heat input level for the material type and thickness. However, as the level of restraint will be greater and the interpass time shorter when welding within an excavation compared to welding the original joint, it is recommended that a higher level of preheat is used (typically by 50°C).
ReferencesBS 5135:1984 Arc Welding of Carbon and Carbon Manganese Steels (now superceded by EN 1011: 2001) EN 1011-1: 2001 Welding - Recommendations for Welding of Metallic Materials
Part 1- General Guidance for Arc Welding
Part 2- Arc Welding of Ferritic Steels
EN ISO 13916: 1997 Welding - Guidance on the Measurement of Preheating Temperature, Interpass Temperature and Preheat Maintenance Temperature
EN ISO 5817: 2003 Welding - Fusion-welded joints in steel , nickel, titanium and their alloys (Beam welding excluded). Quality levels for imperfections
N Bailey et al, Welding steels without hydrogen cracking, Woodhead Publishing, 2004
发表于 24-4-2025 15:12:17 | 显示全部楼层
关于缺陷——氢致裂纹在钢中的问题:
氢致裂纹是钢材焊接过程中常见的缺陷之一,主要由于焊接过程中氢的渗入和滞留所引起。针对此问题,需严格控制焊接工艺,减少氢的渗入,采取合理焊后处理,如预热、后热等,以降低氢脆敏感性。此外,应采用优质焊接材料及严格的质量控制措施,确保焊缝质量。针对已出现的氢致裂纹,需进行打磨或修补处理,确保结构的安全性和可靠性。
GMT+8, 27-6-2026 02:18 , Processed in 0.439768 second(s), 34 queries .
