  • 2067查看
Rolls-Royce Paint View
发表于 26-8-2007 18:30:43 | 显示全部楼层 |阅读模式
Our xyallic paint contains special particles that react to more vividly than normal metallic paint. Sunlight brings the colour alive.
There are 18 standard colours, but we’ll use any paint colour you request, match a sample, or even create a completely new shade, just for you. Two-tone schemes are also possible.
We don’t just paint our cars: we strive to create an incredibly deep, flawless shine. It all starts in our state-of-the-art ‘clean room’, where our craftsmen work alongside advanced robots, spraying the bodyshells with successive layers of water-based primer, base coat and high-gloss clear coat. There’s a curing process between each layer, along with an inspection and careful cleaning.
Once the painting is complete – an e-coat layer is applied over the entire surface of the body structure to give the Phantom corrosion protection, followed by 15kgs of neutral coloured primer to the body panels themselves, then 15kgs of coloured base coat and finally 18kgs of high gloss clear coat - each bodyshell is sent for inspection and finishing, by specialists like Paint Associate, Lisa Taylor.
‘First, we check the painted body for any slight imperfections', says Lisa, 'partly by sight but more by hand – you develop particularly sensitive fingers in this job. We ring each mark with a Chinagraph pencil, which doesn’t damage the surface, and then gently sandpaper it, before polishing with lambskin until it’s completely smooth and shining.'
‘The biggest challenge is sanding to exactly the right level to smooth out the mark, but not to go too deep. Sometimes I’ve just got the polish perfect and I spot another tiny imperfection and have to begin all over again. In general it takes three polishes on a light colour to get it to my satisfaction, and up to five on a dark colour.’
GMT+8, 23-12-2024 08:42 , Processed in 0.273965 second(s), 27 queries .
